9 Replies Latest reply on Jul 29, 2015 6:03 PM by Trevor.Dennis
    Perspective Warp is greyed out
    North88
      I have Photoshop CC 14.2 installed.  Perspective warp is greyed out.  How do I get perspective warp to appear?
        • 1. Re: Perspective Warp is greyed out
          Enable GPU support under Preferences --> Performance --> Advanced --> Use for computations
          Mylenium
          • 2. Re: Perspective Warp is greyed out
            mikephotog
            I have tried the suggested solution, to no effect.
            Clicked on Advanced. in the Drawing mode; "Use Graphics Processor to Acceelerate Computation" is greyed out.
            "Use OpenCL" is greyed out
            There is a tick in the box "Anti-Alias Guides and Paths"
            Is it a proble with my Graphics Processor?  NVIDIA GeForce GT 120 OpenGL Engine.
            Any further thoughts would be appreciated
            mikephotog
            • 3. Re: Perspective Warp is greyed out
              Use menu Help>System Info...  Look ate the GPU section is your GPU shown with ate least 512MB of Vram the your card has.  512MB is required for Photoshop support.  You should also see CC level the it should be 14.2.1 not the 14.2 in you append.  Make sure you have the latest drivers for you card and OS.
              Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64 <------------------------------------------ 14.2.1
              Operating System: Windows 7 64-bit
              Version: 6.1 Service Pack 1
              System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
              Physical processor count: 12
              Logical processor count: 24
              Processor speed: 1995 MHz
              Built-in memory: 40886 MB
              Free memory: 34544 MB
              Memory available to Photoshop: 37152 MB
              Memory used by Photoshop: 90 %
              Image tile size: 1028K
              Image cache levels: 4
              Font Preview: Extra Large
              TextComposer: Latin
              Display: 1
              Display Bounds: top=0, left=0, bottom=1080, right=1920
              Display: 2
              Display Bounds: top=0, left=-1360, bottom=768, right=0
              OpenGL Drawing: Enabled. <------------------------------------------------------------------------------------- enabled -----------------------------------
              OpenGL Allow Old GPUs: Not Detected.
              OpenGL Drawing Mode: Advanced
              OpenGL Allow Normal Mode: True.
              OpenGL Allow Advanced Mode: True.
              AIFCoreInitialized=1
              AIFOGLInitialized=1
              OGLContextCreated=1
              NumGPUs=1
              gpu[0].OGLVersion="3.0"
              gpu[0].MemoryMB=2048 <---------------------------------------------------------------------------------------- ------------------------------ min 512
              gpu[0].RectTextureSize=16384
              gpu[0].Renderer="Quadro 4000/PCIe/SSE2"
              gpu[0].RendererID=1757
              gpu[0].Vendor="NVIDIA Corporation"
              gpu[0].VendorID=4318
              gpu[0].HasNPOTSupport=1
              gpu[0].DriverVersion="9.18.13.3276" <---------------------------------------------------------------------------------------- -------------- driver version
              gpu[0].Driver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
              gpu[0].DriverDate="20140304000000.000000-000" <------------------------------------------------------------------------------------ driver date
              gpu[0].CompileProgramGLSL=1
              gpu[0].TestFrameBuffer=1
              gpu[0].OCLPresent=1
              gpu[0].OCLVersion="1.1"
              gpu[0].CUDASupported=1
              gpu[0].CUDAVersion="6.0.1"
              gpu[0].OCLBandwidth=7.49936e+010
              gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
              gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
              gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
              gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
              gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
              gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
              gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
              gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
              gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
              gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
              gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
              gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
              gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
              gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
              gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
              gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
              gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
              gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
              gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
              gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
              gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
              • 4. Re: Perspective Warp is greyed out
                mikephotog Level 1
                Thanks - what a list!
                Here is mine to the same point.  I am using iMac 24inch early 2009.
                I think that I am not able to upgrade the Graphics card or the driver.
                Operating System: Mac OS 10.9.2
                System architecture: Intel CPU Family:6, Model:23, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
                Physical processor count: 2
                Processor speed: 2930 MHz
                Built-in memory: 4096 MB
                Free memory: 2141 MB
                Memory available to Photoshop: 3587 MB
                Memory used by Photoshop: 70 %
                Image tile size: 128K
                Font Preview: Medium
                TextComposer: Latin
                The GPU Sniffer crashed on 06/01/2014 at 20:56:11
                Display: 1
                Main Display
                Display Bounds: top=0, left=0, bottom=1200, right=1920
                Display: 2
                Display Bounds: top=176, left=1920, bottom=1200, right=3200
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGPUs=1
                gpu[0].OGLVersion="2.1"
                gpu[0].MemoryMB=256
                gpu[0].RectTextureSize=8192
                gpu[0].Renderer="NVIDIA GeForce GT 120 OpenGL Engine"
                gpu[0].RendererID=16918028
                gpu[0].OCLPresent=1
                gpu[0].OCLVersion="1.2 (Dec  8 2013 21:07:05)"
                gpu[0].CUDASupported=0
                gpu[0].OCLBandwidth=1.29941e+10
                gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
                gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                • 5. Re: Perspective Warp is greyed out
                  Your VRAM is shown as 256MB.   Photoshop requires 512MB or more....
                  • 6. Re: Perspective Warp is greyed out
                    mikephotog Level 1
                    Many thanks.  I expect to upgrade the NVIDIA card is expensive.
                    It is a shame that there is this restriction in the software/hardware.
                    Many thanks
                    • 7. Re: Perspective Warp is greyed out
                      It a requirement not a restriction does your car go without gas if its a gas car no it requires gas.   Perspective warp  code requires a GPU with 512MB VRAM.  The specs I see for you video card list 512MB. http://www.geforce.com/hardware/desktop-gpus/geforce-gt-120/specifications Do you have the latest driver?   Photoshop is only seeing 256MB.
                      • 8. Re: Perspective Warp is greyed out
                        raonimadalena
                        Hi, JJMack. If you help me with this, I would be very glad. My GPU appears with 1008Mb of memory and it is still not enabling the perspective warp option. I sepparated infos u highlighted here:
                        OpenGL Drawing Mode: Basic
                        OpenGL Allow Normal Mode: False.
                        OpenGL Allow Advanced Mode: False.
                        whole profile (portuguese can't understand why my CC is not enabling english language on photoshop):
                        Versão Adobe Photoshop: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x32
                        Sistema Operacional: Windows 7 64-bits
                        Versão: 6.1 Service Pack 1
                        Arquitetura do sistema: Intel Família CPU:6, Modelo:10, Etapa:7 com MMX, número inteiro SSE, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
                        Contagem de processadores físicos: 4
                        Velocidade do processador: 2793 MHz
                        Memória interna: 12192 MB
                        Memória livre: 6800 MB
                        Memória disponível para Photoshop: 3255 MB
                        Memória usada pelo Photoshop: 60 %
                        Tamanho de ladrilhos de cache: 128K
                        Níveis do cache de imagem: 1
                        Visualização da fonte: Média
                        Compositor de texto: Latim
                        Vídeo: 1
                        Limites do monitor: parte superior= 0, esquerda= 0, parte inferior= 1080, direita= 1920
                        Desenho do OpenGL: Ativado.
                        Permitir GPUs antigos do OpenGL: Não detectado.
                        Modo de desenho do OpenGL: Básico
                        Permitir modo normal do OpenGL: Falso.
                        Permitir modo avançado do OpenGL: Falso.
                        AIFOGLInitialized=1
                        OGLContextCreated=1
                        NumGPUs=1
                        gpu[0].MemoryMB=1808
                        gpu[0].RectTextureSize=4096
                        gpu[0].Renderer="Intel(R) HD Graphics Family"
                        gpu[0].RendererID=258
                        gpu[0].Vendor="Intel"
                        gpu[0].VendorID=32902
                        gpu[0].DriverVersion="8.15.10.2291"
                        gpu[0].Driver="igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32"
                        gpu[0].DriverDate="20110127000000.000000-000"
                        gpu[0].OCLPresent=0
                        gpu[0].OCLBandwidth=0
                        gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30  - Intel Build 8.15.10.2291"
                        gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
                        gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
                        gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
                        gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
                        gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
                        Tipo de licença: Assinatura
                        Número de série: 96040780495635177048
                        Pasta do aplicativo: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\
                        Demarcador de arquivo temporário: C:\Users\EDIELS~1\AppData\Local\Temp\
                        O rascunho do Photoshop tem E/S ***íncrona ativado
                        Volume de trabalho(s):
                        C:\, 557,2G, 195,8G livre
                        Pasta de plug-ins necessários: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\Required\Plug-Ins\
                        Pasta Plug-ins Primários: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\Plug-ins\
                        Componentes instalados:
                           ACE.dll   ACE 2013/10/29-11:47:16   79.548223   79.548223
                           adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
                           AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
                           AdobeOwl.dll   Adobe Owl 2013/10/25-12:15:59   5.0.24   79.547804
                           AdobePDFL.dll   PDFL 2013/10/29-11:47:16   79.508720   79.508720
                           AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1786
                           AdobeXMP.dll   Adobe XMP Core 2013/10/29-11:47:16   79.154911   79.154911
                           AdobeXMPFiles.dll   Adobe XMP Files 2013/10/29-11:47:16   79.154911   79.154911
                           AdobeXMPScript.dll   Adobe XMP Script 2013/10/29-11:47:16   79.154911   79.154911
                           adobe_caps.dll   Adobe CAPS   7,0,0,21
                           AGM.dll   AGM 2013/10/29-11:47:16   79.548223   79.548223
                           ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
                           aif_core.dll   AIF   5.0   79.534508
                           aif_ocl.dll   AIF   5.0   79.534508
                           aif_ogl.dll   AIF   5.0   79.534508
                           amtlib.dll   AMTLib   7.0.0.249 BuildVersion: 7.0; BuildDate: Thu Nov 14 2013 15:55:50)   1.000000
                           ARE.dll   ARE 2013/10/29-11:47:16   79.548223   79.548223
                           AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                           AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                           Bib.dll   BIB 2013/10/29-11:47:16   79.548223   79.548223
                           BIBUtils.dll   BIBUtils 2013/10/29-11:47:16   79.548223   79.548223
                           boost_date_time.dll   DVA Product   7.0.0
                           boost_signals.dll   DVA Product   7.0.0
                           boost_system.dll   DVA Product   7.0.0
                           boost_threads.dll   DVA Product   7.0.0
                           cg.dll   NVIDIA Cg Runtime   3.0.00007
                           cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                           CIT.dll   Adobe CIT   2.1.6.30929   2.1.6.30929
                           CITThreading.dll   Adobe CITThreading   2.1.6.30929   2.1.6.30929
                           CoolType.dll   CoolType 2013/10/29-11:47:16   79.548223   79.548223
                           dvaaudiodevice.dll   DVA Product   7.0.0
                           dvacore.dll   DVA Product   7.0.0
                           dvamarshal.dll   DVA Product   7.0.0
                           dvamediatypes.dll   DVA Product   7.0.0
                           dvaplayer.dll   DVA Product   7.0.0
                           dvatransport.dll   DVA Product   7.0.0
                           dvaunittesting.dll   DVA Product   7.0.0
                           dynamiclink.dll   DVA Product   7.0.0
                           ExtendScript.dll   ExtendScript 2013/10/30-13:12:12   79.546835   79.546835
                           FileInfo.dll   Adobe XMP FileInfo 2013/10/25-03:51:33   79.154511   79.154511
                           filter_graph.dll   AIF   5.0   79.534508
                           icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                           icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                           imslib.dll   IMSLib DLL   7.0.0.145
                           JP2KLib.dll   JP2KLib 2013/10/29-11:47:16   79.248139   79.248139
                           libeay32.dll   The OpenSSL Toolkit   0.9.8g
                           libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                           libiomp5md.dll   Intel(R) OMP Runtime Library   5.0
                           libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                           LogSession.dll   LogSession   2.1.2.1785
                           mediacoreif.dll   DVA Product   7.0.0
                           MPS.dll   MPS 2013/10/29-11:47:16   79.535029   79.535029
                           msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                           msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                           msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                           msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
                           msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                           msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                           msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                           msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
                           msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                           msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                           PatchMatch.dll   PatchMatch 2013/10/29-11:47:16   79.542390   79.542390
                           pdfsettings.dll   Adobe PDFSettings   1.04
                           Photoshop.dll   Adobe Photoshop CC   CC
                           Plugin.dll   Adobe Photoshop CC   CC
                           PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (32 bit)   4.2.0.36
                           PSArt.dll   Adobe Photoshop CC   CC
                           PSViews.dll   Adobe Photoshop CC   CC
                           SCCore.dll   ScCore 2013/10/30-13:12:12   79.546835   79.546835
                           ScriptUIFlex.dll   ScriptUIFlex 2013/10/30-13:12:12   79.546835   79.546835
                           shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
                           ssleay32.dll   The OpenSSL Toolkit   0.9.8g
                           svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                           tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
                           tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
                           updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
                           WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
                        Plug-ins necessários:
                           3D Studio 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Afresco 14.2.1
                           Aquarela 14.2.1
                           Arestas Acentuadas 14.2.1
                           Arestas Brilhantes 14.2.1
                           Arestas Posterizadas 14.2.1
                           Arestas Rasgadas 14.2.1
                           Assimetria 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Baixo-Relevo 14.2.1
                           Bastão de Borrar 14.2.1
                           Bico de Pena 14.2.1
                           BMP 14.2.1
                           Bordado 14.2.1
                           Brilho Difuso 14.2.1
                           Camera Raw 8.4
                           Carvão 14.2.1
                           Centro da Medida 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Cineon 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Cisalhamento 14.2.1
                           Collada 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Coordenadas Polares 14.2.1
                           Cores NTSC 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Correção de Lente 14.2.1
                           Cortar e corrigir fotos 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Craquelé 14.2.1
                           Crayon Conté 14.2.1
                           Cristalizar 14.2.1
                           Cromo 14.2.1
                           Curtose 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Demarcadores para o Illustrator 14.2.1
                           Desentrelaçamento 14.2.1
                           Desfoque de Lente 14.2.1
                           Desfoque Inteligente 14.2.1
                           Desfoque Radial 14.2.1
                           Desvio Padrão 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Dicom 14.2.1
                           Dissolver 14.2.1
                           Eazel Acquire 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Embutir marca d'água 4.0
                           Entropia 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Esferização 14.2.1
                           Espátula 14.2.1
                           Esponja 14.2.1
                           Estampa 14.2.1
                           Extrusão 14.2.1
                           Fibras 14.2.1
                           Filtro Camera Raw 8.4
                           Filtro Cortar e Corrigir Fotos 14.2.1
                           Filtro do Pacote de Figuras 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Flash 3D 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Formato IFF 14.2.1
                           Foto Granulada 14.2.1
                           Fotocópia 14.2.1
                           Galeria de filtros 14.2.1
                           Gesso 14.2.1
                           GIF da CompuServe 14.2.1
                           Giz e Carvão 14.2.1
                           Google Earth 4 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Grande angular adaptável 14.2.1
                           Granulado 14.2.1
                           Hachura 14.2.1
                           HDRMergeUI 14.2.1
                           Intervalo 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           JPEG 2000 14.2.1
                           Ladrilhos 14.2.1
                           Ladrilhos do Mosaico 14.2.1
                           Lápis de Cor 14.2.1
                           Ler marca d'água 4.0
                           Marola 14.2.1
                           Matlab Operation 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Matriz de Meio-Tom 14.2.1
                           Máximo 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Mecanismo 3D do Photoshop 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Média 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Mediana 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Meia-Tinta 14.2.1
                           Meio-Tom em Cores 14.2.1
                           Mesclagem 14.2.1
                           Mínimo 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Néon 14.2.1
                           Nuvens 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Nuvens por Diferença 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Ondas 14.2.1
                           Ondulação 14.2.1
                           OpenEXR 14.2.1
                           Papel de Carta 14.2.1
                           Papel Molhado 14.2.1
                           Pastéis Ásperos 14.2.1
                           PCX 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Photoshop Touch 14.0
                           Pincel a Seco 14.2.1
                           Pintura a óleo 14.2.1
                           Pixar 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Plastificação 14.2.1
                           PNG 14.2.1
                           Pontilhar 14.2.1
                           Ponto de Fuga 14.2.1
                           Portable Bit Map 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Radiance 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Rastro da Tinta 14.2.1
                           Recorte de Arestas 14.2.1
                           Redemoinho 14.2.1
                           Redução de vibração 14.2.1
                           Reflexo de Flash 14.2.1
                           Respingo 14.2.1
                           Reticulação 14.2.1
                           Rotinas FastCore 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Rotinas MMXCore 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Salvar para Web 14.2.1
                           Solarização 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Somatória 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           STL 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Sucção 14.2.1
                           Sumi-e 14.2.1
                           Suporte a Multiprocessamento 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Suporte para Scripts 14.2.1
                           Suporte WIA 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Targa 14.2.1
                           Texturizador 14.2.1
                           Tinta-Base 14.2.1
                           Toques de Tinta 14.2.1
                           Traçado Angular 14.2.1
                           Traçado Borrifado 14.2.1
                           Traçado Escuro 14.2.1
                           Variações 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Variância 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Vento 14.2.1
                           Vidro 14.2.1
                           Vitral 14.2.1
                           Wavefront|OBJ 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           WBMP 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00)
                           Ziguezague 14.2.1
                        Plug-ins opcionais e de terceiros: NENHUM
                        Plug-ins com falha no carregamento: NENHUM
                        Flash:
                           Mini Bridge
                           Kuler
                           Adobe Exchange
                        Dispositivos TWAIN instalados: NENHUM
                        • 9. Re: Perspective Warp is greyed out
                          Trevor.Dennis Adobe Community Professional (Moderator)
                          Your Drawing Mode is set to Basic, and Perspective Warp requires Drawing Mode to be set to Advanced.  Go to Preferences > Performance > Advanced settings, and change to Advanced.  If Advanced is greyed out, your only hope is to update the video card driver.  I struggled to find the card and driver because of the language, so can you tell us what you are using?
                          [EDIT]  If you are unable to access Perspective Warp, and can give you a workaround if you need it.  PW is a godsend when making composites.
