1 Reply Latest reply on Jan 21, 2014 3:33 PM by Josh_Corey
    Text Multi-Line
      I have included a Multi-line text in my form. I have found that when the section is filled, only some of the content of the box is seen when printed. How do I make the box expand as the user inputs in that section so all of their comments are viewed when printed or exported?
        • 1. Re: Text Multi-Line
          Josh_Corey Adobe Employee
          Can you describe where it is that you are not seeing the entire text?  Also - was your form created in FormsCentral or did you Import a PDF to create the form?
          When you use the "Download Response as PDF Form" feature from the View Responses tab for any FormsCentral authored form, the PDF that is downloaded should have all of the data the user entered (with exception of attachments which are listed) including all multi-line text fields being automatically expanded to fit all of the text so that you can view/print.
