1. Re: Want to superimpose text on graphic frame?
straightlife Jan 24, 2014 4:06 PM (in response to straightlife)Wow! Found THIS! Only affects text beneath. But of course now I have to go back and move graphics to top layer. If there's any other way, let me know. Please.
2. Re: Want to superimpose text on graphic frame?
P Spier Jan 24, 2014 4:14 PM (in response to straightlife)Text frame options > Check the box in the lower left to Ignore Text Wrap (and turn off only affects text below).
3. Re: Want to superimpose text on graphic frame?
straightlife Jan 24, 2014 4:53 PM (in response to P Spier)Peter, that won't work because the rest of the text,THE STORY, no longer wraps.
And "only affects text below" is a problem because I'm anchoring the objects so they'll flow with the story text. So if I go back and move all my objects to the top layer, which I tried doing, the minute I re-anchor them to the text, they go back to the lowest layer.
4. Re: Want to superimpose text on graphic frame?
Willi Adelberger Jan 24, 2014 9:50 PM (in response to straightlife)You should not use to affect text beneath. It is te Quark like way to solve things but is causing a lot of problems with transparency (e.g. your drop shadows will cause problems if they extend to texts beneath of them.) I am always recommending to use text in a separate layer above images!
What Peter said is the right answer. But I suppose that you applied this option to the whole text and that is of course not rights. Only those text frames upon images should ignore text wrapping.
I would also recomend to create specific object styles for each kind of text behavior.
5. Re: Want to superimpose text on graphic frame?
P Spier Jan 24, 2014 10:56 PM (in response to straightlife)straightlife wrote:
Ignore text wrap should only be activated for the caption frames you want on top of the photos.
