4 Replies Latest reply on Jan 27, 2014 11:18 PM by claursen
    Changing sorting order for symbol/button.
    claursen Level 1
      I have a line of buttons (that are close to eachother). When clicked they scale up large.
      Problem is that the button clicked isn't arranged/sorted to the front and thereby is behind
      other buttons next to it.
      How do I change the sorting order (inside the button/symbol) when it is clicked?
        • 1. Re: Changing sorting order for symbol/button.
          Saurav Adobe Employee
          Hi Claursen,
          In the click event of the button you can add the following command :-
          I have asumed  that my symbol name is "btn1"
          var el = sym.getSymbol("btn1").getSymbolElement();
          el.css("z-index","1");
          By doing this the symbol will appear on top of other symbols . Hopw it helps
          Saurav
          • 2. Re: Changing sorting order for symbol/button.
            claursen Level 1
            Hi Saurav,
            Thanks for your reply! Very much appreciated.
            This was exactly what I was looking for. A line of code that could stack/sort the symbol.
            Unfortunately when I tried putting it in, it didn't work. Not sure what i'm doing wrong. I changed
            the btnl to my symbol name and tried both putting it in under mouseover and down.
            There's a lot of layers for this, dont know if that could be the issue. I tried changing the z index
            to 5. Still nothing. I have basically the stage, a symbol that covers most of the stage, inside that
            I have a symbol that holds all the buttons and inside that i have the buttons.
            Any idea what it might be?
            • 3. Re: Changing sorting order for symbol/button.
              Hi Claursen,
              This is what I did to reproduce your scenario :-
              1.On stage I create a symbol , inside that I created another symbol and inside the nested symbol I created 3 symbols and named them "btn1" , "btn2" , "btn3".
              2.Now I opened the actions of symbol "btn1" and for click event I  wrote the following code
              el.css("transform","scale(4,4)");
              Similarly I put the code for click events for "btn2" and "btn3"
              3.Now When I published the file and clicked on any of the three symols , It scaled and was visible on top of the other symbols.
              Correct me if this is not the scenario you are facing .
              Saurav
              • 4. Re: Changing sorting order for symbol/button.
                claursen Level 1
                Yes, that worked. Thanks a lot!!!
