32 Replies Latest reply on Nov 8, 2014 8:56 PM by jokki
    Undo is not working properly (grayed out)
    Eudia
      Undo is not working properly in Indesign CC 9.2. I am using a 17" MBP running OSX 10.9.1.
      Processor: 2.2 GHz Intel Core i7
      Memory: 4GB 1333 MHz DDR3
      I ran into this issue doing a publication layout. I was not doing anything overly complicated. Copying/pasting, placing images, adding text boxes, copying/pasting text boxes. It seems to happen without rhyme or reason.
      I know that is not helpful for troubleshooting so I was able to isolate the problem. Here is how to recreate it.
      Open new doc (standard letter)
      Create text box with random text
      copy the text box (cmd C)
      paste the text box (cmd V)
      move the resulting text box using selection tool (V)
      select NEW text box (selection tool)
      copy the NEW text box (cmd C)
      paste the NEW text box (cmd V)
      move the text box (selection tool).
      Repeat until there are 5 text boxes (at least).
      Undo the various actions after placing and moving the 5 text boxes.
      I cannot undo back to a "new document."
      In some cases I can only undo 2 actions before "undo" becomes grayed out, and in some cases, I can undo up to 9 or 10 actions before it gets grayed out.
      Other programs running:
      Illustrator
      Photoshop
      Text Edit
      MS Word 2011
      Excell 2011
      Messages
      Chrome
      Finder
      Fetch (FTP software)
      I need to have these programs running simultaneously in many cases and have done so successfully in the past. I have a feeling it might be a memory issue, but I have not seen a similar post and I never had the issue with CS5 running with an identical setup. I was able to undo actions up until my previous save in CS5 sometimes 25-30 actions.
        • 1. Re: Undo is not working properly (grayed out)
          BDinkar Adobe Employee
          Hello Eudia,
          We are trying to recreate this problem at our end but so far things are working fine at our end. I am not seeing Undo getting grayed out when it is not suppose to. Is it possible for you to provide a video showing the problem from scratch? Would be really helpful.
          Also, when you see Undo getting grayed out, please check File->Save/Save As option also? Are they enabled? I am asking this because we have fixed one bug related to Save/Saveas and undo/redo getting grayed out in 9.2? just wanted to make sure if Save/SaveAs are working fine.
          Dinkar
          • 2. Re: Undo is not working properly (grayed out)
            Eudia Level 1
            Here is a video of it happening.
            http://youtu.be/L2NRbfGuCHU
            Save/Save/as functions properly and works fine.
            I'm pretty sure it's a memory problem (I have my "Activity Monitor" opened so you can see the CPU usage), and my screen recorder was eating up a lot of RAM, but I have made tutorials using the same screen recorder with all the same programs opened in CS5 and not had a problem.
            Please note the other programs opened in the dock.
            Also opened are
            2 word documents opened,
            1 excel document
            Chrome
            2 finder windows,
            Fetch FTP browser (inactive)
            Note: after I closed my screen recorder, I did the same thing and was able to undo 5 times before the option was grayed out.
            • 3. Re: Undo is not working properly (grayed out)
              Thanks Eudia for sharing the video.
              We are trying here to reproduce the issue. So far with the steps you have provided, Undo-Redo is working fine for us. We wil update you as soon as we find out whats going wrong.
              Dinkar
              • 4. Re: Undo is not working properly (grayed out)
                Eudia Level 1
                Thanks Dinkar,
                I tried restarting the computer and here's what I found. When running InDesign by itself after a restart, none of those problems arise. Undo functions properly.
                When I run all the other programs with InDesign, undo becomes spotty. Unfortunately, I will NEED the other programs running for my work flow and I don't think it is an exorbant amount.
                From Adobe's InDesign tutorials, it states:
                You can undo or redo up to several hundred of the most recent actions (the amount is limited by the amount of RAM available and the kinds of actions you performed).
                To me, that says it is a memory issue on my MBP.
                I am running a late 2011 MBP with 4G of RAM.
                Is this normal behavior for InDesign CC running on a setup like mine to have less than 10 undo actions when other programs are running? Is 4G no longer sufficient?
                • 5. Re: Undo is not working properly (grayed out)
                  drwMrk
                  I've expereinced similar issues in InDesign. Usually this behavior, for me, accompanies the inability to save as well.
                  I found, quite be accident, that this issue somehow involved missing fonts or issues with Suitcase Fusion and it's plugins not being up to date. I had specified fonts in the document that were at one time available on the system (usually made available via Suitcase Fusion), but when I have these undo and save issues, such fonts are not availalbe.
                  Usually in the past I've been able to ignore missing fonts, and continue to edit the document. I'm finding this is no longer the case—missing fonts appear to mess with InDesign's ability to undo/save. It may not be the missing fonts that are the issue, but the need for Suitcase Fusion to update with InDesign (either the core app itself, or the plugin that it uses with InDesign). But either way, when fonts aren't available, suddenly I have these issues.
                  I thought I had this issue figured out by updating Suitcase Fusion, but lately with Adobe's tighter integration with Typekit, this appears to be happening again.
                  • 6. Re: Undo is not working properly (grayed out)
                    No Eudia. This is not the expected behavior. There is something that is wrong and we here are trying to see what the problem is. If you could find any other information you think would be important for us, please let us know. Meanwhile, we are trying to recreate the problem at our end.
                    Dinkar
                    • 7. Re: Undo is not working properly (grayed out)
                      Hello Drew,
                      As posted in other thread, if possible, please provide one such file with which you are able to reproduce this issue consistently @ sharewithID@adobe.com.
                      Dinkar
                      • 8. Re: Undo is not working properly (grayed out)
                        Eudia Level 1
                        Thanks Dinkar,
                        Exhibited the same behavior again. This time without the other programs running (just activity monitor and QuickTime). Isolated the memory issue to InDesign.
                        Here is the screen record of it. http://youtu.be/RP9eqLYoOr4
                        The "extra" programs were running previously and I shut them down, but did not restart the MBP before I made the video so there could be some residudual memory being tied up but not sure if that would contribute.
                        I did the same thing after I recorded it without Quicktime or Activity Monitor active and it let me undo 5 actions again before "graying" out.
                        Other things of note:
                        Also connected to the MBP via USB:
                        a 750GB Seagate external hard drive for Time Machine backups
                        A logitech M310 wireless Mouse
                        An Iphone 4 (just charging).
                        • 9. Re: Undo is not working properly (grayed out)
                          Eudia Level 1
                          I unplugged the USB items and the problem still persisted so it is not related to any of those.
                          I shut down InDesign and tried reopening. InDesign crashed at reopen. I have provided the log below. Hopefully this shows where the problem is occurring.
                          Process:         Adobe InDesign CC [3814]
                          Path:            /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
                          Identifier:      com.adobe.InDesign
                          Version:         9.2.0.69 (9200)
                          Code Type:       X86-64 (Native)
                          Parent Process:  launchd [172]
                          Responsible:     Adobe InDesign CC [3814]
                          User ID:         ***
                          Date/Time:       2014-01-27 11:58:37.300 -0800
                          OS Version:      Mac OS X 10.9.1 (13B42)
                          Report Version:  11
                          Anonymous UUID:  ********************
                          Sleep/Wake UUID: *********************
                          Crashed Thread:  8
                          Exception Type:  EXC_CRASH (SIGABRT)
                          Exception Codes: 0x0000000000000000, 0x0000000000000000
                          Application Specific Information:
                          abort() called
                          *** error for object 0x6180002737c0: Heap corruption detected, free list canary is damaged
                          Thread 0:: Dispatch queue: com.apple.main-thread
                          0   libsystem_kernel.dylib         0x00007fff8af44622 __open_nocancel + 10
                          1   libsystem_c.dylib             0x00007fff8fa09c9b __opendir2$INODE64 + 59
                          2   com.apple.CoreFoundation       0x00007fff8d160d4a _CFIterateDirectory + 74
                          3   com.apple.CoreFoundation       0x00007fff8d1636b3 _CFBundleCopyInfoDictionaryInDirectoryWithVersion + 627
                          4   com.apple.CoreFoundation       0x00007fff8d16331d CFBundleGetInfoDictionary + 141
                          5   com.apple.CoreFoundation       0x00007fff8d15fb5b _CFBundleCreate + 827
                          6   com.apple.CoreFoundation       0x00007fff8d1a3e89 _CFBundleEnsureBundleExistsForImagePath + 89
                          7   com.apple.CoreFoundation       0x00007fff8d24bb93 _CFBundleEnsureAllBundlesUpToDateAlreadyLocked + 67
                          8   com.apple.CoreFoundation       0x00007fff8d1a3bf8 CFBundleGetBundleWithIdentifier + 248
                          9   com.adobe.InDesign.AWS         0x000000011667d2bc 0x116676000 + 29372
                          10  com.adobe.InDesign.AWS         0x000000011667a577 0x116676000 + 17783
                          11  com.adobe.InDesign.AWS         0x000000011667a370 0x116676000 + 17264
                          12  com.adobe.InDesign.AWS         0x00000001166772a7 0x116676000 + 4775
                          13  com.adobe.InDesign.AWS         0x0000000116683fb0 0x116676000 + 57264
                          14  com.adobe.InDesign.AWS         0x000000011668472e 0x116676000 + 59182
                          15  com.adobe.InDesign.AWSUI       0x0000000116646597 0x116636000 + 66967
                          16  com.adobe.InDesign.AWSUI       0x0000000116645f05 0x116636000 + 65285
                          17  com.adobe.InDesign.AppFramework 0x000000010d6739bb 0x10d632000 + 268731
                          18  ObjectModelLib.dylib           0x0000000104b2fcd3 0x104b10000 + 130259
                          19  ObjectModelLib.dylib           0x0000000104b4306c 0x104b10000 + 209004
                          20  ObjectModelLib.dylib           0x0000000104b3e3fc ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 7676
                          21  com.adobe.InDesign             0x0000000100001c7e main + 94
                          22  com.adobe.InDesign             0x0000000100001bb4 start + 52
                          Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                          0   libsystem_kernel.dylib         0x00007fff8af45662 kevent64 + 10
                          1   libdispatch.dylib             0x00007fff9067043d _dispatch_mgr_invoke + 239
                          2   libdispatch.dylib             0x00007fff90670152 _dispatch_mgr_thread + 52
                          Thread 2:
                          0   libsystem_kernel.dylib         0x00007fff8af44716 __psynch_cvwait + 10
                          1   libsystem_pthread.dylib       0x00007fff97874c77 _pthread_cond_wait + 787
                          2   com.apple.CoreServices.CarbonCore 0x00007fff92a51c37 TSWaitOnConditionTimedRelative + 148
                          3   com.apple.CoreServices.CarbonCore 0x00007fff92a2238d MPWaitOnQueue + 192
                          4   PMRuntime.dylib               0x0000000101682be1 0x101681000 + 7137
                          5   com.apple.CoreServices.CarbonCore 0x00007fff92a2290b PrivateMPEntryPoint + 58
                          6   libsystem_pthread.dylib       0x00007fff97872899 _pthread_body + 138
                          7   libsystem_pthread.dylib       0x00007fff9787272a _pthread_start + 137
                          8   libsystem_pthread.dylib       0x00007fff97876fc9 thread_start + 13
                          Thread 3:
                          0   libsystem_kernel.dylib         0x00007fff8af44e6a __workq_kernreturn + 10
                          1   libsystem_pthread.dylib       0x00007fff97873f08 _pthread_wqthread + 330
                          2   libsystem_pthread.dylib       0x00007fff97876fb9 start_wqthread + 13
                          Thread 4:
                          0   libsystem_kernel.dylib         0x00007fff8af4534a fstat$INODE64 + 10
                          1   IMSLib.dylib                   0x0000000119a3d2dd 0x1199c0000 + 512733
                          2   IMSLib.dylib                   0x00000001199f3616 0x1199c0000 + 210454
                          3   IMSLib.dylib                   0x00000001199f39ef 0x1199c0000 + 211439
                          4   IMSLib.dylib                   0x0000000119a1f3c8 0x1199c0000 + 390088
                          5   IMSLib.dylib                   0x00000001199f328d 0x1199c0000 + 209549
                          6   IMSLib.dylib                   0x0000000119a2ebdf 0x1199c0000 + 453599
                          7   IMSLib.dylib                   0x00000001199f64f0 0x1199c0000 + 222448
                          8   IMSLib.dylib                   0x00000001199f894b 0x1199c0000 + 231755
                          9   IMSLib.dylib                   0x0000000119a3fc0e 0x1199c0000 + 523278
                          10  IMSLib.dylib                   0x0000000119a40a0b 0x1199c0000 + 526859
                          11  IMSLib.dylib                   0x00000001199ea34e 0x1199c0000 + 172878
                          12  IMSLib.dylib                   0x00000001199ded11 0x1199c0000 + 126225
                          13  IMSLib.dylib                   0x00000001199d37ef 0x1199c0000 + 79855
                          14  IMSLib.dylib                   0x00000001199e3851 0x1199c0000 + 145489
                          15  IMSLib.dylib                   0x00000001199da4f1 0x1199c0000 + 107761
                          16  IMSLib.dylib                   0x00000001199cce14 0x1199c0000 + 52756
                          17  libsystem_pthread.dylib       0x00007fff97872899 _pthread_body + 138
                          18  libsystem_pthread.dylib       0x00007fff9787272a _pthread_start + 137
                          19  libsystem_pthread.dylib       0x00007fff97876fc9 thread_start + 13
                          Thread 5:
                          Thread 6:: com.apple.NSURLConnectionLoader
                          0   libsystem_kernel.dylib         0x00007fff8af40a1a mach_msg_trap + 10
                          1   libsystem_kernel.dylib         0x00007fff8af3fd18 mach_msg + 64
                          2   com.apple.CoreFoundation       0x00007fff8d1b0315 __CFRunLoopServiceMachPort + 181
                          3   com.apple.CoreFoundation       0x00007fff8d1af939 __CFRunLoopRun + 1161
                          4   com.apple.CoreFoundation       0x00007fff8d1af275 CFRunLoopRunSpecific + 309
                          5   com.apple.Foundation           0x00007fff975a1907 +[NSURLConnection(Loader) _resourceLoadLoop:] + 348
                          6   com.apple.Foundation           0x00007fff975a170b __NSThread__main__ + 1318
                          Thread 7:
                          Thread 8 Crashed:
                          0   libsystem_kernel.dylib         0x00007fff8af44866 __pthread_kill + 10
                          1   libsystem_pthread.dylib       0x00007fff9787335c pthread_kill + 92
                          2   libsystem_c.dylib             0x00007fff8fa39bba abort + 125
                          3   libsystem_malloc.dylib         0x00007fff919a5bf9 nanozone_error + 486
                          4   libsystem_malloc.dylib         0x00007fff919a5dbb _nano_malloc_check_clear + 445
                          5   libsystem_malloc.dylib         0x00007fff919a46c4 nano_malloc + 35
                          6   libsystem_malloc.dylib         0x00007fff919a287c malloc_zone_malloc + 71
                          7   libsystem_malloc.dylib         0x00007fff919a3290 malloc + 42
                          8   libc++abi.dylib               0x00007fff90c5853e operator new(unsigned long) + 30
                          9   libstdc++.6.dylib             0x00007fff8f47d0be std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator<char> const&) + 102
                          10  libstdc++.6.dylib             0x00007fff8f47d00d std::string::_Rep::_M_clone(std::allocator<char> const&, unsigned long) + 35
                          11  libstdc++.6.dylib             0x00007fff8f47dae6 std::string::reserve(unsigned long) + 62
                          12  libstdc++.6.dylib             0x00007fff8f47de3b std::string::append(char const*, unsigned long) + 101
                          13  IMSLib.dylib                   0x0000000119a414fb 0x1199c0000 + 529659
                          14  IMSLib.dylib                   0x0000000119a416a2 0x1199c0000 + 530082
                          15  IMSLib.dylib                   0x00000001199ea192 0x1199c0000 + 172434
                          16  IMSLib.dylib                   0x00000001199ded11 0x1199c0000 + 126225
                          17  IMSLib.dylib                   0x00000001199d37ef 0x1199c0000 + 79855
                          18  IMSLib.dylib                   0x00000001199e3851 0x1199c0000 + 145489
                          19  IMSLib.dylib                   0x00000001199da4f1 0x1199c0000 + 107761
                          20  IMSLib.dylib                   0x00000001199cce14 0x1199c0000 + 52756
                          21  libsystem_pthread.dylib       0x00007fff97872899 _pthread_body + 138
                          22  libsystem_pthread.dylib       0x00007fff9787272a _pthread_start + 137
                          23  libsystem_pthread.dylib       0x00007fff97876fc9 thread_start + 13
                          Thread 9:: com.apple.CFSocket.private
                          0   libsystem_kernel.dylib         0x00007fff8af449aa __select + 10
                          1   com.apple.CoreFoundation       0x00007fff8d1fbd43 __CFSocketManager + 867
                          2   libsystem_pthread.dylib       0x00007fff97872899 _pthread_body + 138
                          3   libsystem_pthread.dylib       0x00007fff9787272a _pthread_start + 137
                          4   libsystem_pthread.dylib       0x00007fff97876fc9 thread_start + 13
                          Thread 10:
                          Thread 8 crashed with X86 Thread State (64-bit):
                            rax: 0x0000000000000000  rbx: 0x0000000119dfa000  rcx: 0x0000000119df8958  rdx: 0x0000000000000000
                            rdi: 0x0000000000007c13  rsi: 0x0000000000000006  rbp: 0x0000000119df8980  rsp: 0x0000000119df8958
                             r8: 0x0000000000000000   r9: 0x0000000000000000  r10: 0x0000000008000000  r11: 0x0000000000000206
                            r12: 0x0000000104bf7000  r13: 0x00006180002737c0  r14: 0x0000000000000006  r15: 0x0000000000000000
                            rip: 0x00007fff8af44866  rfl: 0x0000000000000206  cr2: 0x00000001083c9000
                          Logical CPU:     0
                          Error Code:      0x02000148
                          Trap Number:     133
                          Binary Images:
                                 0x100000000 -        0x100005fff +com.adobe.InDesign (9.2.0.69 - 9200) <B7C09BD6-74AF-323E-8D22-D5E1F7965643> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
                                 0x10000c000 -        0x10000eff7 +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <612870BE-869E-3165-9714-55F900A66BCC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
                                 0x100014000 -        0x10001cfff +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <65BFDA83-4121-3D12-9BBE-9F4FF1DB3D6A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
                                 0x100025000 -        0x10002ffff +ASLSupportLib.dylib (1) <1039F962-C495-36E4-B868-3DA5C43E3EBF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ASLSupportLib.dylib
                                 0x100037000 -        0x10013aff7 +DV_WidgetBinLib.dylib (1) <57491245-3B90-3D4B-B4B6-4441EE325E3C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/DV_WidgetBinLib.dylib
                                 0x1001d5000 -        0x10021aff7 +TextPanelLib.dylib (1) <4B30610F-C637-3910-A413-C40325795CAD> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/TextPanelLib.dylib
                                 0x100237000 -        0x100398fff +WidgetBinLib.dylib (1) <50EE77D3-591B-306F-9D62-2026938837EE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/WidgetBinLib.dylib
                                 0x10044a000 -        0x100616fff +com.adobe.owl (AdobeOwl version 5.0.24 - 5.0.24) <1C99AA07-E73F-370B-82FA-01C1C4AAF97D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                 0x100659000 -        0x10089dfff +com.adobe.dvacore.framework (7.0.849324 - 7.0.849324.0) <08EB97C1-03E5-3C1B-B154-C886807BC6F1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                 0x100964000 -        0x100df1ff7 +com.adobe.dvaui.framework (7.0.849324 - 7.0.849324.0) <25942AAC-0437-303F-9663-B17113468EBB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                                 0x101089000 -        0x101089fff +com.adobe.InDesign.InDesignModel (9.0 - 0) <7DCCCD9E-8ECB-330B-84AF-4F090F82BBBA> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
                                 0x10108e000 -        0x10109cfff +com.adobe.boost_threads.framework (7.0.847203 - 7.0.847203.0) <A0AE19A9-2B8E-310A-8AC1-0E2E026E7A40> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                 0x1010b2000 -        0x1010b8ff7 +com.adobe.boost_date_time.framework (7.0.847203 - 7.0.847203.0) <F30F59C3-41C0-3DB1-899A-E2491EA25263> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                 0x1010c7000 -        0x101536ff7 +PublicLib.dylib (1) <1B305F6E-A0D3-39A3-91FE-B878D638B7A7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/PublicLib.dylib
                                 0x101681000 -        0x10168bfff +PMRuntime.dylib (1) <0164EA5E-E56E-332F-901A-5E514833C38F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/PMRuntime.dylib
                                 0x101694000 -        0x1016abff7 +com.adobe.AFL (AdobeAFL 1.5.0 - 1.5) <1C46F2BE-2E4D-3E25-ACDF-85E2962B92DF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
                                 0x1016ba000 -        0x1019cbff7 +com.adobe.CoolType (AdobeCoolType 5.15.00.31977 - 5.15.00.31977) <42323DBD-3A6D-3C41-A2C1-2B944789D8A9> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                 0x101a13000 -        0x101a30fff +com.adobe.BIB (AdobeBIB 1.2.03.31977 - 1.2.03.31977) <A69D3AA0-9248-3B77-991B-89B2B7FE46BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                 0x101a38000 -        0x101b7efff +com.adobe.ACE (AdobeACE 2.20.02.31977 - 2.20.02.31977) <3A212837-B075-34C0-96E9-5A4019C9DFEE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                 0x101b92000 -        0x102163fff +com.adobe.AGM (AdobeAGM 4.30.29.31977 - 4.30.29.31977) <BFFDBF0E-28EF-3720-93BE-293618541D26> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                 0x102200000 -        0x10223dfff +com.adobe.ARE (AdobeARE 1.5.02.31977 - 1.5.02.31977) <73174C59-1DDC-3416-A0AD-4D70930ABA60> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                                 0x102245000 -        0x10226bfff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <FA20BCA0-05BF-35ED-95B7-5775B8310D12> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                 0x102273000 -        0x10280cfff +com.adobe.MPS (AdobeMPS 5.8.1.31977 - 5.8.1.31977) <96C4D283-326B-3E50-B555-534492C6AA95> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                 0x102889000 -        0x1028a7fff +com.adobe.dvaflashview.framework (7.0.849324 - 7.0.849324.0) <46FFD5B4-2182-3CC3-A258-486E585A5B2D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                                 0x1028bf000 -        0x1028c3ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                 0x1028ca000 -        0x10298cfff +com.adobe.exo.framework (7.0.849324 - 7.0.849324.0) <AF41BB10-6BB7-3645-9F60-AE77E54F04F1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
                                 0x102a2a000 -        0x102ad8fff +com.adobe.dvaworkspace.framework (7.0.849324 - 7.0.849324.0) <97F274A8-A56B-3F3A-AAA7-66B9FBEFEBF1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                                 0x102b5b000 -        0x1031fafff +com.adobe.PlugPlugOwl (4.2.0.36 - 4.2.0.36) <D6EC53B4-E257-3698-8EA8-24D4E3D98EBD> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
                                 0x1034ef000 -        0x10351bff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/libtbb.dylib
                                 0x103536000 -        0x103555fe7 +libtbbmalloc.dylib (0) <6887ED68-67ED-3748-82DA-B39A3EB210BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/libtbbmalloc.dylib
                                 0x10357a000 -        0x1042bffff +com.adobe.ICUData (4.0 - 3.61) <01D90725-4B10-312C-9546-9C0CCCA1B7BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
                                 0x1042d3000 -        0x104404ff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <CD4AD967-00CD-3979-8F82-1166E2058FA6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40.0 .dylib
                                 0x104458000 -        0x10454eff7 +com.adobe.ICUUnicode (4.0 - 3.61) <2352E6C8-3431-3A99-92B9-382E85A018AC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
                                 0x104586000 -        0x1046b4fff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                 0x10470f000 -        0x1047fffff +com.adobe.amtlib (7.0.0.247 - 7.0.0.247) <48D8FFDB-DFEA-310D-BAE3-DFD8D05B0160> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                 0x104812000 -        0x104814fff +com.adobe.AdobeCrashReporter (7.0 - 7.1) <B68D0D42-8DEB-3F22-BD17-981AC060E9D7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                 0x10481a000 -        0x1048d1ff7 +com.adobe.boost_regex.framework (7.0.847203 - 7.0.847203.0) <F1C659D9-D3E8-3ACE-8368-9161529A6A66> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                                 0x10493b000 -        0x1049aaff7 +com.adobe.adobe_caps (adobe_caps 7.0.0.21 - 7.0.0.21) <CE3C6356-9EE2-3B88-8261-8612A0743F56> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                                 0x1049b5000 -        0x1049c0fff +com.adobe.boost_signals.framework (7.0.847203 - 7.0.847203.0) <E0B3BB47-4294-3D65-8979-29B2D6C5DD2E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                 0x1049cf000 -        0x1049d3fff +com.adobe.boost_system.framework (7.0.847203 - 7.0.847203.0) <70F73B9F-8416-37BF-9294-086AE475B743> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                 0x1049d9000 -        0x104a7afff +com.adobe.ICUConverter (4.0 - 3.61) <46764474-111C-3B13-AF62-002B71877405> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
                                 0x104a9a000 -        0x104afcfff +DataBaseLib.dylib (1) <670C9B64-DD9A-3B32-BDA9-22D6EA26A5EF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/DataBaseLib.dylib
                                 0x104b10000 -        0x104b7dfff +ObjectModelLib.dylib (1) <38EFA738-542E-32EB-A5AA-45380C5CCAAF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ObjectModelLib.dylib
                                 0x104b9a000 -        0x104bbefff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.30807 - 3.8.0.30807) <16FF5E16-19E0-3CE1-A68E-27567234429F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
                                 0x108348000 -        0x108386fff +com.adobe.InDesign.Dictionary Editor Dialog (9.2.0.69 - 0) <EC06E951-7EDF-306A-85E2-B52805F8110C> /Applications/Adobe InDesign CC/*/Dictionary Editor Dialog
                                 0x1083a7000 -        0x1083b6ff7 +com.adobe.InDesign.DTTransform (9.2.0.69 - 0) <417A914C-BEA9-3AF6-94BC-158C93DCDC56> /Applications/Adobe InDesign CC/*/DTTransform
                                 0x10846c000 -        0x108479ff7 +com.adobe.InDesign.Text Color Panel (9.2.0.69 - 0) <B9722BDD-B3B2-3B6B-90EC-D7B52D54C678> /Applications/Adobe InDesign CC/*/Text Color Panel
                                 0x108482000 -        0x108496ff7 +com.adobe.InDesign.Story Panel (9.2.0.69 - 0) <989D8312-C513-36B9-9A2A-A161EC806905> /Applications/Adobe InDesign CC/*/Story Panel
                                 0x1084a5000 -        0x1084afff7 +com.adobe.InDesign.Span Columns Panel (9.2.0.69 - 0) <15F063E0-7874-30AE-841C-C10A12CF8B5E> /Applications/Adobe InDesign CC/*/Span Columns Panel
                                 0x1084b8000 -        0x1084c9ff7 +com.adobe.InDesign.SING (9.2.0.69 - 0) <3CC6846B-D663-31F2-BAB9-03BCAD89606E> /Applications/Adobe InDesign CC/*/SING
                                 0x1084d3000 -        0x1084ddfff +com.adobe.InDesign.Justification Panel (9.2.0.69 - 0) <4F940073-AAF8-3FDF-87FA-04A8DC87679D> /Applications/Adobe InDesign CC/*/Justification Panel
                                 0x109caa000 -        0x109cabff7 +com.adobe.InDesign.Metadata Database Filter (9.2.0.69 - 0) <3BE1DF86-81E8-359D-A40E-84EC7A016E16> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
                                 0x109cb0000 -        0x109ccaff7 +com.adobe.InDesign.IME (9.2.0.69 - 0) <905334C5-8BF8-3958-8216-720BDB4D3A1F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
                                 0x109cda000 -        0x109cddfff +com.adobe.InDesign.Global Preferences Panel (9.2.0.69 - 0) <3B261D67-E6B5-32E3-AC7E-AFCCDC9B75CB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
                                 0x109ce3000 -        0x109cedfff +com.adobe.InDesign.Workgroup Client UI (9.2.0.69 - 0) <5025F9EC-7C4C-377B-92F0-EC208F75B671> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
                                 0x10aa1f000 -        0x10aa23fff  com.apple.agl (3.2.3 - AGL-3.2.3) <1B85306F-D2BF-3FE3-9915-165237B491EB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                 0x10af61000 -        0x10af9ffff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 7.0.1.102 - 7.0.1.102) <75ADE364-1107-3DA7-84A2-26C6874EB881> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
                                 0x10afdc000 -        0x10afeefff +com.adobe.boost_filesystem.framework (7.0.847203 - 7.0.847203.0) <B0F56E9F-BAAB-34C5-93C4-C713203AB0DF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                                 0x10c6ee000 -        0x10c6f0ff7  com.apple.textencoding.unicode (2.6 - 2.6) <0EEF0283-1ACA-3147-89B4-B4E014BFEC52> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                 0x10c6f5000 -        0x10c6f9fff +com.adobe.InDesign.Help (9.2.0.69 - 0) <09CFAB79-828F-39A9-8E6C-634999CF4EC8> /Applications/Adobe InDesign CC/*/Help
                                 0x10d632000 -        0x10d7f8ff7 +com.adobe.InDesign.AppFramework (9.2.0.69 - 0) <D84FAD4D-B653-3EB4-8FDA-7264A51F7359> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
                                 0x10e0cf000 -        0x10e255ff7 +com.adobe.InDesign.SettingsInCloud (9.2.0.69 - 0) <EC5B37FA-9195-3243-9D62-C6A5FB8E394A> /Applications/Adobe InDesign CC/*/SettingsInCloud
                                 0x10e640000 -        0x10e7feff7 +com.adobe.InDesign.Text Walker (9.2.0.69 - 0) <BA84432B-6B10-3684-982F-856AB2248204> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
                                 0x10e856000 -        0x10e8a7fff +com.adobe.InDesign.Linguistics (9.2.0.69 - 0) <13A4BC6D-4C68-3884-9059-5837B952EC17> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
                                 0x10e8c1000 -        0x10e927fff +com.adobe.InDesign.Text Panel (9.2.0.69 - 0) <70BA1FF5-A8FD-3D59-976A-5AE782CB79ED> /Applications/Adobe InDesign CC/*/Text Panel
                                 0x10e94a000 -        0x10e996ff7 +com.adobe.InDesign.Spelling Panel (9.2.0.69 - 0) <B208BBCC-1AAB-354C-9CA6-44C6B5D35946> /Applications/Adobe InDesign CC/*/Spelling Panel
                                 0x10e9b0000 -        0x10ec14fff +com.adobe.InDesign.Package and Preflight (9.2.0.69 - 0) <6590908A-0A78-32F4-A455-ABBEC9D97B5E> /Applications/Adobe InDesign CC/*/Package and Preflight
                                 0x10ec5a000 -        0x10ecc7ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 21 - 79.154911) <E8E31BC1-F7BC-3018-8CF8-AC3C7B2DCEA2> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                 0x10ecd3000 -        0x10eda5fff +com.adobe.InDesign.Text Editor (9.2.0.69 - 0) <C8F82611-461D-3339-A65E-51190B515F9F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
                                 0x10edd5000 -        0x10efe3fff +com.adobe.InDesign.Layout UI (9.2.0.69 - 0) <5BC0A7D6-7A69-346C-B5A1-4F4AF2AC5F01> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
                                 0x10f043000 -        0x10f0b3fff +com.adobe.InDesign.Import Export UI (9.2.0.69 - 0) <FFA896AE-BAF9-30EC-A788-25AD02061296> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
                                 0x10f0da000 -        0x10f1e8fff +com.adobe.InDesign.Hyperlinks (9.2.0.69 - 0) <BF029BB8-6578-303F-A983-9ADEE43AB7A4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
                                 0x10f213000 -        0x10f2b7fff +com.adobe.InDesign.Master Page (9.2.0.69 - 0) <557BD678-3F9D-3A4F-ABDA-8A1DD7D41AF6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
                                 0x10f2d1000 -        0x10f2fffff +com.adobe.InDesign.Utilities (9.2.0.69 - 0) <9F7A613A-54DB-3604-B811-FCE0BC56F416> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
                                 0x10f31a000 -        0x10f417fff +com.adobe.InDesign.Color Management (9.2.0.69 - 0) <33023C59-D4C5-3BF2-8C42-54BD6E50E651> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
                                 0x10f444000 -        0x10f659ff7 +com.adobe.InDesign.Application UI (9.2.0.69 - 0) <2235307F-D211-397C-BAA7-34028F1C4F56> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
                                 0x10f6f0000 -        0x10fa0eff7 +com.adobe.dvaadameve.framework (7.0.849324 - 7.0.849324.0) <FF303DE3-2F53-3AA7-94E7-93B46DB28918> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                                 0x10fce4000 -        0x10fd33fff +com.adobe.headlights.LogSessionFramework (2.1.2.1785) <160BF2F9-B418-31C5-866F-6FADA1B720ED> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                 0x10fd59000 -        0x10fe17fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.5 - 4.5.5.31983) <7764EE73-651A-3D8A-9B0F-A25DF57D79E1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                                 0x10fe3f000 -        0x10feeaff7 +com.adobe.AdobeScCore (ScCore 4.5.5 - 4.5.5.31983) <0E9111E5-ECBF-3C1C-82DB-9A945F1A573C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                 0x10ff14000 -        0x110064fff +com.adobe.dvascriptui.framework (7.0.849324 - 7.0.849324.0) <EC31CE70-34C1-31E0-A68D-F49D99ADA604> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
                                 0x110186000 -        0x110366fff +com.adobe.InDesign.Document Framework (9.2.0.69 - 0) <ABC1E3A8-3AC3-3199-B572-B734998B696E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
                                 0x1106d2000 -        0x110813fff +com.adobe.InDesign.SangamServicer-Mapper (9.2.0.69 - 0) <F2E5BD34-3091-317F-88A8-0B6090F262E0> /Applications/Adobe InDesign CC/*/SangamServicer-Mapper
                                 0x110837000 -        0x1108a0fff +com.adobe.AdobeSangam (AdobeSangam 5.65.0.31977 - 5.65.0.31977) <81A4C7F3-E791-3AD1-A44B-CF5BB5B6A545> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
                                 0x1108ee000 -        0x11091aff7 +com.adobe.Reader for DOCX (Reader for DOCX 5.65.0.31977 - 5.65.0.31977) <C21B199B-542B-34CD-8F0E-F38D970D88BD> /Applications/Adobe InDesign CC/*/Reader for DOCX
                                 0x110925000 -        0x110a23ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.30807 - 3.8.0.30807) <DF0EC9F6-D499-39B8-B2F4-CAF4F742D702> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                 0x110a39000 -        0x110b16fff +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.30807 - 3.8.0.30807) <6299FB87-471B-3EA2-9E02-6DEA293FA533> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
                                 0x110b2b000 -        0x110b96ff7 +com.adobe.AdobeSangamML (AdobeSangamML 5.65.0.31977 - 5.65.0.31977) <BF6D92E9-AF42-3B9F-BBDD-FBCDE605C4BE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
                                 0x110bba000 -        0x110c18ff7 +com.adobe.Reader for Excel (Reader for Excel 5.65.0.31977 - 5.65.0.31977) <628DA00F-210B-3856-89F3-66393386E801> /Applications/Adobe InDesign CC/*/Reader for Excel
                                 0x110c2b000 -        0x110c3ffff +com.adobe.AdobeSFL (AdobeSFL 1.1.0.31977 - 1.1.0.31977) <A1874DA3-6F12-333D-8941-ED3A08A1E265> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
                                 0x110c47000 -        0x110d3cfff +com.adobe.Reader for Quark (Reader for Quark 5.65.0.31977 - 5.65.0.31977) <7877BBF5-B31A-3CA9-9E8E-3FDFB174F261> /Applications/Adobe InDesign CC/*/Reader for Quark
                                 0x110d56000 -        0x110db1ff7 +com.adobe.Reader for RTF (Reader for RTF 5.65.0.31977 - 5.65.0.31977) <3ACB0F8E-0B51-3E5C-B924-A31D1D6606F6> /Applications/Adobe InDesign CC/*/Reader for RTF
                                 0x110dca000 -        0x110e38ff7 +com.adobe.Reader for Word (Reader for Word 5.65.0.31977 - 5.65.0.31977) <27531852-B602-3785-94C0-3B316DBEC69C> /Applications/Adobe InDesign CC/*/Reader for Word
                                 0x110e4d000 -        0x110eb3fff +com.adobe.Reader for XLSX (Reader for XLSX 5.65.0.31977 - 5.65.0.31977) <D896568B-FB6A-3036-91FC-A1DF0FA820DF> /Applications/Adobe InDesign CC/*/Reader for XLSX
                                 0x110ecd000 -        0x110ed5ff7 +com.adobe.ZTextReader (ZTextReader 5.65.0.31977 - 5.65.0.31977) <28B268EF-A3AD-3933-B4DC-247428D3A88D> /Applications/Adobe InDesign CC/*/ZTextReader
                                 0x110f5c000 -        0x110fcbfff +com.adobe.InDesign.XMLParser (9.2.0.69 - 0) <745F02C0-071B-3979-B284-391BA59D9CF5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
                                 0x110fe1000 -        0x111204fff +com.adobe.InDesign.XML (9.2.0.69 - 0) <97314A64-BB21-3965-B9D3-F4C219C3DCDF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
                                 0x11124e000 -        0x11127bfff +com.adobe.InDesign.WorldReady (9.2.0.69 - 0) <787871A9-77D2-3095-8930-4F140D091F0A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
                                 0x11128b000 -        0x1112c8ff7 +com.adobe.InDesign.Workgroup (9.2.0.69 - 0) <FEA65E81-92F4-36EE-940C-3C7BD07DB7F4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
                                 0x1112d8000 -        0x1112fafff +com.adobe.InDesign.Workgroup Client (9.2.0.69 - 0) <2447A61F-74CA-38D1-9444-22A25D2DEE98> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
                                 0x111308000 -        0x111416fff +com.adobe.InDesign.Widgets (9.2.0.69 - 0) <A9FB91A0-7CDB-3025-B6AC-D53BA8BBEB1E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
                                 0x11147c000 -        0x1115c0ff7 +com.adobe.InDesign.Transparency (9.2.0.69 - 0) <636FD3CD-06FE-3D25-A252-368317D80C66> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
                                 0x1115eb000 -        0x11259ffef +com.adobe.psl (AdobePSL 14.0.0.31988 - 14.0.0.31988) <1EBD1547-F7B1-379D-8F50-FB49C7E01A58> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                                 0x112762000 -        0x11281bff7 +com.adobe.JP2K (1.2.2 - 1.2.2.31977) <8BD41D6E-B8A2-36FA-B855-7CF02E856A08> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                                 0x112842000 -        0x1128a4fff +com.adobe.InDesign.TOC (9.2.0.69 - 0) <99A6C9FF-2F20-3475-A9CF-24C7B0F63CF3> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
                                 0x1128b8000 -        0x112ebbff7 +com.adobe.InDesign.Text (9.2.0.69 - 0) <4216A99F-7F58-3E9B-A37E-8178A6ED812A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
                                 0x112f59000 -        0x112fcfff7 +com.adobe.InDesign.Text Wrap (9.2.0.69 - 0) <8B65C672-BB4E-3F46-A7C5-6B2D0331C0F5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
                                 0x112fe8000 -        0x11300cfff +com.adobe.InDesign.Text Wrap Path (9.2.0.69 - 0) <D826BA05-20A8-367F-9414-573944D46303> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
                                 0x113015000 -        0x11302bff7 +com.adobe.InDesign.Text Editor Model (9.2.0.69 - 0) <C997B3C0-98C6-34A5-89E0-DBD7FB071AD6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
                                 0x113036000 -        0x11308cff7 +com.adobe.InDesign.Text Attributes (9.2.0.69 - 0) <F90E2E25-38B2-3F12-8902-D5A56D6AD919> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
                                 0x1130a7000 -        0x113104ff7 +com.adobe.InDesign.TableStyles (9.2.0.69 - 0) <4D83BFF9-CAF4-34EF-BEAE-86E2D8A1D14F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
                                 0x113117000 -        0x113349fff +com.adobe.InDesign.Table Model (9.2.0.69 - 0) <829471A3-999A-3B01-BD5A-B2ADC2F2972A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
                                 0x113385000 -        0x1133d8ff7 +com.adobe.InDesign.Image Filters (9.2.0.69 - 0) <F3DF9DCA-6073-3DF8-89EB-18F8D1DB8902> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
                                 0x1133e4000 -        0x11346ffff +com.adobe.InDesign.SVGExport (9.2.0.69 - 0) <E86D7C69-48CA-362B-B3A0-CC2C8F4B31B5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
                                 0x113489000 -        0x113547fff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
                                 0x11356a000 -        0x11360efff +com.adobe.InDesign.Support for JavaScript (9.2.0.69 - 0) <EC1C0215-E510-3D0F-B692-E2F8853811D9> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
                                 0x113639000 -        0x113690ff7 +com.adobe.InDesign.Support for AppleScript (9.2.0.69 - 0) <7D7706C3-B3C9-3B96-8473-CAD03A053148> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
                                 0x1136a6000 -        0x1137a8ff7 +com.adobe.InDesign.Graphics (9.2.0.69 - 0) <FCBDB8E7-46E8-3987-9BCB-0E3177F00F11> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
                                 0x1137cc000 -        0x113827ff7 +com.adobe.InDesign.Stroke and Fill (9.2.0.69 - 0) <72D3DE23-CFCC-3821-80AE-0908DB5768F5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
                                 0x11383f000 -        0x113980ff7 +com.adobe.InDesign.Spread (9.2.0.69 - 0) <AF10A69E-0D98-3E25-ABE5-CC310529098A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
                                 0x1139b2000 -        0x113a14fff +com.adobe.InDesign.Spread UI (9.2.0.69 - 0) <B7A3AE3F-DC65-34F6-B601-1780AF9220D9> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
                                 0x113a30000 -        0x113a7afff +com.adobe.InDesign.Spline (9.2.0.69 - 0) <53E6EF37-C070-39BE-BB18-2703B2041EC6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
                                 0x113a92000 -        0x113adaff7 +com.adobe.InDesign.Spline UI (9.2.0.69 - 0) <9FC93D14-6D7C-32EE-BF90-3756FEA25FEE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
                                 0x113af6000 -        0x113b09ff7 +com.adobe.InDesign.Spelling Service (9.2.0.69 - 0) <1E6AAFFE-ACCA-3E0B-AA63-37A767CC336E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
                                 0x113b18000 -        0x113b26fff +com.adobe.InDesign.Sound (9.2.0.69 - 0) <43D68A27-E17F-3E9D-A02D-EB3230178339> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
                                 0x113b32000 -        0x113bbcfff +com.adobe.InDesign.SharedContent (9.2.0.69 - 0) <3863D336-3468-35E6-8298-3C1BFB37FBA5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
                                 0x113bdd000 -        0x113c05fff +com.adobe.InDesign.Sections (9.2.0.69 - 0) <4DB2B4F0-124A-36F1-B1A3-9BFA36BB2FCF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
                                 0x113c16000 -        0x113cc4fff +com.adobe.InDesign.Scripting (9.2.0.69 - 0) <01395410-7F18-323A-BF92-4FAC6F3ECCD5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
                                 0x113ce3000 -        0x113d0dff7 +com.adobe.InDesign.Rulers (9.2.0.69 - 0) <C21FAD98-14EA-3E6F-9D58-7DED5B0EFB76> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
                                 0x113d20000 -        0x113eb5fff +com.adobe.InDesign.Print (9.2.0.69 - 0) <4E53767E-8497-32D1-B922-735E610640E2> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
                                 0x113ee2000 -        0x113f21ff7 +com.adobe.InDesign.PNG Import Filter (9.2.0.69 - 0) <3EA87A99-3FBF-38E5-BE00-896001E5AD91> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
                                 0x113f31000 -        0x113f6afff +com.adobe.InDesign.Photoshop Import Filter (9.2.0.69 - 0) <B62B89C7-29F4-3058-BBD9-62BAB193B133> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
                                 0x113f7a000 -        0x113fe0fff +com.adobe.InDesign.Book (9.2.0.69 - 0) <A57C7841-5282-3A46-8202-CAB3C70DFBD0> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
                                 0x113ff7000 -        0x11410dff7 +com.adobe.InDesign.Image (9.2.0.69 - 0) <E026A24C-EF82-33E8-95FD-463A23618CB2> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
                                 0x114139000 -        0x114145ff7 +com.adobe.InDesign.Group (9.2.0.69 - 0) <8DF66586-0FC5-3EA5-8F0D-6083387F0697> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
                                 0x114152000 -        0x114294fe7 +com.adobe.InDesign.EPS Page Item (9.2.0.69 - 0) <CFD4D636-06B2-3969-91FA-ED68F0873111> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
                                 0x1142d3000 -        0x11451ffff +com.adobe.InDesign.PDF (9.2.0.69 - 0) <36EED87F-F233-3B82-83C4-57584FEBE296> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
                                 0x114561000 -        0x114665fff +com.adobe.PDFPort (AdobePDFPort 2.1.0.31977 - 2.1.0.31977) <83787D51-C878-3CFF-A3A2-F2107F7BB920> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                                 0x114678000 -        0x1146a1ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                                 0x1146ab000 -        0x114917ff7 +com.adobe.InDesign.Generic Page Item (9.2.0.69 - 0) <F0DECCE6-EAF5-30C0-8FB0-48FA56CB3503> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
                                 0x114963000 -        0x1149a7fff +com.adobe.InDesign.Path Type (9.2.0.69 - 0) <32D8F2D5-AF06-375A-85ED-C4E42D3B790B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
                                 0x1149c0000 -        0x1149caff7 +PathTypeLib.dylib (1) <A6E44FB4-61D6-3729-B3DD-A4D22EEC73B3> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/PathTypeLib.dylib
                                 0x1149d3000 -        0x114a88fff +com.adobe.InDesign.Paragraph Composer (9.2.0.69 - 0) <EEE3D51D-AF42-30AF-A8BA-DE663DC95888> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
                                 0x114a99000 -        0x114adafff +com.adobe.InDesign.Open Place (9.2.0.69 - 0) <6CBC4B8F-3B3D-3B14-9512-6808497AC68A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
                                 0x114aee000 -        0x114b06ff7 +com.adobe.InDesign.Movie (9.2.0.69 - 0) <FD78448B-F572-32C2-9580-4A0681AC69EE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
                                 0x114b15000 -        0x114ba0fff +com.adobe.InDesign.Metadata (9.2.0.69 - 0) <361ED9DD-BAD7-35E5-AFE5-3176BAD1C0FC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
                                 0x114bbd000 -        0x114ccafff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 81 - 79.154911) <38348CA8-7905-3AA4-AA00-95A6D912C491> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                                 0x114d00000 -        0x114d5cff7 +com.adobe.InDesign.Media (9.2.0.69 - 0) <560CE1DB-99AF-389F-8BC2-37D5F83C110F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
                                 0x114d72000 -        0x114eacfff +com.adobe.InDesign.Links (9.2.0.69 - 0) <1BCD7856-3DD0-3C58-AF61-0E430CF5EFBC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
                                 0x114ee1000 -        0x114f0afff +com.adobe.InDesign.Layout (9.2.0.69 - 0) <98815961-6446-3917-B266-7E3DB625B782> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
                                 0x114f19000 -        0x114f46fff +com.adobe.InDesign.Layer (9.2.0.69 - 0) <94604B73-0E52-30CB-9CC0-805F5B138FE4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
                                 0x114f59000 -        0x115029fff +com.adobe.InDesign.INXCore (9.2.0.69 - 0) <FCF49243-A7FD-3993-A242-7ECAB3971857> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
                                 0x115051000 -        0x115157ff7 +com.adobe.InDesign.Indexing (9.2.0.69 - 0) <CD23A88C-DBB2-3F46-91CC-31B334E29762> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
                                 0x115178000 -        0x115210ff7 +com.adobe.InDesign.InCopyWorkflow (9.2.0.69 - 0) <D6C76680-B980-3D34-A873-C8883C2779F6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
                                 0x115236000 -        0x115253fff +com.adobe.InDesign.InCopySharedUI (9.2.0.69 - 0) <0A19AFFD-DB77-334D-B8D3-60CB775F517D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
                                 0x115263000 -        0x115366fff +com.adobe.InDesign.InCopyShared (9.2.0.69 - 0) <5BDCF61D-711B-3F05-A3D4-79E7ECD75C93> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
                                 0x115392000 -        0x115464ff7 +com.adobe.InDesign.HTMLPGT (9.2.0.69 - 0) <DE7D940F-9651-3A94-B364-588061627B2C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
                                 0x1154c8000 -        0x1154e9ff7 +com.adobe.InDesign.Guides (9.2.0.69 - 0) <0431FB5F-AA6B-33A6-BDFE-7ABEC7445572> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
                                 0x1154fb000 -        0x11556bfff +com.adobe.InDesign.Gradient Fill (9.2.0.69 - 0) <FFE95F52-F173-3B84-A96C-3340E06FFE72> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
                                 0x115587000 -        0x115595fff +com.adobe.InDesign.GenericSettings (9.2.0.69 - 0) <265C32A6-C9D4-3571-93BB-BF1A64FE3001> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
                                 0x11559f000 -        0x1156eaff7 +com.adobe.InDesign.GalleyUI (9.2.0.69 - 0) <89C9D915-C94D-3548-92AE-4017AC973AA5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
                                 0x115718000 -        0x115779ff7 +com.adobe.InDesign.Galley (9.2.0.69 - 0) <970A6D55-9CDF-3DE7-939D-372B0907F4BC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
                                 0x11578e000 -        0x115865ff7 +com.adobe.InDesign.FormField (9.2.0.69 - 0) <8D813A0F-DBD0-31EA-93DA-102D366DF99C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
                                 0x11588a000 -        0x1159d9ff7 +com.adobe.InDesign.Font Manager (9.2.0.69 - 0) <8DEF8575-863F-396B-9247-683B45C28643> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
                                 0x115a01000 -        0x115d61fff +com.adobe.InDesign.Dynamic Documents (9.2.0.69 - 0) <CA3478E3-0A3A-3595-8804-2DFDD485E3B6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
                                 0x115da9000 -        0x115ea0fff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.31977 - 2.1.0.31977) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
                                 0x115ebd000 -        0x11609aff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
                                 0x1160be000 -        0x11610eff7 +com.adobe.InDesign.DV_Widgets (9.2.0.69 - 0) <AB7FF37C-CB4B-3DE7-A825-2CEB2DE0568A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
                                 0x116143000 -        0x11614dff7 +com.adobe.InDesign.Document UI (9.2.0.69 - 0) <7FAE894D-EEAE-3C6B-B209-A6CFAFA514B7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
                                 0x116157000 -        0x11617dfff +com.adobe.InDesign.Document Actions (9.2.0.69 - 0) <6E70D356-C8C4-3EBD-9026-19E728F20013> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
                                 0x11618a000 -        0x1161b0fff +com.adobe.InDesign.Dialog Layout (9.2.0.69 - 0) <F0876EDD-1E88-3B12-BABC-63F14A8DA912> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
                                 0x1161c2000 -        0x1161f6ff7 +com.adobe.InDesign.ContentDropper (9.2.0.69 - 0) <770161E3-FD66-3F7E-9590-8081A26EBF87> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
                                 0x11620a000 -        0x116261fff +com.adobe.InDesign.Conditional Text (9.2.0.69 - 0) <0F92B4B6-9877-38A5-AE21-77558C13513F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
                                 0x11627a000 -        0x1162e1ff7 +com.adobe.InDesign.CompFontMgr (9.2.0.69 - 0) <445E5D30-A1FC-3E63-AEA9-B0DF8B1F9213> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
                                 0x1162f9000 -        0x11637ffff +com.adobe.InDesign.CJKGrid (9.2.0.69 - 0) <C2AE712A-12DC-3666-A8F6-CE4572E22B87> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
                                 0x11639b000 -        0x11642bff7 +com.adobe.InDesign.CJK Text Attributes (9.2.0.69 - 0) <A3516E48-C8B1-33E1-9948-056076338D94> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
                                 0x11644e000 -        0x116487fff +com.adobe.InDesign.CellStyles (9.2.0.69 - 0) <99BB7B71-EDF0-361B-B168-A9AB3025E24D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
                                 0x11649a000 -        0x11653cff7 +com.adobe.InDesign.BNCore (9.2.0.69 - 0) <7370C6DC-E42A-3AE4-9E2B-AE876B3A625F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
                                 0x11655a000 -        0x1165c3fff +com.adobe.InDesign.Behavior (9.2.0.69 - 0) <9224EBBE-1184-30AC-9C0B-7776AC77A582> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
                                 0x1165e1000 -        0x11661bff7 +com.adobe.InDesign.Basic Tools (9.2.0.69 - 0) <67E340EB-CE3F-334F-B1FB-7B0FBCE2AB75> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
                                 0x116636000 -        0x116661ff7 +com.adobe.InDesign.AWSUI (9.2.0.69 - 0) <6CDDCDEE-176D-3E7E-A666-3CE5045EA3CB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
                                 0x116676000 -        0x1166b6fff +com.adobe.InDesign.AWS (9.2.0.69 - 0) <A7EDAAFF-361B-3BB0-BACD-4183815AE433> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
                                 0x1166cf000 -        0x11676cfff +com.adobe.InDesign.Assignments (9.2.0.69 - 0) <CB509B9C-35FF-3A4B-92FD-04B62DA4A91B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
                                 0x11678d000 -        0x1167b3ff7 +com.adobe.InDesign.Article (9.2.0.69 - 0) <5594CD9B-844A-3C9F-949A-93F520ACCD63> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
                                 0x1167c3000 -        0x116826ff7 +com.adobe.InDesign.Actions (9.2.0.69 - 0) <445019FF-B875-3B7B-9149-261136E3B61E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
                                 0x116841000 -        0x116970ff7 +com.adobe.InDesign.XMedia UI (9.2.0.69 - 0) <EE29CCB0-862B-3528-B6F1-AA856F23DFA8> /Applications/Adobe InDesign CC/*/XMedia UI
                                 0x1169ba000 -        0x116a0bff7 +com.adobe.InDesign.Snippet (9.2.0.69 - 0) <5CC75DF2-5697-3E17-920D-1536AED78A9A> /Applications/Adobe InDesign CC/*/Snippet
                                 0x116a24000 -        0x116a2efff +com.adobe.InDesign.Workgroup UI (9.2.0.69 - 0) <B71098FE-647E-327A-9767-8075272CB665> /Applications/Adobe InDesign CC/*/Workgroup UI
                                 0x116a37000 -        0x116a46ff7 +com.adobe.InDesign.Metadata UI (9.2.0.69 - 0) <442F11B4-4698-3BED-BADD-F1E858A7DCB7> /Applications/Adobe InDesign CC/*/Metadata UI
                                 0x116a50000 -        0x116ac1fe7 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 79.154511) <E69CE2EF-1FC7-3C8D-AAB8-8C5B0B3D3176> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                                 0x116ad4000 -        0x116ae0ff7 +com.adobe.InDesign.PerformanceMetrics (9.2.0.69 - 0) <67E7E2B5-61E3-3F40-B440-5FE1EDE59E77> /Applications/Adobe InDesign CC/*/PerformanceMetrics
                                 0x116aeb000 -        0x116b02ff7 +com.adobe.InDesign.Track Changes UI (9.2.0.69 - 0) <01C328F8-3440-3866-B596-D03D78FA5BF3> /Applications/Adobe InDesign CC/*/Track Changes UI
                                 0x116b0d000 -        0x116b15fff +com.adobe.InDesign.Track Changes Preferences (9.2.0.69 - 0) <5A658631-2249-3036-A041-EE8CB387BF8B> /Applications/Adobe InDesign CC/*/Track Changes Preferences
                                 0x116b1f000 -        0x116b27ff7 +com.adobe.InDesign.Tool Tips (9.2.0.69 - 0) <88CF576A-34C1-3CE6-A4CB-8EDB975F1DCB> /Applications/Adobe InDesign CC/*/Tool Tips
                                 0x116b30000 -        0x116b50fff +com.adobe.InDesign.Tool Box (9.2.0.69 - 0) <5B97B389-A741-323E-A4E8-38B49C3F2BF3> /Applications/Adobe InDesign CC/*/Tool Box
                                 0x116b74000 -        0x116b9afff +com.adobe.InDesign.Shortcut Editor Dialog (9.2.0.69 - 0) <C4A827C6-AA10-3628-8967-01B9CD5EF71E> /Applications/Adobe InDesign CC/*/Shortcut Editor Dialog
                                 0x116bae000 -        0x116bd2ff7 +com.adobe.InDesign.SharedContentUI (9.2.0.69 - 0) <D62134DD-76DC-3DD0-B8B2-4F2C857037E5> /Applications/Adobe InDesign CC/*/SharedContentUI
                                 0x116be1000 -        0x116bfdfff +com.adobe.InDesign.Performance UI (9.2.0.69 - 0) <278593AB-82E1-373C-9644-85373371BB93> /Applications/Adobe InDesign CC/*/Performance UI
                                 0x116c12000 -        0x116c25ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                 0x116c2c000 -        0x116c37ff7 +com.adobe.InDesign.General Preferences Panel (9.2.0.69 - 0) <F513D5DE-713B-3A9A-9F3E-E997883E69A6> /Applications/Adobe InDesign CC/*/General Preferences Panel
                                 0x116c42000 -        0x116c63ff7 +com.adobe.InDesign.GapTool (9.2.0.69 - 0) <FC93E783-D09C-3F01-9CF1-873002CC0FBD> /Applications/Adobe InDesign CC/*/GapTool
                                 0x116c73000 -        0x116cabff7 +com.adobe.InDesign.Galley Preferences (9.2.0.69 - 0) <8AA1A69A-6B95-320B-9307-C45F80BCD14D> /Applications/Adobe InDesign CC/*/Galley Preferences
                                 0x116cc6000 -        0x116cf8fff +com.adobe.InDesign.CSXS (9.2.0.69 - 0) <23CEA49C-D486-3ADB-B1E9-4647E3BD22AE> /Applications/Adobe InDesign CC/*/CSXS
                                 0x116d10000 -        0x116d3cff7 +com.adobe.InDesign.Article Panel (9.2.0.69 - 0) <DFB7EF6E-5FBE-3E41-8A0B-B5E678F955A4> /Applications/Adobe InDesign CC/*/Article Panel
                                 0x116d55000 -        0x116d7aff7 +com.adobe.InDesign.Text Style Panel (9.2.0.69 - 0) <8313AC57-723E-3409-97C3-4E33665F8396> /Applications/Adobe InDesign CC/*/Text Style Panel
                                 0x116d8b000 -        0x116daeff7 +com.adobe.InDesign.Text Ruler (9.2.0.69 - 0) <7B9A2B91-60B5-32FD-8244-6372495C16BF> /Applications/Adobe InDesign CC/*/Text Ruler
                                 0x116dbf000 -        0x116de1fff +com.adobe.InDesign.Text Preferences (9.2.0.69 - 0) <8C47BE3B-1091-32A2-9059-386030EC9C49> /Applications/Adobe InDesign CC/*/Text Preferences
                                 0x116df1000 -        0x116e1dff7 +com.adobe.InDesign.Text Frame Options (9.2.0.69 - 0) <24DF4463-54CA-3FC3-95E3-E8C791B12169> /Applications/Adobe InDesign CC/*/Text Frame Options
                                 0x116e2e000 -        0x116eaafff +com.adobe.InDesign.Color Picker Panel (9.2.0.69 - 0) <65E3F570-F364-3016-A42A-355B59BEB4DF> /Applications/Adobe InDesign CC/*/Color Picker Panel
                                 0x116ed2000 -        0x116f8fff7 +com.adobe.InDesign.Swatches Panel (9.2.0.69 - 0) <AFC9C047-060B-3F87-BFF4-C500FFC817DF> /Applications/Adobe InDesign CC/*/Swatches Panel
                                 0x116fc6000 -        0x117041ff7 +com.adobe.InDesign.Style Panel (9.2.0.69 - 0) <9282C33B-17C7-3AE0-94D0-7F53831FA588> /Applications/Adobe InDesign CC/*/Style Panel
                                 0x11706a000 -        0x117096ff7 +com.adobe.InDesign.Find Change Format Panel (9.2.0.69 - 0) <59B463B6-6D3B-3D25-B353-4A99C6301B2A> /Applications/Adobe InDesign CC/*/Find Change Format Panel
                                 0x1170aa000 -        0x1171cfff7 +com.adobe.InDesign.Find and Change Panel (9.2.0.69 - 0) <9B25A6FC-D818-3715-9CAD-D1C7FDC71680> /Applications/Adobe InDesign CC/*/Find and Change Panel
                                 0x11720c000 -        0x117240ff7 +com.adobe.InDesign.Paragraph Panel (9.2.0.69 - 0) <AF14E0F9-4234-355B-816F-A19A7BCE8676> /Applications/Adobe InDesign CC/*/Paragraph Panel
                                 0x117253000 -        0x117280fff +com.adobe.InDesign.RunIn Styles Panel (9.2.0.69 - 0) <EE33D598-7F48-3DCE-A596-B619BE63F8EE> /Applications/Adobe InDesign CC/*/RunIn Styles Panel
                                 0x117292000 -        0x1172a9fff +com.adobe.InDesign.Path Type UI (9.2.0.69 - 0) <5FBB48B2-8E60-3BFA-82EA-A52467B9831A> /Applications/Adobe InDesign CC/*/Path Type UI
                                 0x1172b9000 -        0x1172cbff7 +com.adobe.InDesign.Paragraph Rules Panel (9.2.0.69 - 0) <505B0CE0-4873-3DA9-97BC-1CE80B8A81E4> /Applications/Adobe InDesign CC/*/Paragraph Rules Panel
                                 0x1172d5000 -        0x1172f5fff +com.adobe.InDesign.Optical Kerning (9.2.0.69 - 0) <4E574590-FE5E-3CD1-91FE-A812919DDFAF> /Applications/Adobe InDesign CC/*/Optical Kerning
                                 0x117300000 -        0x117308ff7 +com.adobe.InDesign.Keeps Panel (9.2.0.69 - 0) <B93BD9B2-6C80-39E6-8A20-C37883A904E4> /Applications/Adobe InDesign CC/*/Keeps Panel
                                 0x117310000 -        0x117324fff +com.adobe.InDesign.Indents and Tabs (9.2.0.69 - 0) <43823223-7B60-3171-AACB-A8CD50C966CC> /Applications/Adobe InDesign CC/*/Indents and Tabs
                                 0x117333000 -        0x11733dfff +com.adobe.InDesign.Hyphenation Panel (9.2.0.69 - 0) <CE3045F4-F009-33E4-904D-557A76A05216> /Applications/Adobe InDesign CC/*/Hyphenation Panel
                                 0x11734a000 -        0x11741afff +com.adobe.InDesign.Glyphs Panel (9.2.0.69 - 0) <0C352A11-C0DE-33D4-ACD6-1A436B87D956> /Applications/Adobe InDesign CC/*/Glyphs Panel
                                 0x11743e000 -        0x11747eff7 +com.adobe.InDesign.Font Usage Dialog (9.2.0.69 - 0) <8CD7FADB-42BB-3C5D-8D01-D66041C451BB> /Applications/Adobe InDesign CC/*/Font Usage Dialog
                                 0x117496000 -        0x1174b3ff7 +com.adobe.InDesign.Create Outlines (9.2.0.69 - 0) <67E01895-4459-3227-97EE-05C08FAF12A7> /Applications/Adobe InDesign CC/*/Create Outlines
                                 0x1174c0000 -        0x1174f2fff +com.adobe.InDesign.Conditional Text UI (9.2.0.69 - 0) <E1DD33FA-169E-3173-8E4F-E60BBFCC55D2> /Applications/Adobe InDesign CC/*/Conditional Text UI
                                 0x11750d000 -        0x1175a4ff7 +com.adobe.InDesign.Character Panel (9.2.0.69 - 0) <13A2F730-248F-35BC-BB7E-4768DB93439D> /Applications/Adobe InDesign CC/*/Character Panel
                                 0x1175e4000 -        0x117688ff7 +com.adobe.InDesign.TableStylesUI (9.2.0.69 - 0) <956E57B9-06EB-3501-A290-B0D891C623C3> /Applications/Adobe InDesign CC/*/TableStylesUI
                                 0x1176b4000 -        0x117798fff +com.adobe.InDesign.Tables UI (9.2.0.69 - 0) <EB6A86BF-BECA-374D-9AE3-B29A6566EB44> /Applications/Adobe InDesign CC/*/Tables UI
                                 0x1177c7000 -        0x1177d5ff7 +com.adobe.InDesign.Scripts Panel (9.2.0.69 - 0) <C96405B4-3F30-3174-9F2A-4C874721EF27> /Applications/Adobe InDesign CC/*/Scripts Panel
                                 0x1177e4000 -        0x1177eafff +com.adobe.InDesign.Script Label Panel (9.2.0.69 - 0) <CF90BDAA-5B8E-33EB-B580-972C71104678> /Applications/Adobe InDesign CC/*/Script Label Panel
                                 0x1177f6000 -        0x1178e4ff7 +com.adobe.InDesign.JBX (9.2.0.69 - 0) <5302971B-87FB-3CFF-A72E-9930FB1F805D> /Applications/Adobe InDesign CC/*/JBX
                                 0x11790e000 -        0x117a1bff7 +com.adobe.InDesign.Package and Preflight UI (9.2.0.69 - 0) <A11E8FC7-DF9C-3B40-BEB4-B555BE2A2A3C> /Applications/Adobe InDesign CC/*/Package and Preflight UI
                                 0x117a5c000 -        0x117afdff7 +com.adobe.InDesign.DataMerge (9.2.0.69 - 0) <0DFAE7C2-0731-3D82-AA8C-1AE6E109DF99> /Applications/Adobe InDesign CC/*/DataMerge
                                 0x117b1d000 -        0x117b51fff +com.adobe.InDesign.DataMergeUI (9.2.0.69 - 0) <898AA1EF-681C-346F-B141-6DB164AD3FE5> /Applications/Adobe InDesign CC/*/DataMergeUI
                                 0x117b6c000 -        0x117bd0ff7 +com.adobe.InDesign.BNUI (9.2.0.69 - 0) <A687AB81-E289-3AFD-BDC5-3350B0C1122D> /Applications/Adobe InDesign CC/*/BNUI
                                 0x117bf0000 -        0x117c06fff +com.adobe.InDesign.Scotch Rules (9.2.0.69 - 0) <7BB10CB0-31B7-3B31-B2A5-97B8792273C3> /Applications/Adobe InDesign CC/*/Scotch Rules
                                 0x117c11000 -        0x117c23ff7 +com.adobe.InDesign.PS Import UI (9.2.0.69 - 0) <6F36235F-8819-3C30-8DCE-2771243875BE> /Applications/Adobe InDesign CC/*/PS Import UI
                                 0x117c32000 -        0x117c4dfff +com.adobe.InDesign.Image Import UI (9.2.0.69 - 0) <BBC09119-A690-340C-93A7-E27B238004B6> /Applications/Adobe InDesign CC/*/Image Import UI
                                 0x117c5f000 -        0x117c9bfff +com.adobe.InDesign.Transform Panel (9.2.0.69 - 0) <78B039EC-7BD7-3D4E-8C85-DE128B6C1F4B> /Applications/Adobe InDesign CC/*/Transform Panel
                                 0x117cb1000 -        0x117cf2fff +com.adobe.InDesign.TOC UI Dialog (9.2.0.69 - 0) <9DC626E3-B44C-327D-A605-3486F290893A> /Applications/Adobe InDesign CC/*/TOC UI Dialog
                                 0x117d0c000 -        0x117d4bff7 +com.adobe.InDesign.Text Wrap Panel (9.2.0.69 - 0) <0767C906-FE80-30D5-89E1-78D3F7AC8A5A> /Applications/Adobe InDesign CC/*/Text Wrap Panel
                                 0x117d64000 -        0x117d6efff +com.adobe.InDesign.StepRepeat (9.2.0.69 - 0) <0F3A3EC5-6BF6-3D92-B2A9-A8D571E51B54> /Applications/Adobe InDesign CC/*/StepRepeat
                                 0x117d7a000 -        0x117d89fff +com.adobe.InDesign.Sections UI (9.2.0.69 - 0) <3FD8D737-8DA8-3707-9031-FB97E05D9FB9> /Applications/Adobe InDesign CC/*/Sections UI
                                 0x117d94000 -        0x117e58fff +com.adobe.InDesign.Pages Panel (9.2.0.69 - 0) <67B36CC5-4EED-30FA-9507-62B45AFDBFB5> /Applications/Adobe InDesign CC/*/Pages Panel
                                 0x117e89000 -        0x117e95ff7 +com.adobe.InDesign.Generic Style Editor (9.2.0.69 - 0) <6DD52448-3D93-3D78-AEE4-BB5B78D2B018> /Applications/Adobe InDesign CC/*/Generic Style Editor
                                 0x117ea4000 -        0x117ecafff +com.adobe.InDesign.Page Setup Dialog (9.2.0.69 - 0) <36758243-E6DC-3E0F-A79E-AADCD5A416A8> /Applications/Adobe InDesign CC/*/Page Setup Dialog
                                 0x117ed7000 -        0x117f86ff7 +com.adobe.InDesign.Transparency UI (9.2.0.69 - 0) <3209F3EC-0A3E-3E68-AB9F-04D2F2D76C3D> /Applications/Adobe InDesign CC/*/Transparency UI
                                 0x117fb9000 -        0x11805cfff +com.adobe.InDesign.Graphic Panels (9.2.0.69 - 0) <AC90D2D5-F299-3B08-A9CB-82BC0E557FFC> /Applications/Adobe InDesign CC/*/Graphic Panels
                                 0x118086000 -        0x11812bff7 +com.adobe.InDesign.ObjectStylesUI (9.2.0.69 - 0) <0D9FA355-F322-31B5-BC77-2020503C5260> /Applications/Adobe InDesign CC/*/ObjectStylesUI
                                 0x11815b000 -        0x1181a7ff7 +com.adobe.InDesign.Links UI (9.2.0.69 - 0) <5D426E96-ADC2-38BE-A84E-840FFFF0EB1D> /Applications/Adobe InDesign CC/*/Links UI
                                 0x1181c9000 -        0x11828dfff +com.adobe.InDesign.Knowledge Base (9.2.0.69 - 0) <E650B6BD-690B-37A0-9371-970563634B38> /Applications/Adobe InDesign CC/*/Knowledge Base
                                 0x118297000 -        0x1182b7fff +com.adobe.InDesign.Layout Adjustment (9.2.0.69 - 0) <08AB16C3-C9CB-3486-A339-2A35E63E0565> /Applications/Adobe InDesign CC/*/Layout Adjustment
                                 0x1182c6000 -        0x1182cbfff +com.adobe.InDesign.Layout Adjustment Panel (9.2.0.69 - 0) <098313B3-96FB-3AF9-BC24-2F3CA93AFB4C> /Applications/Adobe InDesign CC/*/Layout Adjustment Panel
                                 0x1182d4000 -        0x118327ff7 +com.adobe.InDesign.Layers Panel (9.2.0.69 - 0) <32A9F245-ABAE-302A-B17C-B3EF2A5E4A9D> /Applications/Adobe InDesign CC/*/Layers Panel
                                 0x118349000 -        0x1183b2fff +com.adobe.InDesign.Info Panel (9.2.0.69 - 0) <F0AABE7E-6D25-3BD9-A8EC-A1CE5B1C3373> /Applications/Adobe InDesign CC/*/Info Panel
                                 0x1183ca000 -        0x11845afff +com.adobe.InDesign.Index Panel (9.2.0.69 - 0) <3B1558CE-A272-35B4-A8A3-FFD880B3630B> /Applications/Adobe InDesign CC/*/Index Panel
                                 0x11847a000 -        0x118486ff7  com.apple.carbonframeworktemplate (1.0 - 1.0) <E859A35E-8EC1-3CA9-9758-95EC69D4EC5D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
                                 0x118491000 -        0x118554ff7 +com.adobe.InDesign.Hyperlinks Panel (9.2.0.69 - 0) <AA907300-643E-3EAF-9687-83E8ECF7C6B9> /Applications/Adobe InDesign CC/*/Hyperlinks Panel
                                 0x118584000 -        0x1185befff +com.adobe.InDesign.Eyedropper Tool (9.2.0.69 - 0) <6EB8BC12-7868-3B4C-BAD1-851801E0A42E> /Applications/Adobe InDesign CC/*/Eyedropper Tool
                                 0x1185d3000 -        0x1185ddfff +com.adobe.InDesign.Create Guides Dialog (9.2.0.69 - 0) <59B37FF3-166C-3BA0-88F9-B48121D455FA> /Applications/Adobe InDesign CC/*/Create Guides Dialog
                                 0x1185e8000 -        0x11862eff7 +com.adobe.InDesign.Control Panel (9.2.0.69 - 0) <15528F16-3629-3E3B-90A8-E5CBD8E31B45> /Applications/Adobe InDesign CC/*/Control Panel
                                 0x11864b000 -        0x118684fff +com.adobe.InDesign.ContentDropper Tool (9.2.0.69 - 0) <E8550DE9-50AD-303F-9009-8E584DBADF9E> /Applications/Adobe InDesign CC/*/ContentDropper Tool
                                 0x1186a3000 -        0x1186bffff +com.adobe.InDesign.Bookmark Panel (9.2.0.69 - 0) <BDC06E7C-049F-323E-B333-1FED1E499E37> /Applications/Adobe InDesign CC/*/Bookmark Panel
                                 0x1186d6000 -        0x118724ff7 +com.adobe.InDesign.Book Panel (9.2.0.69 - 0) <AA1C2413-72AA-3407-8A68-203B8FB4FEA2> /Applications/Adobe InDesign CC/*/Book Panel
                                 0x118748000 -        0x1187b5fff +com.adobe.InDesign.Asset PubLibrary (9.2.0.69 - 0) <37F17FFD-7BAA-3F5F-87D3-647C49A127ED> /Applications/Adobe InDesign CC/*/Asset PubLibrary
                                 0x1187d3000 -        0x11881afff +com.adobe.InDesign.Asset Library Panel (9.2.0.69 - 0) <94FC082E-93DF-34B8-B9AF-56F7A5A98B9E> /Applications/Adobe InDesign CC/*/Asset Library Panel
                                 0x11883e000 -        0x11884efff +com.adobe.InDesign.Alignment Panel (9.2.0.69 - 0) <54940D94-3BB6-38D7-B45B-14906B94A6C3> /Applications/Adobe InDesign CC/*/Alignment Panel
                                 0x118857000 -        0x11887fff7 +com.adobe.InDesign.MediaUI (9.2.0.69 - 0) <3EF85F9E-52B3-3385-861C-116A4758E02D> /Applications/Adobe InDesign CC/*/MediaUI
                                 0x118894000 -        0x118936fff +com.adobe.InDesign.ButtonUI (9.2.0.69 - 0) <A6BBF878-D711-3510-B607-EC1B52687BFC> /Applications/Adobe InDesign CC/*/ButtonUI
                                 0x118966000 -        0x11896bff7 +com.adobe.InDesign.Username UI (9.2.0.69 - 0) <D3009947-D338-3EAB-9690-722AB9C10FB3> /Applications/Adobe InDesign CC/*/Username UI
                                 0x118975000 -        0x118980ff7 +com.adobe.InDesign.NotePref (9.2.0.69 - 0) <D1FA4217-A5A8-31D2-9178-D94F2F048790> /Applications/Adobe InDesign CC/*/NotePref
                                 0x11898e000 -        0x1189e5ff7 +com.adobe.InDesign.Note (9.2.0.69 - 0) <07808666-F165-34C1-9E46-D4403EC7C6A6> /Applications/Adobe InDesign CC/*/Note
                                 0x118a05000 -        0x118a0dfff +com.adobe.InDesign.InCopyWorkflow UI (9.2.0.69 - 0) <F7524889-E7AC-3177-AFF7-B487FD6BF7D6> /Applications/Adobe InDesign CC/*/InCopyWorkflow UI
                                 0x118a18000 -        0x118a1ffff +com.adobe.InDesign.InCopyImport (9.2.0.69 - 0) <6C4D93D1-26B1-3A78-AEC4-08BE97A6F15A> /Applications/Adobe InDesign CC/*/InCopyImport
                                 0x118a26000 -        0x118a2efff +com.adobe.InDesign.InCopyExport (9.2.0.69 - 0) <9ACE4231-FCB8-3995-BE0E-ED6DBEAA58B7> /Applications/Adobe InDesign CC/*/InCopyExport
                                 0x118a38000 -        0x118a3fff7 +com.adobe.InDesign.InCopyExportUI (9.2.0.69 - 0) <F0EB0F82-C96B-3B9D-92C5-66E2DCC416DF> /Applications/Adobe InDesign CC/*/InCopyExportUI
                                 0x118a48000 -        0x118a87ff7 +com.adobe.InDesign.InCopy Bridge (9.2.0.69 - 0) <F476293E-F020-3CDB-9A0C-660B91A71281> /Applications/Adobe InDesign CC/*/InCopy Bridge
                                 0x118a97000 -        0x118abafff +com.adobe.InDesign.InCopy Bridge UI (9.2.0.69 - 0) <7923E03C-96CB-3369-8CEC-1EA4E369DE70> /Applications/Adobe InDesign CC/*/InCopy Bridge UI
                                 0x118ac8000 -        0x118b2cfff +com.adobe.InDesign.Assignment UI (9.2.0.69 - 0) <23FE015C-C541-3EB2-BAAD-25F931528849> /Applications/Adobe InDesign CC/*/Assignment UI
                                 0x118b4e000 -        0x118b72ff7 +com.adobe.InDesign.Swatch Library Panel (9.2.0.69 - 0) <5C94F9C0-227E-3D5E-83FE-8D24A39A7286> /Applications/Adobe InDesign CC/*/Swatch Library Panel
                                 0x118b81000 -        0x118c63fff +com.adobe.InDesign.PrintUI (9.2.0.69 - 0) <8CF1D4F4-85B0-3B0E-ABB8-DF70DA17609C> /Applications/Adobe InDesign CC/*/PrintUI
                                 0x118c8f000 -        0x118ca6ff7 +com.adobe.InDesign.Printer Styles (9.2.0.69 - 0) <ACDF3B96-030B-3A7A-B552-661D4EF28F6D> /Applications/Adobe InDesign CC/*/Printer Styles
                                 0x118cb5000 -        0x118d36fff +com.adobe.InDesign.PDF UI (9.2.0.69 - 0) <2ABDFC92-F233-3DD2-9F41-6EA7F34B2E1E> /Applications/Adobe InDesign CC/*/PDF UI
                                 0x118d5a000 -        0x118d71ff7 +com.adobe.InDesign.OutputMiscUI (9.2.0.69 - 0) <BACF73C7-0ABA-361D-8F85-840CF055968A> /Applications/Adobe InDesign CC/*/OutputMiscUI
                                 0x118d84000 -        0x118dd5fff +com.adobe.InDesign.Output Preview (9.2.0.69 - 0) <1967D234-6D81-314A-8F7D-C85C7A2C2875> /Applications/Adobe InDesign CC/*/Output Preview
                                 0x118def000 -        0x118e0afff +com.adobe.InDesign.JPEG Export (9.2.0.69 - 0) <DB2C27D2-B1A9-37BF-BFB4-484E28CFC2E5> /Applications/Adobe InDesign CC/*/JPEG Export
                                 0x118e1c000 -        0x118e24ff7 +com.adobe.InDesign.JPEG Export UI (9.2.0.69 - 0) <2EAEC64B-5E6D-3E13-80AC-2DED9C3F0A28> /Applications/Adobe InDesign CC/*/JPEG Export UI
                                 0x118e2d000 -        0x118e63fff +com.adobe.InDesign.Gradient Panel (9.2.0.69 - 0) <A0B7F034-768A-3725-8F03-7302B1014374> /Applications/Adobe InDesign CC/*/Gradient Panel
                                 0x118e7a000 -        0x118e96fff +com.adobe.InDesign.EPS UI (9.2.0.69 - 0) <EEC807E7-CA80-341C-9EC9-B2A466EEF0D8> /Applications/Adobe InDesign CC/*/EPS UI
                                 0x118ea7000 -        0x118f27ff7 +com.adobe.InDesign.DynamicDocumentsUI (9.2.0.69 - 0) <7AE58B59-0747-3910-8FD5-34C4347F9320> /Applications/Adobe InDesign CC/*/DynamicDocumentsUI
                                 0x118f4e000 -        0x119165fff +com.adobe.InDesign.Digital Publishing (9.0.10.29 - 0) <6AABD4D4-EA0A-3F46-82EE-1F6A685437AD> /Applications/Adobe InDesign CC/*/Digital Publishing
                                 0x1192e5000 -        0x11931dfef +libcurl.4.dylib (7) <FA1D87DC-8CBC-3645-8ADA-D974B6EDED53> /Applications/Adobe InDesign CC/*/libcurl.4.dylib
                                 0x119328000 -        0x11936cff7 +com.adobe.InDesign.Color Management UI (9.2.0.69 - 0) <E1F74CF9-8EF7-3EDE-9A4B-D8588C99A23F> /Applications/Adobe InDesign CC/*/Color Management UI
                                 0x11937c000 -        0x119389fff +com.adobe.InDesign.Clipping Path Dialog (9.2.0.69 - 0) <93D2E8FF-D77F-3DBA-96AF-116B460D22C3> /Applications/Adobe InDesign CC/*/Clipping Path Dialog
                                 0x11939b000 -        0x11946eff7 +com.adobe.InDesign.Tagged Text Attributes (9.2.0.69 - 0) <63FB581D-0334-3755-8697-6051DBBA1716> /Applications/Adobe InDesign CC/*/Tagged Text Attributes
                                 0x11949d000 -        0x119542fff +com.adobe.InDesign.Tagged Text Filters (9.2.0.69 - 0) <A33D33F5-232D-3778-BC70-3BA61804DD2B> /Applications/Adobe InDesign CC/*/Tagged Text Filters
                                 0x119557000 -        0x119563fff +com.adobe.InDesign.Tagged Text Filters UI (9.2.0.69 - 0) <83C996D8-4E24-3511-A666-70DE47F3DE39> /Applications/Adobe InDesign CC/*/Tagged Text Filters UI
                                 0x11956e000 -        0x119570fff +com.adobe.InDesign.SimpleTextImportFilter (9.2.0.69 - 0) <B409D770-A106-3EFE-9925-DE295432C918> /Applications/Adobe InDesign CC/*/SimpleTextImportFilter
                                 0x119576000 -        0x11958cff7 +com.adobe.InDesign.SaveBack (9.2.0.69 - 0) <42FE0ACC-F37A-3DAC-8101-490609415A86> /Applications/Adobe InDesign CC/*/SaveBack
                                 0x11959a000 -        0x1195eeff7 +com.adobe.InDesign.SangamExport (9.2.0.69 - 0) <86187ADD-BB1A-37CD-9699-DEC36615F2C0> /Applications/Adobe InDesign CC/*/SangamExport
                                 0x119605000 -        0x11962fff7 +com.adobe.InDesign.Sangam Preferences UI (9.2.0.69 - 0) <BCFBDD3B-9562-3F7A-AFE7-052DE0E3620E> /Applications/Adobe InDesign CC/*/Sangam Preferences UI
                                 0x119642000 -        0x11964bff7 +com.adobe.InDesign.PNG Import Filter UI (9.2.0.69 - 0) <C566B5E1-9945-3673-A6E0-12FDBE39B7D2> /Applications/Adobe InDesign CC/*/PNG Import Filter UI
                                 0x119656000 -        0x1196b3fff +com.adobe.InDesign.Media Import Filter (9.2.0.69 - 0) <E612697E-17AF-3305-B5CF-F7BCA68C4777> /Applications/Adobe InDesign CC/*/Media Import Filter
                                 0x1196c6000 -        0x119812ff7 +com.adobe.InDesign.EBookExport (9.2.0.69 - 0) <E3E7D070-D9A7-386A-A43E-C7CC4B678E02> /Applications/Adobe InDesign CC/*/EBookExport
                                 0x11983d000 -        0x119863fff +com.adobe.InDesign.LILO (9.2.0.69 - 0) <02CAE547-BE94-333C-A38D-F73923098BD2> /Applications/Adobe InDesign CC/*/LILO
                                 0x119871000 -        0x11994cfff +com.adobe.linguistic.LinguisticManager (7.0.0 - 19061) <FDBCF369-5EFE-33BB-893A-2136EF8D0D6E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                                 0x119968000 -        0x119970fff +com.adobe.InDesign.Data Services (9.2.0.69 - 0) <48C1DEF8-D77A-3717-AD51-02E641D9EF8F> /Applications/Adobe InDesign CC/*/Data Services
                                 0x119976000 -        0x11997efff +com.adobe.InDesign.Data Services UI (9.2.0.69 - 0) <EF01EA1E-61C9-3B9E-A166-0A425537E310> /Applications/Adobe InDesign CC/*/Data Services UI
                                 0x119988000 -        0x1199aeff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                                 0x1199c0000 -        0x119aa4fff +IMSLib.dylib (7.0.0.146 - 7.0.0.146) <38D7DA66-E06E-38A3-9401-42755F56C2C5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/IMSLib.dylib
                                 0x119abc000 -        0x119b33ff7  com.apple.xquery (1.3.1 - 30) <2F2DC0D6-456F-33A0-8537-E0C651F6817C> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                              0x7fff62c64000 -     0x7fff62c97817  dyld (239.3) <D1DFCF3F-0B0C-332A-BCC0-87A851B570FF> /usr/lib/dyld
                              0x7fff8a707000 -     0x7fff8a774fff  com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                              0x7fff8a775000 -     0x7fff8a7c3fff  libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
                              0x7fff8a80b000 -     0x7fff8a80cfff  liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
                              0x7fff8a867000 -     0x7fff8a89fff7  com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                              0x7fff8a8e2000 -     0x7fff8a8f4fff  com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                              0x7fff8a8f5000 -     0x7fff8a8f8fff  libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                              0x7fff8ad23000 -     0x7fff8ade6ff7  com.apple.backup.framework (1.5.1 - 1.5.1) <FC4E949B-B41A-3F21-8AF8-AEDB13146FEA> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                              0x7fff8af2f000 -     0x7fff8af4bff7  libsystem_kernel.dylib (2422.1.72) <D14913DB-47F1-3591-8DAF-D4B4EF5F8818> /usr/lib/system/libsystem_kernel.dylib
                              0x7fff8af8c000 -     0x7fff8afa8fff  libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
                              0x7fff8afa9000 -     0x7fff8bb1dff7  com.apple.AppKit (6.9 - 1265) <0E9FC8BF-DA3C-34C5-91CC-12BC922B5F01> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                              0x7fff8bb1e000 -     0x7fff8c43a05f  com.apple.CoreGraphics (1.600.0 - 599.7) <7D0FD5A7-A061-39BA-8E00-723825D2C4DD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                              0x7fff8c461000 -     0x7fff8c4eafff  com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                              0x7fff8c4eb000 -     0x7fff8c7b9ff4  com.apple.CoreImage (9.0.54) <74BB8685-69A9-3A45-8DED-EA26BD39D710> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                              0x7fff8c7c9000 -     0x7fff8c7f1ffb  libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
                              0x7fff8c7f2000 -     0x7fff8c81affb  libRIP.A.dylib (599.7) <6F528EE3-99F8-3871-BD60-1306495C27D5> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                              0x7fff8cd38000 -     0x7fff8cd46fff  com.apple.opengl (9.0.83 - 9.0.83) <AF467644-7B1D-327A-AC47-CECFCAF61990> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                              0x7fff8cd49000 -     0x7fff8cd78fff  com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                              0x7fff8cf06000 -     0x7fff8cf6aff3  com.apple.datadetectorscore (5.0 - 354.0) <9ACF24B8-3268-3134-A5BC-D72C9371A195> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                              0x7fff8cf6b000 -     0x7fff8d055fff  libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
                              0x7fff8d088000 -     0x7fff8d0afff7  libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
                              0x7fff8d127000 -     0x7fff8d127fff  com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                              0x7fff8d13f000 -     0x7fff8d324ff7  com.apple.CoreFoundation (6.9 - 855.11) <E22C6A1F-8996-349C-905E-96C3BBE07C2F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                              0x7fff8d325000 -     0x7fff8d758ffb  com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                              0x7fff8d759000 -     0x7fff8d7abfff  libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
                              0x7fff8d836000 -     0x7fff8d843ff4  com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                              0x7fff8d874000 -     0x7fff8d9c7ff7  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <A0B7B007-9BD8-30E2-B644-47856DA29FEE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                              0x7fff8d9c8000 -     0x7fff8da0ffff  libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                              0x7fff8da42000 -     0x7fff8db0dfff  libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                              0x7fff8db5b000 -     0x7fff8db74ff7  com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                              0x7fff8dbb5000 -     0x7fff8dbbdfff  libsystem_dnssd.dylib (522.1.11) <270DCF6C-502D-389A-AA9F-DE4624A36FF7> /usr/lib/system/libsystem_dnssd.dylib
                              0x7fff8dd25000 -     0x7fff8dd2fff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                              0x7fff8dd37000 -     0x7fff8dd70ff7  com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                              0x7fff8dd71000 -     0x7fff8dd74fff  com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                              0x7fff8dd75000 -     0x7fff8dd85fff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
                              0x7fff8dded000 -     0x7fff8def2fff  com.apple.ImageIO.framework (3.3.0 - 1038) <2C058216-C6D8-3380-A7EA-92A3F04520C1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                              0x7fff8e141000 -     0x7fff8e15aff7  com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                              0x7fff8e186000 -     0x7fff8e18fff3  libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
                              0x7fff8e193000 -     0x7fff8e19aff7  liblaunch.dylib (842.1.4) <FCBF0A02-0B06-3F97-9248-5062A9DEB32C> /usr/lib/system/liblaunch.dylib
                              0x7fff8e19b000 -     0x7fff8e1a7ff7  com.apple.OpenDirectory (10.9 - 173.1.1) <6B78BD7B-5622-38E6-8FC6-86A117E3ACCA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                              0x7fff8e1a8000 -     0x7fff8e201fff  libTIFF.dylib (1038) <5CBFE0C2-9DD8-340B-BA63-A94CE2E476F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                              0x7fff8e202000 -     0x7fff8e20eff3  com.apple.AppleFSCompression (56 - 1.0) <5652B0D0-EB08-381F-B23A-6DCF96991FB5> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                              0x7fff8e20f000 -     0x7fff8e20ffff  com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                              0x7fff8e2e2000 -     0x7fff8e3d3ff9  libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
                              0x7fff8e3d4000 -     0x7fff8e3d7ffc  com.apple.IOSurface (91 - 91) <07CA8A59-1E32-3FB6-B506-18DAF58A8CE0> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                              0x7fff8e3e4000 -     0x7fff8e3ebfff  com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                              0x7fff8f450000 -     0x7fff8f49eff9  libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
                              0x7fff8f9c4000 -     0x7fff8f9ccff3  libCGCMS.A.dylib (599.7) <92AA4E85-7633-36E2-BAD0-7B1A2E48E75C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
                              0x7fff8f9cd000 -     0x7fff8f9d7fff  libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
                              0x7fff8f9d8000 -     0x7fff8f9dcfff  com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                              0x7fff8f9dd000 -     0x7fff8fa66ff7  libsystem_c.dylib (997.1.1) <61833FAA-7281-3FF9-937F-686B6F20427C> /usr/lib/system/libsystem_c.dylib
                              0x7fff8fb64000 -     0x7fff8fb64fff  com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                              0x7fff8fc94000 -     0x7fff8fc95ffb  libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
                              0x7fff8fc96000 -     0x7fff8fc9afff  libsystem_stats.dylib (93.1.26) <B9E26A9E-FBBC-3938-B8B7-6CF7CA8C99AD> /usr/lib/system/libsystem_stats.dylib
                              0x7fff8fc9b000 -     0x7fff8fca5ff7  com.apple.CrashReporterSupport (10.9 - 538) <B487466B-3AA1-3854-A808-A61F049FA794> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                              0x7fff8fca6000 -     0x7fff8fd19ffb  com.apple.securityfoundation (6.0 - 55122) <119D1C53-B292-3378-AEE1-A3B1FB02F43F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                              0x7fff8fd21000 -     0x7fff8fd23ff3  libsystem_configuration.dylib (596.12) <C4F633D9-94C8-35D9-BB2D-84C5122533C7> /usr/lib/system/libsystem_configuration.dylib
                              0x7fff8fd24000 -     0x7fff8fd26fff  libCVMSPluginSupport.dylib (9.0.83) <E2AED858-6EEB-36C6-8C06-C3CF649A3CD5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                              0x7fff8fd31000 -     0x7fff8fd32fff  com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                              0x7fff900fc000 -     0x7fff900fcfff  com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                              0x7fff90125000 -     0x7fff9016cff7  libcups.2.dylib (372) <348EED62-6C20-35D6-8EFB-E80943965100> /usr/lib/libcups.2.dylib
                              0x7fff901cc000 -     0x7fff902b3ff7  libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
                              0x7fff902b4000 -     0x7fff902f5fff  com.apple.PerformanceAnalysis (1.47 - 47) <784ED7B8-FAE4-36CE-8C76-B7D300316C9F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                              0x7fff9066d000 -     0x7fff90687fff  libdispatch.dylib (339.1.9) <46878A5B-4248-3057-962C-6D4A235EEF31> /usr/lib/system/libdispatch.dylib
                              0x7fff90688000 -     0x7fff9068afff  libRadiance.dylib (1038) <55F99274-5074-3C73-BAC5-AF234E71CF38> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                              0x7fff9068b000 -     0x7fff9068effa  libCGXType.A.dylib (599.7) <2FC9C2BC-B5C5-3C27-93F9-51C6C4512E9D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                              0x7fff9068f000 -     0x7fff90692fff  com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                              0x7fff90693000 -     0x7fff90694ff7  com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                              0x7fff906a0000 -     0x7fff906afff8  com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                              0x7fff90777000 -     0x7fff9077eff3  libcopyfile.dylib (103) <5A881779-D0D6-3029-B371-E3021C2DDA5E> /usr/lib/system/libcopyfile.dylib
                              0x7fff9077f000 -     0x7fff908edff7  libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                              0x7fff90b92000 -     0x7fff90b9affc  libGFXShared.dylib (9.0.83) <11A621C3-37A0-39CE-A69B-8739021BD79D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                              0x7fff90b9b000 -     0x7fff90b9fff7  libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
                              0x7fff90ba0000 -     0x7fff90c17fff  com.apple.CoreServices.OSServices (600.4 - 600.4) <36B2B009-C35E-3F21-824E-E0D00E7808C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                              0x7fff90c34000 -     0x7fff90c5dff7  libc++abi.dylib (48) <8C16158F-CBF8-3BD7-BEF4-022704B2A326> /usr/lib/libc++abi.dylib
                              0x7fff90c5e000 -     0x7fff90c76ff7  com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                              0x7fff90c77000 -     0x7fff90c7bff7  libGIF.dylib (1038) <C29B4323-1B9E-36B9-96C2-7CEDBAA124F0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                              0x7fff90f42000 -     0x7fff90ffbfff  libcrypto.0.9.7.dylib (106) <BFE87BFA-7971-37DC-9B20-55F04E509A80> /usr/lib/libcrypto.0.9.7.dylib
                              0x7fff90ffc000 -     0x7fff90ffdff7  libSystem.B.dylib (1197.1.1) <BFC0DC97-46C6-3BE0-9983-54A98734897A> /usr/lib/libSystem.B.dylib
                              0x7fff9105e000 -     0x7fff91308ffd  com.apple.HIToolbox (2.1 - 696) <1CFFF37B-C392-3088-B0A4-C08C55B2AF8F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                              0x7fff91309000 -     0x7fff913cbff1  com.apple.CoreText (352.0 - 367.15) <E5C70FC8-C861-39B8-A491-595E5B55CFC8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                              0x7fff9140a000 -     0x7fff9144cff7  libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
                              0x7fff91829000 -     0x7fff91855fff  com.apple.CoreServicesInternal (184.8 - 184.8) <707E05AE-DDA8-36FD-B0FF-7F15A061B46A> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                              0x7fff91856000 -     0x7fff918c5ff1  com.apple.ApplicationServices.ATS (360 - 363.1) <88976B22-A9B8-3E7B-9AE6-0B8E09A968FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                              0x7fff918c6000 -     0x7fff918c6ffd  libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
                              0x7fff91935000 -     0x7fff9197aff6  com.apple.HIServices (1.22 - 466) <21807AF8-3BC7-32BB-AB96-7C35CB59D7F6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                              0x7fff91992000 -     0x7fff919adff7  libsystem_malloc.dylib (23.1.10) <FFE5C472-B23A-318A-85BF-77CDE61900D1> /usr/lib/system/libsystem_malloc.dylib
                              0x7fff919ae000 -     0x7fff91adeff7  com.apple.desktopservices (1.8 - 1.8) <09DC9BB8-432F-3C7A-BB08-956A2DDFC2DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                              0x7fff91adf000 -     0x7fff91b5ffff  com.apple.CoreSymbolication (3.0 - 141) <B018335C-698B-3F87-AF1C-6115C4FA8954> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                              0x7fff91b60000 -     0x7fff91b6dff7  libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
                              0x7fff91b6e000 -     0x7fff91b73ff7  libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
                              0x7fff91b8c000 -     0x7fff91b95fff  com.apple.speech.synthesis.framework (4.6.2 - 4.6.2) <0AAE45F0-FC6E-36B6-A6A7-73E6950A74AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                              0x7fff91b98000 -     0x7fff91baaff7  com.apple.MultitouchSupport.framework (245.13 - 245.13) <D5E7416D-45AB-3690-86C6-CC4B5FCEA2D2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                              0x7fff9211c000 -     0x7fff9220bfff  libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                              0x7fff92258000 -     0x7fff924a0fff  com.apple.CoreData (107 - 481) <E5AFBA07-F73E-3B3F-9099-F51224EE8EAD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                              0x7fff924a1000 -     0x7fff924a5fff  libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
                              0x7fff92510000 -     0x7fff9253fff5  com.apple.GSS (4.0 - 2.0) <ED98D992-CC14-39F3-9ABC-8D7F986487CC> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                              0x7fff92540000 -     0x7fff92545fff  libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
                              0x7fff92549000 -     0x7fff9292affe  libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                              0x7fff92956000 -     0x7fff929a7ff3  com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <BF4C2FE3-8BC8-30D1-8347-2A7221268794> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                              0x7fff929a8000 -     0x7fff92c92fff  com.apple.CoreServices.CarbonCore (1077.14 - 1077.14) <B00BEB34-A9F5-381F-99FD-11E405768A9A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                              0x7fff92eda000 -     0x7fff92effff7  com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                              0x7fff932a5000 -     0x7fff932f3fff  com.apple.opencl (2.3.57 - 2.3.57) <FC03A80D-543A-3448-83FF-D399C3A240D9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                              0x7fff932f4000 -     0x7fff932f6ff7  com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                              0x7fff93341000 -     0x7fff93347ff7  libsystem_platform.dylib (24.1.4) <331BA4A5-55CE-3B95-99EB-44E0C89D7FB8> /usr/lib/system/libsystem_platform.dylib
                              0x7fff93441000 -     0x7fff934abff7  com.apple.framework.IOKit (2.0.1 - 907.1.13) <C1E95F5C-B79B-31BE-9F2A-1B25163C1F16> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                              0x7fff93538000 -     0x7fff93538fff  com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                              0x7fff93539000 -     0x7fff9353cff7  libdyld.dylib (239.3) <62F4D752-4089-31A8-8B73-B95A68893B3C> /usr/lib/system/libdyld.dylib
                              0x7fff9353d000 -     0x7fff9353dfff  com.apple.Carbon (154 - 157) <45A9A40A-78FF-3EA0-8FAB-A4F81052FA55> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                              0x7fff9353e000 -     0x7fff93540ff7  libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
                              0x7fff9354c000 -     0x7fff93820fc7  com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                              0x7fff93821000 -     0x7fff93900fff  libcrypto.0.9.8.dylib (50) <B95B9DBA-39D3-3EEF-AF43-44608B28894E> /usr/lib/libcrypto.0.9.8.dylib
                              0x7fff9390d000 -     0x7fff9391aff0  libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
                              0x7fff9391b000 -     0x7fff93933ff7  com.apple.GenerationalStorage (2.0 - 160.2) <79629AC7-896F-3302-8AC1-4939020F08C3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                              0x7fff93934000 -     0x7fff93964fff  com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                              0x7fff939ab000 -     0x7fff939d2ffb  libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
                              0x7fff939d3000 -     0x7fff93a11ff7  libGLImage.dylib (9.0.83) <C08048A7-03CC-3E40-BCDC-7791D87AC8E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                              0x7fff93a5e000 -     0x7fff93a75fff  com.apple.CFOpenDirectory (10.9 - 173.1.1) <3FB4D5FE-860B-3BDE-BAE2-3531D919EF10> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                              0x7fff93ac2000 -     0x7fff93ad3ff7  libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
                              0x7fff93c62000 -     0x7fff93ebaff1  com.apple.security (7.0 - 55471) <233831C5-C457-3AD5-AFE7-E3E2DE6929C9> /System/Library/Frameworks/Security.framework/Versions/A/Security
                              0x7fff944df000 -     0x7fff94503fff  libxpc.dylib (300.1.17) <4554927A-9467-365C-91F1-5A116989DD7F> /usr/lib/system/libxpc.dylib
                              0x7fff94696000 -     0x7fff946e9fff  com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                              0x7fff946ea000 -     0x7fff94897f27  libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
                              0x7fff94977000 -     0x7fff94a40fff  com.apple.LaunchServices (572.23 - 572.23) <8D955BDE-2C4C-3DD4-B4D7-2D916174FE1D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                              0x7fff94a47000 -     0x7fff94a68ff7  libssl.0.9.7.dylib (106) <BBD44AF3-440F-34AB-A491-30975B53A18C> /usr/lib/libssl.0.9.7.dylib
                              0x7fff94a69000 -     0x7fff94aa3ff3  com.apple.bom (12.0 - 192) <989690DB-B9CC-3DB5-89AE-B5D33EDC474E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                              0x7fff9524d000 -     0x7fff95251ff7  libheimdal-asn1.dylib (323.12) <063A01C2-E547-39D9-BB42-4CC8E64ADE70> /usr/lib/libheimdal-asn1.dylib
                              0x7fff95274000 -     0x7fff95279fff  com.apple.DiskArbitration (2.6 - 2.6) <F8A47F61-83D1-3F92-B7A8-A169E0D187C0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                              0x7fff9528b000 -     0x7fff9528cff7  libsystem_sandbox.dylib (278.10) <A47E7E11-3C76-318E-B67D-98972B86F094> /usr/lib/system/libsystem_sandbox.dylib
                              0x7fff9572b000 -     0x7fff9575afd2  libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
                              0x7fff9601f000 -     0x7fff96020ff7  libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
                              0x7fff96023000 -     0x7fff96034ff7  libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
                              0x7fff96037000 -     0x7fff96052ff7  libPng.dylib (1038) <EF781AF8-C2E6-3179-B8A1-A584783070F1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                              0x7fff9606f000 -     0x7fff9607afff  libkxld.dylib (2422.1.72) <C88EF3E6-B31F-3E12-BE9B-562D912BA733> /usr/lib/system/libkxld.dylib
                              0x7fff9607b000 -     0x7fff960c8ff2  com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                              0x7fff96153000 -     0x7fff9616eff7  libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
                              0x7fff96179000 -     0x7fff961d4ffb  com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                              0x7fff961d8000 -     0x7fff962bcfff  com.apple.coreui (2.1 - 231) <432DB40C-6B7E-39C8-9FB5-B95917930056> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                              0x7fff962bd000 -     0x7fff962e2ff7  com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                              0x7fff962e3000 -     0x7fff962f0fff  com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                              0x7fff96812000 -     0x7fff9681dfff  libGL.dylib (9.0.83) <984A960A-C159-3AE5-8B40-E2B451F6C712> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                              0x7fff9681e000 -     0x7fff968ceff7  libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                              0x7fff96c60000 -     0x7fff96c68ff7  com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                              0x7fff96e6a000 -     0x7fff96e6aff7  libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
                              0x7fff971d1000 -     0x7fff9736dff7  com.apple.QuartzCore (1.8 - 332.0) <994D1E0A-64B6-398C-B9A2-C362F02DE943> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                              0x7fff9737d000 -     0x7fff9737dffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <6E89F3CB-CC41-3728-9F9A-FDFC151E8261> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                              0x7fff9753a000 -     0x7fff97839fff  com.apple.Foundation (6.9 - 1056) <D608EDFD-9634-3573-9B7E-081C7D085F7A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                              0x7fff97845000 -     0x7fff97846fff  libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
                              0x7fff97871000 -     0x7fff97878ff7  libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
                              0x7fff97879000 -     0x7fff9787aff7  libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
                              0x7fff9787b000 -     0x7fff978dfff9  com.apple.Heimdal (4.0 - 2.0) <E7D20A4D-4674-37E1-A949-635FFF7C439A> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                              0x7fff9798f000 -     0x7fff979cefff  libGLU.dylib (9.0.83) <8B457205-513B-3477-AE9C-3AD979D5FE11> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                              0x7fff97a4e000 -     0x7fff97a55fff  libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
                              0x7fff97a90000 -     0x7fff97b1ffff  com.apple.Metadata (10.7.0 - 800.12.2) <A9F5D471-8732-3F95-A4A2-33864B92A181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                              0x7fff97c8f000 -     0x7fff97cf2ff7  com.apple.SystemConfiguration (1.13 - 1.13) <F05F4149-981B-380B-8F50-51CE804BBB89> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                              0x7fff97d00000 -     0x7fff97eb8ff3  libicucore.A.dylib (511.27) <003B6C21-CBD1-3486-9A1D-030ADF5FA061> /usr/lib/libicucore.A.dylib
                              0x7fff97eb9000 -     0x7fff97f45ff7  com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                              0x7fff97f46000 -     0x7fff97f6aff7  libJPEG.dylib (1038) <86F349A8-882D-3326-A0B0-63257F68B1A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                              0x7fff97fb8000 -     0x7fff97fc1fff  com.apple.CommonAuth (4.0 - 2.0) <1D263127-5F27-3128-996D-7397660D0C6E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                              0x7fff97fc2000 -     0x7fff9801aff7  com.apple.Symbolication (1.4 - 129) <16D42516-7B5E-357C-898A-FAA9EE7642B3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                              0x7fff980b0000 -     0x7fff980bbff7  com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                              0x7fff980bc000 -     0x7fff980e5fff  com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                              0x7fff980f3000 -     0x7fff98263ff6  com.apple.CFNetwork (673.0.3 - 673.0.3) <42CFC3DB-35C8-3652-AF37-4BCC73D8BDEF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                              0x7fff9828e000 -     0x7fff9837cfff  libJP2.dylib (1038) <6C8179F5-8063-3ED6-A7C2-D5603DECDF28> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                          External Modification Summary:
                            Calls made by other processes targeting this process:
                              task_for_pid: 1
                              thread_create: 0
                              thread_set_state: 0
                            Calls made by this process:
                              task_for_pid: 0
                              thread_create: 0
                              thread_set_state: 0
                            Calls made by all processes on this machine:
                              task_for_pid: 164004
                              thread_create: 2
                              thread_set_state: 0
                          VM Region Summary:
                          ReadOnly portion of Libraries: Total=398.6M resident=238.5M(60%) swapped_out_or_unallocated=160.1M(40%)
                          Writable regions: Total=191.7M written=54.8M(29%) resident=69.0M(36%) swapped_out=4K(0%) unallocated=122.7M(64%)
                          REGION TYPE                      VIRTUAL
                          CG backing stores                  1928K
                          CG raster data                        8K
                          CG shared images                    204K
                          Image IO                           1928K
                          Kernel Alloc Once                     8K
                          MALLOC                            150.1M
                          MALLOC (admin)                       32K
                          MALLOC_LARGE (reserved)             9.8M        reserved VM address space (unallocated)
                          Memory Tag 242                       12K
                          STACK GUARD                        56.0M
                          Stack                              12.2M
                          VM_ALLOCATE                        2552K
                          __DATA                             35.0M
                          __IMAGE                             528K
                          __LINKEDIT                         99.6M
                          __TEXT                            299.0M
                          __UNICODE                           544K
                          mapped file                        31.2M
                          shared memory                         4K
                          TOTAL                             700.5M
                          TOTAL, minus reserved VM space    690.7M
                          Model: MacBookPro8,3, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 4 GB, SMC 1.70f6
                          Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
                          Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
                          Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                          Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                          AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.22)
                          Bluetooth: Version 4.2.0f6 12982, 3 services, 15 devices, 1 incoming serial ports
                          Network Service: Wi-Fi, AirPort, en1
                          Serial ATA Device: TOSHIBA MK7559GSXF, 750.16 GB
                          Serial ATA Device: MATSHITADVD-R   UJ-898
                          USB Device: FaceTime HD Camera (Built-in)
                          USB Device: Hub
                          USB Device: USB Receiver
                          USB Device: BRCM2070 Hub
                          USB Device: Bluetooth USB Host Controller
                          USB Device: Apple Internal Keyboard / Trackpad
                          USB Device: Hub
                          USB Device: GoFlex Mac
                          USB Device: iPhone
                          USB Device: IR Receiver
                          Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
                          • 10. Re: Undo is not working properly (grayed out)
                            Eudia Level 1
                            It has been almost a month. Any progress? Has this been addressed? Are you able to duplicate the problem with this?
                            • 11. Re: Undo is not working properly (grayed out)
                              BDinkar Adobe Employee
                              Sorry Eudia, I don't have a good news to share with you.
                              We are still trying to replicate the problem but not sure why this is not happening on our machines. There are other users facing the same problem and I am in touch with them. But still no success.
                              The crash you have posted above is something else and is not related to the undo issue.
                              Regards,
                              Dinkar
                              • 12. Re: Undo is not working properly (grayed out)
                                jennafer10
                                Has there been any resolution to this issue? I experience this problem about once or twice a week. I'll work on 30+ files a day and somewhere in the midst of this work, my save and undo options drop out for no apparent reason.
                                • 13. Re: Undo is not working properly (grayed out)
                                  Piers Hugill
                                  I have been having a similar problem too. I noticed it first on Photoshop and then the same thing started happening on InDesign. In my case Save is working OK, but I can only undo one action before Undo gets greyed out. I'm not really in a position to add anything as to the possible cause, but I would be very interested if any solution is found to this problem.
                                  Best, Piers
                                  • 14. Re: Undo is not working properly (grayed out)
                                    michaelvash
                                    I have had the same problem, I just toss the plist preferences and restart and that took care of it. Hope that helps.
                                    • 15. Re: Undo is not working properly (grayed out)
                                      BriGuyAG Level 1
                                      Just started noticing the same today. Actually, last night I noticed things become sluggish during saving/opening across the board, not just InDesign. Safari being slow to actually place text that I typed into the address/search box ("Hello, Safari, wake up! Are you going to do anything???"), OS X dragging its heels just opening a new window, etc. ... it's like things aren't "catching up."
                                      But today was the first time I noticed the undo issue. I went to undo a couple changes, but I couldn't get past a single undo. I could hit Cmd-Z once and it would work, but subsequent ones wouldn't do anything, and then I noticed that the menu command is grayed out.
                                      Like Eudia, I also have a 2011 MacBook Pro -- OS X 10.9.3, 2.5 GHz Intel Core i7, 8 GB 1333 MHz DDR3 RAM, latest Creative Cloud (2014) apps.
                                      Never seen this happen before, but will try some of the posts here (restart, trash plist files, etc.) and see if anything fixes itself.
                                      **Edit: crash on quit: windows/toolbars shut down, but "InDesign" still in OS X menu bar, spinning beach ball of death, then it finally went away but a big Apple crash report window opened saying that "InDesign quit unexpectedly." Crashed thread = 0 Main Thread Dispatch queue: com.apple.main-thread, so seems more like a system issue. I just finished rebooting my computer and so far, so good. Tested by making 8 different changes to the file I had open last time, from copying an item via Cmd-C and pasting it in another area to scaling another group of objects to adding text to moving something to a new location, and I was able to undo all of that, no problem. Just a weird fluke at the moment, I guess -- for me, anyway.**
                                      My current work environment (apps running simultaneously):
                                      InDesign CC (2014) (10.0.0.70 Build)
                                      Thunderbird (26.4.0) -- email
                                      Suitcase Fusion 5 (16.2.1)
                                      Photoshop CC (2014) only open when I need it
                                      Illustrator CC (2014) only open when I need it
                                      Time Machine -- backs up automatically/periodically to a 2 TB WD My Passport for Mac external HD connected via USB.
                                      For what it's worth:
                                      After rebooting, I opened Activity Monitor to see what happens as I launch various programs. What I noticed:
                                      1. InDesign would cycle between normal black text and red text with "Not Responding" next to the app name while it's loading its preferences/plug-ins/etc. (normal, I guess?)
                                      2. FMCore (part of Suitcase Fusion) showed as using over 100% CPU (i.e. 100.7%, 100.9%...) while InDesign started up, then dropped down to more normal levels after everything finished launching (currently using 0.6% CPU).
                                      • 16. Re: Undo is not working properly (grayed out)
                                        s peter Level 1
                                        I am having the same problem today for the first time.  I just updated this particular machine's CC Indesign on last Thursday and did not have this problem before I updated.  To be quite honest, that fact that Adobe can't duplicate the problem is not an excuse!  We pay monthly for this to work and I can definitely say that I didn't have any problems that I am experiencing now in comparison to before CC.
                                        My machine is running slow and I rarely run more than one CC product at a time.  Like others have stated, our workflow has not changed but CC has, and it becomes very obvious to us that YOU HAVE A PROBLEM and it is up to you to fix it!!!!
                                        The only thing that you guys might not be aware off is that I use Dropbox for all of my files.  I have 3 machines that connect to Dropbox.  2 of my machines including this one are associated with this account paid for by my client, and the other is a personal CC account that I pay for.  Let me quickly state that I have not had any major problems until CC came around.  At first it was my computers running slow.  Before that, everything ran fast.  And I have used Dropbox like this for the last 2 years.
                                        So maybe as you test, you may want to consider the fact that many of us use cloud storage or an external hard drive to handle all of our files and only have our software loaded to our computers.  Maybe you need to optimize how CC communicates with these secondary storage points.  I'm sure you guys found an excellent way for CC to communicate with your existing cloud service.
                                        Just a suggestion
                                        • 17. Re: Undo is not working properly (grayed out)
                                          alosastudio
                                          I am also having this issue where I can only undo twice in InDesign!  I just updated my CC two days ago and it was not happening until I did the update.
                                          • 18. Re: Undo is not working properly (grayed out)
                                            Rustman1971
                                            I am having the same issue with Undo being grayed out. Sometimes it allows for 2 undos before it craps out and other times as many as four. Seems to be related to type somehow and I can usually tell when it's about to happen because my text boxes will start to act funny. For instance, type will disappear when I move a text box or it will appear as though the text is all jumbled up on top of itself for an instant before resuming it's normal appearance. I had this issue with CC and now with CC 2014. Frustrated doesn't even begin to describe how this makes me feel.
                                            I'm using Font Book to manage my fonts.
                                            • 19. Re: Undo is not working properly (grayed out)
                                              spot-on Level 1
                                              I am also having this problem -- Undo is permanently grayed out!!  Brand-new MacBook Pro with 16GB RAM  running 10.9.4 and using CC, not upgraded to CC2014 yet. On my previous machine I was running CC on 10.9.3, and did not have this problem. No font management software used, no secondary storage devices.  Trashing the prefs in Home > Library >Preferences > Adobe InDesign > Version 9.0 > en_US does nothing. Rebooting the mac solves the problem temporarily, not sure how long it will last.
                                              Adobe, this is appalling, please throw more engineers at the problem and find a fix!
                                              • 20. Re: Undo is not working properly (grayed out)
                                                davidsless
                                                I had the same issue. Very frustrating! I tracked it down to an issue with fonts. In particular, I found that it was something to do with Suitcase Fusion and possibly that some of my fonts had got corrupted. I did a big cleanup using FontDoctor and, reactivated FontBook alongside occaissionaly using  Suitcase Fusion. All is OK now. I lost 3 days work and a couple of days to put it all right. A week in total. So much for software improving productivity!
                                                Come on Adobe, pull your finger out. Life is too short!
                                                • 21. Re: Undo is not working properly (grayed out)
                                                  Hello All,
                                                  We are really very sorry about the trouble you all are facing because of this issue.
                                                  It would be really helpful if few of you can spare some time and work with us so that we can narrow down this problem. If you are able to reproduce this problem consistently then please write to us on sharewithID@adobe.com. We will then work with you over a connect session depending upon your convenient time.
                                                  Dinkar
                                                  InDesign Engineering
                                                  • 22. Re: Undo is not working properly (grayed out)
                                                    paperscout
                                                    I've been experiencing this problem since updating to CC 2014. It has progressively getting worse (allowing me to undo less times) and now will not let me undo at all. Very frustrating!! Please let me know what info I can share to help resolve the issue.
                                                    • 23. Re: Undo is not working properly (grayed out)
                                                      seancwood
                                                      My InDesign CC just began exhibiting this no-undo-no-save behavior today.
                                                      I'm about to close InDesign, so let's hope the recovery files work fine.
                                                      Love to see a fix on this, as I find saving a file quite important to my workflow.
                                                      • 24. Re: Undo is not working properly (grayed out)
                                                        By now this is hours too late, but in order to have a recovery file, ID would have to close abnormally (power failure or Force Quit), not just close the program without saving...
                                                        • 25. Re: Undo is not working properly (grayed out)
                                                          Tom Usrey 2 Level 1
                                                          You should have exported your file to IDML before closing it.
                                                          • 26. Re: Undo is not working properly (grayed out)
                                                            seancwood Level 1
                                                            Thanks, I force quit and there was a semi-decent recovery file.
                                                            • 27. Re: Undo is not working properly (grayed out)
                                                              seancwood Level 1
                                                              Good tip—thanks, I force quit and there was a semi-decent recovery file.
                                                              • 28. Re: Undo is not working properly (grayed out)
        nake
        HI I'm working on a brand new Power Book and have all software up to date. However I can only go 2 steps back in InDesign and my textbox whitens the text occasionally. WhenI zoom in or out it's visible again. Really interferes with my work. How can I resolve this asap?
        • 29. Re: Undo is not working properly (grayed out)
        Hello All,
        We have just released a new InDesign update ( InDesign CC 2014.1, Version 10.1.0.71). We have tried fixing the limited undo problem in this update. Kindly update to the latest version and let us know your feedback on this issue.
        Thanks and Regards,
        Dinkar
        • 30. Re: Undo is not working properly (grayed out)
        jokki
        I am having the same problem: can't undo, redo, copy or paste. I don't think it's a RAM issue as I have 16Gb of RAM, which surely is sufficient. Needless to say I am profoundly disappointed and amazed that a company I have always held in high regard allows this sort of nonsense to occur. I am using the latest Version 10.1.0.71, but will go back to using last year's version in the meantime. I am also running Suitcase Fusion 4, which doesn't appear to be working properly as the fonts won't load automatically, so that could be causing a conflict? Perhaps it's a ploy by Adobe to shut out third-party font management vendors?
        • 31. Re: Undo is not working properly (grayed out)
        jokki Level 1
        Thought I could go back to using InDesign CC Version 9.2.2, but even with Suitcase closed the same problem is still happening, so I'm well and truly stumped now. It's really shattering my illusions about the excellence of Adobe products.
        • 32. Re: Undo is not working properly (grayed out)
        jokki Level 1
        This is really bad. Even when I run InDesign CS4 now there is no undo, so something has corrupted all my old versions of InDesign too. UNBELIEVABLE!! Will try a complete restart.
