3 Replies Latest reply on Jan 23, 2014 9:05 AM by celine of alchimia
    How to discard a random symbol
    celine of alchimia
      Hello,
      I have a problem:  I have a keyframe where I must to upload a random series of symbols, and I do it with the script:
      var myVar = Math.floor((Math.random()*6)+1);
           var stage = sym.$("Stage");
                 var myAni = sym.createChildSymbol("Symbol_" + myVar, "stage");
                myAni.appendTo(stage);
      The script works fine, but, at NEXT keyframe I must load another series. The problem is that the symbol loaded in the previous keyframe is still present and the new symbol overlaps it.
      How can I unload or discard the previous symbol?
      Thanks in advance.
      Celine
        • 1. Re: How to discard a random symbol
          Saurav Adobe Employee
          Hi Celine ,
          Can you just try by listing all the child symbols using sym.getChildSymbols() and then deleting them using sym.deleteSymbol() . I assumed that you want to add different set of symbols at a different time on the timeline .
          Saurav
          • 2. Re: How to discard a random symbol
            heathrowe Most Valuable Participant
            Another option is to set the symbol instance to an element container (draw out a rectangle element), instead of placing them on the Stage.
            So, changes in bold
            // Set the child symbol container to an element; in my case a Rectangle element called Rectangle.
                var stage = sym.$("Rectangle");
            // Then before the symbol instance is created, call the empty() method on the previous container. In other
            // words make sure it is empty before adding a random one.
                stage.empty();
                var myAni = sym.createChildSymbol("Symbol_" + myVar, stage);
            Darrell
            • 3. Re: How to discard a random symbol
              celine of alchimia Level 1
              Both suggestions work! Thanks for solving the problem.
              celine
