0 Replies Latest reply on Jun 20, 2006 6:07 AM by christian_cruz
    "contains" doubt in hexadecimal color value?
    christian_cruz Level 1
      Hello, I have a small matrix of tiles, each one is a sprite of a unique cast member that has an initial color assigned by a movie script:
      on setColorInitial me
      --0000ff
      sprite(1).color = color(#rgb 0,0,255)
      hex0000ff = color (sprite(1).foreColor)
      put hex0000ff.hexString()
      --0033ff
      sprite(2).color = color(#rgb 0,51,255)
      hex0033ff = color (sprite(2).foreColor)
      put hex0033ff.hexString()
      --0066ff
      sprite(3).color = color(#rgb 0,102,255)
      hex0066ff = color (sprite(3).foreColor)
      put hex0066ff.hexString()
      --0099ff
      sprite(4).color = color(#rgb 0,153,255)
      hex0099ff = color (sprite(4).foreColor)
      put hex0099ff.hexString()
      --00ccff
      sprite(5).color = color(#rgb 0,204,255)
      hex00ccff = color (sprite(5).foreColor)
      put hex00ccff.hexString()
      --00ffff
      sprite(6).color = color(#rgb 0,255,255)
      hex00ffff = color (sprite(6).foreColor)
      put hex00ffff.hexString()
      end
      Each tile is a button that when pressed it can change the blend value of the other sprites. It sounds very easy, but the problem is when I have a matrix of 100 tiles and each one is a button! The blend occurrs in a predetermined way, that is to say if tile "00ffff" is pressed then a predetermined amount of sprites will remain with blend value 100 and all the others will change to a blend value 20 for example.
      Is there any way to use a "contains" that can predefine that all the tiles that contains the hexadecimal color value "blablabla" and "blablabla2" and "blablabla3" to change its blend value to 100 and all the others to change to 20. I know that "contains" works as an operator in strings, but can I use it in this case, how?
