10 Replies Latest reply on Feb 5, 2014 9:39 AM by Ramox2000
    Problem with display driver
    illuminator26 Level 1
      Hello,
      Im using Photoshop CC and when it starts up it sometimes gives me this error message:
      'Problem with display driver and has temporary disabled enhancements which use graphics hardware.'
      What does this mean?
      Then it tells me to download the latstest software and gives me a link to an Adobe site that tells me nothing about a sollution.
      About my mac:
      MacBook Pro
      Intel Core i7
      2,2 GHz
      4 cores
      8 GB RAM
      AMD Radeon HD 6750M
      Thanks a bunch!
        • 1. Re: Problem with display driver
          Level 7
          You need to contact Apple, since the video driver in your OS has problems.
          • 2. Re: Problem with display driver
            Ramox2000 Level 1
            I have pretty much the same setup.
            Photoshop CC used to work fine, then I had to get my Logic Board replaced.
            Since then I get intermittant RAM warnings in Photoshop.
            Often they are so frequent that Photoship CC is unusable, at which point I go back to Photoshop CS5, which works fine.
            My other RAM guzzling apps all work fine too.
            If I go to: Photoshop > Preferences > Performance it does show the correct graphics card in there:
            AMD Radeon HD 6750M
            Disabling the Sniffer seems to make the warnings more intermittant but certainly does not solve it.
            Is this definitely a video driver issue?
            As you probably know you cant just update these easily.
            I cant decide if this is an Adobe or Apple issue, but Photoshop CC (alone) is off the menu.
            I posted this question on the Apple discussions too:
            https://discussions.apple.com/thread/5774715
            But as yet nothing that solves the problem.
            • 3. Re: Problem with display driver
              Curt Y Level 7
              CS6 and CC use the GPU a lot more heavily than CS5.  So can card or driver problems would be more noticeable.
              • 4. Re: Problem with display driver
                Ramox2000 Level 1
                Ok, so is there a setting that uses the GPU less intensively, more like CS5 used to?
                I have fiddled with various performance settings but I still get the RAM warnings.
                If this is indeed a display card or display driver issue is it a case of going back to the Apple Approved Servicer?
                • 5. Re: Problem with display driver
                  Curt Y Level 7
                  You can adjust the gpu setting to basic in preferences/performance.  But Adobe redid the code and puts more reliance on the GPU for many of the fuctions.
                  Could not see 6750M in passmark list.  THey have a 670M and and 675M, but both should work fine.  The key is the driver.  May have to check with Apple on this like Chris suggested.
                  • 6. Re: Problem with display driver
                    Jeffrey Tranberry Adobe Employee
                    It may help if we could see your Photoshop System Info. Directions for sharing your system info from Photoshop:
                    http://feedback.photoshop.com/photoshop_family/topics/photoshop_how_do_i_share_my_system_i nformation
                    • 7. Re: Problem with display driver
                      Ramox2000 Level 1
                      Sorry guys, I pasted the info from my iMac rather than my MacBook Pro, which has the problem.
                      Please ignore that last entry.
                      I will get the correct info now.
                      • 8. Re: Problem with display driver
                        Ramox2000 Level 1
                        Here you go:
                        Adobe Photoshop Version: 14.2 (14.2 20131211.r.515 2013/12/11:23:00:00) x64
                        Operating System: Mac OS 10.9.1
                        System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                        Physical processor count: 4
                        Logical processor count: 8
                        Processor speed: 2200 MHz
                        Built-in memory: 4096 MB
                        Free memory: 2266 MB
                        Memory available to Photoshop: 3136 MB
                        Memory used by Photoshop: 80 %
                        Image tile size: 1024K
                        Image cache levels: 4
                        Font Preview: Medium
                        TextComposer: Latin
                        The GPU Sniffer crashed on 10/01/2014 at 09:05:58
                        Display: 1
                        Main Display
                        Display Bounds: top=0, left=0, bottom=900, right=1440
                        OpenGL Drawing: Enabled.
                        OpenGL Allow Old GPUs: Not Detected.
                        OpenGL Drawing Mode: Advanced
                        OpenGL Allow Normal Mode: True.
                        OpenGL Allow Advanced Mode: True.
                        AIFCoreInitialized=1
                        AIFOGLInitialized=1
                        OGLContextCreated=1
                        NumGPUs=1
                        gpu[0].OGLVersion="2.1"
                        gpu[0].MemoryMB=1024
                        gpu[0].RectTextureSize=16384
                        gpu[0].Renderer="AMD Radeon HD 6750M OpenGL Engine"
                        gpu[0].RendererID=16915206
                        gpu[0].Vendor="ATI Technologies Inc."
                        gpu[0].VendorID=4098
                        gpu[0].HasNPOTSupport=1
                        gpu[0].CompileProgramGLSL=1
                        gpu[0].TestFrameBuffer=1
                        gpu[0].OCLPresent=1
                        gpu[0].OCLVersion="1.2 (Aug 24 2013 21:03:27)"
                        gpu[0].CUDASupported=0
                        gpu[0].OCLBandwidth=1.89051e+10
                        gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                        gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[4096]
                        gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                        gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                        gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                        gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                        gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                        gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[3072]
                        gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[3072]
                        gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
                        gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                        gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                        gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                        gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                        License Type: Subscription
                        Serial number:
                        Application folder: /Applications/Adobe Photoshop CC/
                        Photoshop scratch has async I/O enabled
                        Scratch volume(s):
                          Macintosh HD, 697.8G, 107.2G free
                        Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
                        Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-Ins/
                        Installed components:
                           adbeape.framework   adbeape   3.4.0.29366   0.1160850
                           AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.31983   79.546835
                           adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
                           AdobeACE.framework   AdobeACE   2.20.02.31977   79.548223
                           AdobeAGM.framework   AdobeAGM   4.30.29.31977   79.548223
                           AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                           AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                           AdobeBIB.framework   AdobeBIB   1.2.03.31977   79.548223
                           AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.548223
                           AdobeCoolType.framework   AdobeCoolType   5.15.00.31977   79.548223
                           AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
                           AdobeExtendScript.framework   AdobeExtendScript   4.5.5.31983   79.546835
                           AdobeJP2K.framework   AdobeJP2K   1.2.2.31977   79.248139
                           AdobeLinguistic.framework      19061
                           AdobeMPS.framework   AdobeMPS   5.8.1.31977   79.535029
                           AdobeOwl.framework   AdobeOwl   5.0.24   79.547804
                           AdobePDFL.framework   AdobePDFL   11.0.0.31977   79.508720
                           AdobePDFSettings.framework   AdobePDFSettings   1.4
                           AdobePIP.framework   AdobePIP   7.0.0.1786
                           AdobeScCore.framework   AdobeScCore   4.5.5.31983   79.546835
                           AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                           AdobeXMP.framework   AdobeXMPCore   79.154911   79.154911
                           AdobeXMPFiles.framework   AdobeXMPFiles   79.154911   79.154911
                           AdobeXMPScript.framework   AdobeXMPScript   79.154911   79.154911
                           ahclient.framework   ahclient   1.8.0.31
                           aif_core.framework   AdobeAIF   5.0.00   79.534508
                           aif_ocl.framework   AdobeAIF   5.0.00   79.534508
                           aif_ogl.framework   AdobeAIF   5.0.00   79.534508
                           AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
                           amtlib.framework   amtlib   7.0.0.249
                           boost_date_time.framework   boost_date_time   7.0.0.0
                           boost_signals.framework   boost_signals   7.0.0.0
                           boost_system.framework   boost_system   7.0.0.0
                           boost_threads.framework   boost_threads   7.0.0.0
                           Cg.framework   NVIDIA Cg
                           CIT.framework   CIT   2.1.6.30929   151865
                           CITThreading.framework   CITThreading   2.1.6.30929   151865
                           dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
                           dvacore.framework   dvacore   7.0.0.0
                           dvamarshal.framework   dvamarshal   7.0.0.0
                           dvamediatypes.framework   dvamediatypes   7.0.0.0
                           dvaplayer.framework   dvaplayer   7.0.0.0
                           dvatransport.framework   dvatransport   7.0.0.0
                           dvaunittesting.framework   dvaunittesting   7.0.0.0
                           dynamiclink.framework   dynamiclink   7.0.0.0
                           FileInfo.framework   FileInfo   79.154511   79.154511
                           filter_graph.framework   AdobeAIF   5.0.00   79.534508
                           ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                           ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                           LogSession.framework   LogSession   2.1.2.1785
                           mediacoreif.framework   mediacoreif   7.0.0.0
                           patchmatch.framework   patchmatch   1.2.00.31977   79.542390
                           PlugPlugOwl.framework   PlugPlugOwl   4.2.0.36
                           UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
                           WRServices.framework
                        Required plug-ins:
                           3D Studio 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Accented Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Adaptive Wide Angle 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                           Angled Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Average 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
                           Bas Relief 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           BMP 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Camera Raw 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Camera Raw Filter 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Chalk & Charcoal 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Chrome 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Cineon 14.2 x001  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
                           Clouds 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Collada DAE 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Color Halftone 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Colored Pencil 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Craquelure 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crop and Straighten Photos 14.2 x001  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                           Crop and Straighten Photos Filter 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Crosshatch 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crystallize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Cutout 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Dark Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           De-Interlace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
                           Difference Clouds 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Diffuse Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Displace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dry Brush 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Eazel Acquire 14.2 x001  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                           Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                           Entropy 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Extrude 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           FastCore Routines 14.2 x001  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
                           Fibers 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Film Grain 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Filter Gallery 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Flash 3D 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Fresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glowing Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Google Earth 4 KMZ 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Graphic Pen 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Halftone Pattern 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                           IFF Format 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Ink Outlines 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           JPEG 2000 14.2 x001  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                           Kurtosis 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Lens Blur 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                           Lens Correction 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                           Lens Flare 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Liquify 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
                           Matlab Operation 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Maximum 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Mean 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Measurement Core 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                           Median 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Mezzotint 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Minimum 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           MMXCore Routines 14.2 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                           Mosaic Tiles 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Multiprocessor Support 14.2 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                           Neon Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Note Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           NTSC Colors 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                           Ocean Ripple 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Oil Paint 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                           OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Paint Daubs 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Palette Knife 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Paths to Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           PCX 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
                           Photocopy 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Photoshop 3D Engine 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                           Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
                           Picture Package Filter 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Pinch 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pixar 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
                           Plaster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Plastic Wrap 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pointillize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Polar Coordinates 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Portable Bit Map 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
                           Poster Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Radial Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Radiance 14.2 x001  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
                           Range 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Read Watermark NO VERSION - from the file “DigiRead.plugin”
                           Reticulation 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Ripple 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Rough Pastels 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Save for Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                           ScriptingSupport 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                           Shake Reduction 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                           Shear 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Skewness 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Smart Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Smudge Stick 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Solarize 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
                           Spatter 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Spherize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Sponge 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Sprayed Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stained Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stamp 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Standard Deviation 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           STL 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Summation 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Texturizer 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Tiles 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Torn Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Twirl 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Underpainting 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Vanishing Point 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                           Variance 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Water Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Watercolor 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Wave 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wavefront|OBJ 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Wind 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wireless Bitmap 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
                           ZigZag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                        Optional and third party plug-ins: NONE
                        Plug-ins that failed to load: NONE
                        Flash:
                           Mini Bridge
                           Kuler
                           Adobe Exchange
                        Installed TWAIN devices: NONE
                        • 9. Re: Problem with display driver
                          Thanks. Are you running AirDisplay on your system buy chance?
                          • 10. Re: Problem with display driver
                            Ramox2000 Level 1
                            No.
                            When I do connect it to an Apple Cinema Display I use a Thunderbolt cable.
                            I still get the RAM warnings even when using just the built in display.
