1 Reply Latest reply on Jan 23, 2014 8:09 AM by al_reidy
    Indesign server CC trial help
    al_reidy
      I have programmed Applescript and Indesign for desktop for years.
      I have a solution that should work well with Indesign server and applescript.
      Downloaded the Trial for Indesign Server CC.
      Then you have to figure out how to activate the product, which i think i have done via this command :
      adobe_prtk --tool=StartTrial --leid=InDesignServer-CS7-Mac-GM
      Now that its not compaining about being activated i can see that the sample applescripts provided in the install can compile.
      If i run them however i get a failiure thats odd.
      tell application "Finder"
                get startup disk
                          --> "CWFM1:"
                exists "CWFM1:ServerTestFiles"
                          --> true
                exists "CWFM1:ServerTestFiles:bob.indd"
                          --> false
      end tell
      tell application "InDesignServer"
                close every document saving no
                make new document
                          --> document "Untitled 3"
                save document "Untitled 3" to "CWFM1:ServerTestFiles:bob.indd"
                          --> error number -1728
      Result:
      error "InDesignServer got an error: Can’t get document \"Untitled 3\"." number -1728 from document "Untitled 3"
      The folder is chmod'd to 777 so its not a read write issue.
      if i just use the normal open command in applescript i get this error :
      The document “bob.indd” could not be opened. InDesignServer cannot open files of this type.
      which is just odd. its a normal empty indesign document with nothing in it!
      has anyone got ideas?
      Server is MacMini i7 with 16gb ram, OS X 10.8.5 server.
