0 Replies Latest reply on Jan 22, 2014 11:49 AM by webnewbie10
    text doesn't align in animation
    webnewbie10 Level 1
      I'm not sure if this is an Edge issue or Muse, so I'll post in both. I'm having a hard time getting two pieces of different size text to align at the bottom of an animation. I tried align command and manually aligning on a guideline. But I can't get consistent results across browsers.
      The animation is my home page, which was created in Muse. When I publish on Business Catalyst, it looks good on both Firefox and Safari. BUT when I actually upload the files, the word "inter" is lower than the word "active in Firefox, and higher in Safari, IE, etc... I did add a little code to a few files before uploading, so that's the only difference between the two sites.
      To index.html head, I added:
      <!--[if lte IE 8]>
      location.assign('http://www.jamison-design.com/index2.html');
      /// redirect internet explorer users
      </script>
      <![endif]-->
      To contact.html head, I added:
      <!--[if lte IE 8]>
      location.assign('http://www.jamison-design.com/contact2.html');
      </script>
      <![endif]-->
      To site_global.css:
      I changed
      .widget_invisible,.js .invi,.js .se_invi,.js .an_invi /* used to hide the widget before loaded */
      { visibility: hidden; }
      to visibility: visible;
      I don't see why any of those things would make a difference. PLEASE HELP! I'm a designer, and the alignment makes a difference. Thanks! Here are the links...
      http://jamison-designcom.businesscatalyst.com
      http://jamison-design.com
      Note: if you navigate, do NOT use the home icon (This will take you to a page without the animation, which has proper alignment). Use the back button.
