3 Replies Latest reply on Jan 21, 2014 2:40 PM by Chuck Uebele
    How to create a Photoshop Pattern with an Illustrator Pattern CS6
    EyesStyle
      I've been creating patterns in Illustrator (because it's much easier to preview how the pattern turns out) but when I bring them into Photoshop, using the offset filter, it only works when the patterns are blocked. It doesn't work if the patterns are bricked or hexed- which I use often in illustrator.
      So I decided to try and just create a square in illustrator and fill it with the pattern in illustrator, then copy and paste that square into the Photoshop document. When I do that, I get white lines going through the pattern. Any advice on a way to easily bring Illustrator patterns into Photoshop? I don't even need to create the actual tile in Photoshop- but I'm not sure how to get rid of the white lines.
