6 Replies Latest reply on Jan 23, 2014 6:28 AM by Eugene Tyson
    Buttons - Open file - open in new screen
    LucVG
      I use the buttons to open a new PDF. Works fine, but the only problem is that the document opens in the same screen, and when closing this new opened document, I lost my previous screen. I need to restart all.
      What is the solution for this issue ?
      I can change all the links using Acrobat X, because there you can make the choice. Problem is that when you re-generate a new PDF (some changes), you need to do all the work again.
      Luc
      (Indesign CS6)
