2 Replies Latest reply on Jan 23, 2014 2:39 PM by r00sevelt
    tilt shift lens effect ?
    r00sevelt
      How do you approximate the effect of a tilt shift lens using Photoshop ?
      Any suggestions greatly appreciated.
        • 1. Re: tilt shift lens effect ?
          Pixelbender Level 1
          There's a filter for these effects included since PS CS 6
          http://www.photoshopessentials.com/photo-effects/miniature-tilt-shift-cs6/
          If you dont want to use these filters theres another workaround. (CS 6)
          - Duplicate your backgroundlayer or the layer on which you want to apply this effect.
             (convert it into a smart-object, if you want to adjust the strength of the filter at any time)
          - Go to 'filters' -> 'Blur' --> 'Gaussian blur'
              Set the filter to an amount which works fine for you.
          - After you hit OK the whole image will be blurry.
          - Now create a new layer-mask for the blurry layer.
          - select the gradient tool (shortcut 'G' or 'Shift+G' on your keyobard)
              Make sure you have the mask selected. (white border around the miniature of the layer-mask)
          - Now set the gradient style on 'reflective' and draw a gradient on that mask.
          Hope this helps.
          • 2. Re: tilt shift lens effect ?
            r00sevelt Level 1
            Thank you for the ready help.
            I'll try it.
