3 Replies Latest reply on Dec 7, 2007 2:54 AM by chrisatflash
    basic OOP question.
    chrisatflash Level 1
      Hello, can anyone explain why the value keeps returning a undefined value?
      this.speedX and this.speedY are undefined.
      in the source file i used to instanciate the class:
      var test:csmove = new csmove(circle, 2,2);
        • 1. Re: basic OOP question.
          Level 7
          if you are using AS2 when you set the onEnterFrame to upsdatepositie
          the scope of that function doesn't belong to your class. to ensure
          this you must use Delegate.create
          import mx.utils.Delegate;
          function movenow() {
          this.targetMC.onEnterFrame = Delegate.create(this,
          and if you want that the targetMC keep on moving inside updatepositie
          you should have
          targetMC._x += this.speedX;
          targetMC._y += this.speedY;
          hope this is usefull
          • 2. Re: basic OOP question.
            Level 7
            You can use delegate as Roberto suggested, or you can simply put your speed
            variables within your target clip:
            function csmove(targetClip:MovieClip, X, Y) {
            this.targetMC = targetClip;
            this.targetMC.speedX = X;
            this.targetMC.speedY = Y;
            You don't need to change anything else. Now when you say this.speedX inside
            your updaepositie() you will be referring to the speedX property of the
            clip. Note also, I changed the function param above to targetClip - I just
            don't like using same named vars like that.
            Dave -
            Head Developer
            Adobe Community Expert
            • 3. Re: basic OOP question.
              Thanks, both methods worked great!
              The Delegate class was new to me.
              The trick to assign a value to a movieclip works also very well.
