12 Replies Latest reply on Jun 20, 2006 4:54 AM by Newsgroup_User
    random without 0
    hcinderela
      I am constructing a simple guess the number game. I need the computer to pick a number between 1 and 10. Currently I am using random (11) but that still includes 0. How can I exclude it?
        • 1. Re: random without 0
          NSurveyor Level 2
          random(10) gives 0 through 9.... which means
          random(10)+1 gives 1 through 10! :)
          Also random is deprecated.. it stills works, but it's better to use:
          Math.ceil(Math.random()*11)
          Math.random() gives you a random decimal between 0 and 1 (exclusive).
          Math.random()*11 gives you a random decimal between 0 and 11 (exclusive).
          If we round this value up, we should get an integer ranging from 1 to 11.
          • 2. Re: random without 0
            Level 7
            Doh ... You add one!!
            eg. Math.floor(Math.random()*10)+1;
            Jeckyl
            • 3. Re: random without 0
              NSurveyor Level 2
              Whoops... I messed up the second half of my post. It would be:
              Math.ceil(Math.random()*10)
              Jeckyl's way works, too.
              • 4. Re: random without 0 - Math.ceil does NOT work
                Level 7
                No .. Math.ceil won't work .. because Math.ceil(0) is 0 .. so you could
                still get a zero value.(and consequently a slightly smaller change of
                getting 10 compared to other numbers)
                You would need to use instead the method I posted before.
                jeckyl
                • 5. Re: random without 0 - Math.ceil does NOT work
                  NSurveyor Level 2
                  My bad. I always thought 0<Math.random()<1, but now that I take a close look in the Help Docs, I see that it "Returns a pseudo-random number n, where 0 <= n < 1"
                  • 6. Re: random without 0
                    Level 7
                    Hi!
                    // returns a random number between (and including) a and b
                    getRandom = function(a,b) {
                    return Math.round(Math.random()*(b-a))+a;
                    var myNumber = getRandom(1,10);
                    /Jensen/
                    "hcinderela" <webforumsuser@macromedia.com> wrote in message
                    news:e77cjp$b3p$1@forums.macromedia.com...
                    • 7. Re: random without 0- math.round solution no good
                      Level 7
                      That's just as bad .. it doesn't return even distribution .. the values for
                      a and b are half as likely than other values
                      So best is still
                      or if you want whole number between a and b inclusive
                      Math.floor(Math.random()*(b-a+1))+a;
                      Jeckyl
                      • 8. Re: random without 0- math.round solution no good
                        Level 7
                        Well, I ran some tests which proves your statement wrong based on empirical
                        results. Code code included below.
                        I got the following results:
                        repeatNr = 1000000:
                        undefined,111304,111303,111305,111303,111302,111307,111303,111302,111300
                        repeatNr = 100000:
                        undefined,11187,11191,11193,11189,11190,11192,11192,11192,11191
                        repeatNr = 10000:
                        undefined,1091,1092,1093,1095,1095,1094,1090,1091,1092
                        repeatNr = 1000:
                        undefined,99,99,98,92,100,100,100,99,101
                        repeatNr = 100:
                        undefined,12,7,9,10,9,8,9,11,9
                        // My modified code:
                        var repeatNr = 1000000;
                        var L:Array = new Array();
                        for (var i = 1; i < 10; i++) {
                        L = 0;
                        for (var i = 0; i < repeatNr; i++) {
                        L[getRandom(1,9)]++;
                        trace(L);
                        "Jeckyl" <jeckyl@hyde.com> wrote in message
                        news:e789e9$bda$1@forums.macromedia.com...
                        > for a and b are half as likely than other values
                        > So best is still
                        > Jeckyl
                        • 9. Re: random without 0- math.round solution no good
                          NSurveyor Level 2
                          Jeckyl is right. Theoretically, you will only get a, when Math.round(Math.random()*(b-a)) is equal to 0. This is only true, when 0<=Math.random()*(b-a) < 0.5. For the next value, a+1, Math.round(Math.random()*(b-a)) must equal 1. This occurs only when 0.5<=Math.random()*(b-a)<1.5 (notice the broader range than a's). This continues for all values up to b. However, at b...
                          You will only get b, when Math.round(Math.random()*(b-a)) is equal to b-a. This is only true when b-a-0.5<=Math.random()*(b-a)<b-a. A and B is half as likely as all the other numbers.
                          • 10. Re: random without 0- math.round solution no good
                            Level 7
                            You've got faulty code to test a faulty function, so your results are
                            incorrect.
                            Your test script is faulty because of this line...
                            This actually calls the random number function twice .. once to get the
                            value and once to store the answer back again. ie the code as compiled is
                            the same as
                            > L[getRandom(1,9)] = L[getRandom(1,9)]+1;
                            If you correct your test code, then you get the correct sort of results...
                            eg
                            var repeatNr = 10000;
                            var L = new Array();
                            L = 0;
                            var r = getRandom(1,9);
                            L[r]++;
                            trace(L
                            Give you the results:
                            616
                            1297
                            1244
                            1235
                            1271
                            1212
                            1205
                            1292
                            628
                            Jeckyl
                            • 11. Re: random without 0- math.round solution no good
                              Level 7
                              As further evidence that your results are faulty .. look at this:
                              repeatNr = 100:
                              The sum of all the values should add to give 100 is you got it right ..
                              instead you get 84
                              Jeckyl
                              • 12. Re: random without 0- math.round solution no good
                                Level 7
                                Hmm ... interesting. I agree with the logic, I just couldn't support it with
                                the test ... I see now why. Thanks :-)
                                news:e78n7e$sro$1@forums.macromedia.com...
                                > incorrect.
                                > the same as
                                > eg
                                > L = 0;
                                > L[r]++;
                                > trace(L
                                > 616
                                > 1297
                                > 1244
                                > 1235
                                > 1271
                                > 1212
                                > 1205
                                > 1292
                                > 628
                                > Jeckyl
