2 Replies Latest reply on Aug 30, 2014 3:10 AM by Ggash
    Add TWO Edge Animations/Stages to ONE web page (without using oam)
    Jeffscheffs Level 1
      Hi All,
      This is a bit of a follow on question for those who are adding scalable height/width edge compositions to web pages using the awesome piece of code created by Sarah (http://sarahjustine.com/) and other forum contributors... (attached code below).
      My question is: How do I add a second Edge Animate composition to the same page using this method?  So it's using "Stage" already... i'm guessing it's a matter of changing it to "Stage_02" etc in the following code?  I've tried changing the relevant code but so far I have been unsuccessful in getting it to recognise a second stage.
      Any help would be appreciated, many thanks in advance for your time.
      Jeff
      Index.html
      <!--Adobe Edge Runtime-->
          <script type="text/javascript" charset="utf-8" src="clouds_edgePreload.js"></script>
          <style>
              .edgeLoad-EDGE-78729757 { visibility:hidden; }
          </style>
      <!--Adobe Edge Runtime End-->
      <div class="stagewrap">
              <div id="Stage" class="EDGE-78729757">
              </div><!-- Close Edge Animate Stage -->
      </div><!-- Close stagewrap -->
      Adobe Edge Stage Script
      var stageHeight = sym.$('Stage').height(); // Set a variable for the height of the stage
      sym.$("#Stage").css({ // Set the transform origin so we always scale to the top left corner of the stage
      "transform-origin":"0 0",
      "-ms-transform-origin":"0 0",
      "-webkit-transform-origin":"0 0",
      "-moz-transform-origin":"0 0",
      "-o-transform-origin":"0 0"
      function scaleStage() {
          var stage = sym.$('Stage'); // Set a reusable variable to reference the stage
          var parent = sym.$('Stage').parent(); // Set a reusable variable to reference the parent container of the stage
          var parentWidth = stage.parent().width(); // Get the parent of the stage width
          var stageWidth = stage.width(); // Get the stage width
          var desiredWidth = Math.round(parentWidth * 1); // Set the new width of the stage as it scales
          var rescale = (desiredWidth / stageWidth); // Set a variable to calculate the new width of the stage as it scales
      // Rescale the stage!
           stage.css('transform', 'scale(' + rescale + ')');
          stage.css(  '-o-transform', 'scale(' + rescale + ')');
           stage.css('-ms-transform', 'scale(' + rescale + ')');
          stage.css('-webkit-transform', 'scale(' + rescale + ')');
           stage.css('-moz-transform', 'scale(' + rescale + ')');
          stage.css('-o-transform', 'scale(' + rescale + ')');
          parent.height(stageHeight * rescale); // Reset the height of the parent container so the objects below it will reflow as the height adjusts
      // Make it happen when the browser resizes
      $(window).on('resize', function(){
           scaleStage();
      // Make it happen when the page first loads
      $(document).ready(function(){
          scaleStage();
