7 Replies Latest reply on Jan 25, 2014 8:23 AM by W_J_T
    Replace layer names in selected layers only
    big_smile Level 1
      I am using this script to find and replace words in layers. (The script only targets particualr words, rather than the whole layer name).
      I would like to make it so it targets selected layers only.
      I have found this script which loops through selected layers only, but I am not sure how to add the find and replace layer name functioality.
      Thanks for any help that can be offered.
        • 1. Re: Replace layer names in selected layers only
          W_J_T Level 4
          In the original script your using look into adding a condition using:
          if(layerReferenceString.hasSelectedArtwork == true){
               // relative code
          That would offer a way to know if a layer is selected or not.
          • 2. Re: Replace layer names in selected layers only
            big_smile Level 1
            This is my code:
            function renameText() {
                      if (app.documents.length == 0) return;
                      var docRef = app.activeDocument;
                      recurseLayers(docRef.layers);
            if (layerReferenceString.hasSelectedArtwork == true) {
                      renameText();
            function recurseLayers(objArray) {
                      for (var i = 0; i < objArray.length; i++) {
                                objArray[i].name = objArray[i].name.replace(/\s*OLDTEXT\s*\d*/, 'NEWTEXT');
                                if (objArray[i].layers.length > 0) recurseLayers(objArray[i].layers);
            It says layerReferenceString - not defined.
            How can I define layerReferenceString? I have checked in this guide and layerReferenceString doesn't seem to be a built in function, so I am not sure how to make it recognised.
            • 3. Re: Replace layer names in selected layers only
              W_J_T Level 4
              That was just a "generic reference to show the other part of the code. Similar to saying: something.name = blah; You were targeting layers so I just came up with that as a generic reference for you to replace with the appropriate reference in your code, sorry. It was just a pseudo example to show the hasSelectedArtwork.
              • 4. Re: Replace layer names in selected layers only
                big_smile Level 1
                Looking at this guide, there doesn't seem to be a way to detect selected layers. Does this mean it is not possible? Thanks for any help that can be offered.
                • 5. Re: Replace layer names in selected layers only
                  W_J_T Level 4
                  Correct. Yeah there is no direct way unfortunately (like many things via scripting), thats why I suggested using "hasSelectedArtwork", that would work if you select the layer target when selecting your desired layers to rename.
                  • 6. Re: Replace layer names in selected layers only
                    big_smile Level 1
                    Looking through the guide, it doesn't seem "hasSelectedArtwork", is a built in function either. There only seem to be functions to do with selected texct & objects (but no layers).
                    Are there any tutorials or guides that explain how to target selected layers?
                    Thanks for any help!
                    • 7. Re: Replace layer names in selected layers only
                      W_J_T Level 4
                      big_smile wrote:
                      Looking through the guide, it doesn't seem "hasSelectedArtwork", is a built in function either. Are there any tutorials or guides that explain how to target selected layers?
                      Wrong reference manual, see this one:
                      http://www.adobe.com/content/dam/Adobe/en/devnet/pdf/illustrator/scripting/cs6/Illustrator -Scripting-Reference-JavaScript.pdf
                      Page 91 -- CHAPTER 1: JavaScript Object Reference
                      Layer
                      Property
                      hasSelectedArtwork
                      Value type
                      boolean
                      What it is
                      If true, an object in this layer has been selected; set to false to deselect all objects in the layer.
                      So as I talked about here:
                      and...
                           // relative code
                      As far as I know that is the only round about way of knowing if a layer is selected via scripting.
