2 Replies Latest reply: Jan 23, 2014 5:07 AM by BKBK RSS
    Crappy Mappings, ie, Crappings
    Aegis Kleais Community Member
      So correct me if I'm wrong.  I have a file structure that looks like this:
      models
      > framework
      >> alpha.cfc
      application.cfc
      I am executing from application.cfc.  In it, I have created a mapping (NOTE THE DIFFERENCE IN SINGULAR/PLURAL):
      <cfset this.mappings[ '/model' ] = expandPath( '/models/framework' ) />
      When I dump the this.mappings structure, I expectedly get:
      c:\path\to\webroot\models\framework
      So I now dump this code:
      <cfdump var="#fileExists( expandPath( '/model/alpha.cfc' ) )#" />
      And sure, enough, I get: YES
      So here's my problem.  I had always thought that in dot notation syntax, ColdFusion looked at the first value provided and did a mapping check on it.  However, when I run:
      <cfset myNewAlpha = new model.alpha() />
      I get a message saying the CFC cannot be found.  Only by typing the following:
      <cfset myNewAlpha = new '/model.alpha'() />
      Does it actually work and find the CFC through dot notation my using the this-scope mapping.
      So, is there something I'm missing as to why I can't just call nameOfMapping.path.to.cfc rather than having to make a literal string out of it?
        • 1. Re: Crappy Mappings, ie, Crappings
          Well, status update.  Even after doing an: applicationStop() and for all practical puposes, killing the application, it seems ColdFusion, the service, holds onto those mappings and caches them.  I actually had to RESTART THE COLDFUSION APPLICATION SERVICE to get it to release those mappings, and now I can use the: new model.alpha() syntax as expected.
          Sheesh!
          • 2. Re: Crappy Mappings, ie, Crappings
            BKBK Community Member
            You are right: it should work as you expect! Since it fails, this might be an indication that expandPath( '/models/framework' ) and c:\path\to\webroot\models\framework\ are not the same.
            To verify, I would test with
            <cfset this.mappings[ '/model' ] = "c:\path\to\webroot\models\framework\" />
            together with
