1. Re: Form Crashes When Adjusting Rows In Table
meem23 Jan 27, 2014 4:30 AM (in response to meem23)Can someone tell me if this is a bug or what am I doing wrong. Thanks
2. Re: Form Crashes When Adjusting Rows In Table
Magus069 Jan 27, 2014 8:21 AM (in response to meem23)When you say you copied a table from Excel, do you mean you imported the table or you created all the object to have the same table in your PDF Form?
3. Re: Form Crashes When Adjusting Rows In Table
meem23 Jan 27, 2014 8:27 AM (in response to Magus069)I selected the cells from Excel, copied and then pasted into LC.
4. Re: Form Crashes When Adjusting Rows In Table
Magus069 Jan 27, 2014 8:31 AM (in response to meem23)You might want to copy the whole table manually in LiveCycle...
You have more chances to have less bugs..
5. Re: Form Crashes When Adjusting Rows In Table
meem23 Jan 27, 2014 8:34 AM (in response to meem23)so you are saying this is a bug?
6. Re: Form Crashes When Adjusting Rows In Table
Magus069 Jan 27, 2014 8:49 AM (in response to meem23)Yea well, unless you work hard and long enough to be able to fix everything...
Because I don't think that importing tables from other documents is the best tool on LiveCycle... even exporting data from PDF to Excel Spreadsheet...
Is the table you trying to import is complex or simple?
7. Re: Form Crashes When Adjusting Rows In Table
meem23 Jan 27, 2014 8:52 AM (in response to Magus069)A lot of rows with just text.
8. Re: Form Crashes When Adjusting Rows In Table
Magus069 Jan 27, 2014 9:30 AM (in response to meem23)Row count vary depending on data or fixed dimension?
Can the user add row instances?
9. Re: Form Crashes When Adjusting Rows In Table
meem23 Jan 27, 2014 9:45 AM (in response to Magus069)Fixed dimension and user can't add rows. These are basically grids to show a range of payments for various ages.
10. Re: Form Crashes When Adjusting Rows In Table
Magus069 Jan 27, 2014 9:49 AM (in response to meem23)If you don't want to restart and create the tables by yourself you can send me your PDF or send me any image in here... maybe I can fix it, but I am not sure...
If you want to send me you PDF, I'll send you my email on PM
