This content has been marked as final.
Show 3 replies
1. Re: vertical drop down menu with effects possible?
Diana Ispas Dec 7, 2007 1:35 AM (in response to jefbak)Hi,
if I well understand your request, you should do the following:
- insert in page a Spry Vertical MenuBar widget
- go in SpryMenuBarVertical.css file to this rule: ul.MenuBarVertical ul and change the margin property from: margin: -5% 0 0 95%; TO margin: -5% 0 0 0%;. This will make the submenu to display right over the items from first level.
If I wrong understood your request please give us a page where to see what you need and we'll let you know how to achieve the desired behavior.
Diana -
2. vertical drop down menu with effects possible?
jefbak Dec 7, 2007 7:43 AM (in response to jefbak)Thanks for the quick response Diana,
I need a submenu behavior that pushes all the menu items down to display the submenu items.
I also don't know how to change the script so that the submenus will stop shrinking. I need them to stay the same size.
Kind of like what the grow or slide? effect might do but with a menu?
Otherwise I am giving you advice a try. -
3. Re: vertical drop down menu with effects possible?
jefbak Jan 30, 2008 7:54 AM (in response to jefbak)Does anyone know if you could combine the Spry Collapsible Group widget mentioned here with Spry vertical menus?
The functionality would be that a menu with sub-menu items would push all the menu items down to show the sub-menu items.
Right now spry sub-menus "fly-out" either up or down covering the surrounding content. If I could get the menu to push down like the collapsible does, then I could a client need I have right now.
