1 Reply Latest reply on Jan 23, 2014 4:29 PM by Steve Werner
    Rotate Documents
    Sudsbucket
      How do I rotate an entire document for gang printing not just viewing? CS4 allows one to Select all, Group, Transform CW or CCW and the entire document rotates. This is ideal to placing documents on a larger document size in such a way as to print your document in multiples.
      CC seems to rotate objects and not the document or canvas. Plus, the object boxes rotate but the text does not.
        • 1. Re: Rotate Documents
          Steve Werner Adobe Community Professional & MVP
          It sounds like you need prepress imposition software. Except for the simplest of layouts (which can be done with File > Print Booklet), this is not done in InDesign.
          In today's workflows, this is usually either done with PDF files, or using the software in your RIP.
          I'd ask in the Acrobat forums for recommendatons for PDF imposition software.
