5 Replies Latest reply on Jan 24, 2014 11:36 AM by lapneto
    Help with search results - Arrays and indexOf
    lapneto
      Hey guys,
      Need help again - I was able to import a txt file using the code below:
      var ofile = util.readFileIntoStream();
      var myfile = util.stringFromStream(ofile);
      Now i have to perform a search within this file so, I use am using the following code:
      var pattern = new RegExp("27"+abc,"\g"); //establish the pattern I need, abc is another variable established earlier in the code
      myfile.search(pattern); //search myfile for the pattern above
      myfile.match(pattern); //find matching results of the pattern above
      var count = myfile.match(pattern).length; //create a variable with number of matches found
      if(count>0)
      app.alert("Matches found: "+count) //display in an alert the number of matches
      However, now I need to know exactly the position (indexOf) of each of the matches I found in myfile, as I need to extract some characters after the match to input in a specific field of my form.
      I guess I need to establish some sort of array and some sort of loop to the next match, therefore could anyone poing me in the right direction?
      I am not even sure I am following the right path here, so any help will be much appreciated.
      Thanks everyone,
        • 1. Re: Help with search results - Arrays and indexOf
          After you have your matches you can use the "indexOf" method to get their locations, I believe. If there are multiple matches you'll also need to specify the second parameter of this method, to specify from where to start looking...
          • 2. Re: Help with search results - Arrays and indexOf
            lapneto Level 1
            Hi Gilad D, thanks for the usual help.
            Could you please provide me with a little more information or more hints?
            I am trying to use the indexOf method, but my matches will indeed be multiple.
            To be honest, I need to get 35 characters following each match and paste it somewhere else, but I am having no luck with the indexOf use...
            Many thanks for your usual help.
            • 3. Re: Help with search results - Arrays and indexOf
              I've written a piece of code that does it with pure text. You can probably adjust it to use the results of your RegExp match:
              var text = "Hello, what's your name? my name is Gilad."
              var searchTerm = "name";
              var contextLength = 5;
              var matchesCounter = 0;
              var startIndex = 0;
              var matchIndex = text.indexOf(searchTerm,startIndex);
              while (matchIndex!=-1) {
                  matchesCounter++;
                  var context = text.substring(matchIndex-contextLength,matchIndex+searchTerm.length+contextLength);
                  console.println("MATCH " + matchesCounter + " (" + matchIndex + "): " + context);
                  startIndex = matchIndex+searchTerm.length;
              The results of running this code are:
              MATCH 1 (19): your name? my
              MATCH 2 (28): ? my name is G
              • 4. Re: Help with search results - Arrays and indexOf
                lapneto Level 1
                Hi Gilad,
                Thank you so much for your help, adjusting the code above gave me the results I needed!
                Now it will just be a matter of writing the rest of the code (not that it will be easy, but I guess I am on my way!)
                Thanks again!
                • 5. Re: Help with search results - Arrays and indexOf
                  lapneto Level 1
                  Hi Gilad,
                  Suppose i need  to write each of the results to a field (e.g. myField_1, myField_2 etc...).
                  What sort of code would I need to create? I mean, I am no pro and all the code I used was based on the help I get here...
                  Would I need to make it access the field name and increase the end of the field name? (e.g. myField_#+1? Not sure at all)
                  Many thanks again!
