10 Replies Latest reply on Jan 22, 2014 11:56 AM by try67
    Print via PrintParams
    Netman
      Hello everybody.
      I need to print first page into the file. I have trusted function:
      pPrint = app.trustedFunction( function(this,pp)
      app.beginPriv();
      try
      var pp = this.getPrintParams();
      pp.interactive = pp.constants.interactionLevel.silent;
      pp.firstPage = 0;
      pp.lastPage = 0;
      pp.fileName = "/c/temp/temp.pdf";
      pp.printerName = "Adobe PDF";
      this.print(pp);
      catch(e)
              app.alert("Error Trusted Function");
      app.endPriv();
      and code for the button:
      if(typeof(pPrint) == "function")
          pp.firstPage = 0;
          pp.lastPage = 0;
          pPrint(pp);
      else
      app.alert("Error Button");
      but it not work with error for buttons code:
      SyntaxError: missing formal parameter
      28:Folder-Level:App:Config.jsAcrobat EScript Built-in Functions Version 10.0
      Acrobat SOAP 10.0
      I just start to programming for Acrobat JavaScript not long ago and not  understand why buttons code not work.
      Would you be so kind to help me.
        • 1. Re: Print via PrintParams
          Your trusted function needs to only call the print command with the PrintParams parameter. That's it.
          It doesn't strike you as odd that you have the same code in both places?
          You need to pass to it a reference to the document object and the PrintParams object, which you're doing, but don't call it "this". That's a reserved keyword.
          So it should basically be:
          pPrint = app.trustedFunction( function(doc,pp) {
          app.beginPriv();
          try {
              doc.print(pp);
          catch(e){
          app.endPriv();
          And you call it like this:
          pPrint(this, pp);
          • 2. Re: Print via PrintParams
            Netman Level 1
            Thanks for the quick reply. Now better understood. I've tried a lot of variants, but all the stops at
            var pp = get.PrintParems();
            with SyntaxError: invalid object initializer 64:Folder-Level:App:Config......
            I can not understand why does not work the button code. I would be very grateful if you help to understand.
            • 3. Re: Print via PrintParams
              I'm now noticing that the error message talks about Config.js, which is am internal JS file of Acrobat... Did you mess around with it in any way? If that file is corrupt then you have a serious problem and should probably run a Repair Installation on the application.
              • 4. Re: Print via PrintParams
                Don't use "this" in a function.
                Don't use just "getPrintParams" either. You need to correctly refer to the object that owns it.
                • 5. Re: Print via PrintParams
                  Netman Level 1
                  Config.js is my file with declared trusted functions and other function work correct (when not use this part of code).
                  • 6. Re: Print via PrintParams
                    Ah, OK, guess I mistook it withsomething else. At any rate, you have an error in this line:
                    This is not how you access the PrintParams object, and you shouldn't do that in the trusted function, anyway.
                    • 7. Re: Print via PrintParams
                      Netman Level 1
                      okay. I just ran the code on Mac and debugger wrote that the error in the file with trusted functions.
                      in this case, I tried to save a document through a trusted function.
                      Acrobat JavaScript Debugger Functions Version 10.0
                      Acrobat SOAP 10.0
                      doc.saveAs is not a function
                      7: Field: Mouse Up
                      • 8. Re: Print via PrintParams
                        You need to provide the full code. We can't help you with just fragments...
                        • 9. Re: Print via PrintParams
                          Netman Level 1
                          On pdf page I have two buttons "Print" and "Save"
                          Trusted function code in file Config.js is
                          //For Save
                          mySaveAs = app.trustedFunction(function(doc,cPath)
                          app.beginPriv();
                          try
                          doc.saveAs(cPath);
                          catch(e)
                          app.alert("Error Config");
                          app.endPriv();
                          //For Print
                          app.beginPriv();
                          try {
                              doc.print(pp);
                          catch(e){
                          app.endPriv();
                          and save button on pdf page has code
                          if(typeof(mySaveAs) == "function")
                          mySaveAs({
                          cPath: "/c/temp/temp.pdf"
                          else
                          app.alert("Missing Save Fucntion " + "Please contact forms administrator");
                          for print button:
                          pp.interactive = pp.constants.interactionLevel.automatic;
                          pp.firstPage = 0;
                          pp.lastPage = 0;
                          pPrint(this, pp);
                          else
                          app.alert("Missing Print Fucntion " + "Please contact forms administrator");
                          • 10. Re: Print via PrintParams
                            That's better...
                            You're not called mySaveAs correctly. You should call it like this:
                            mySaveAs(this, "/c/temp/temp.pdf");
