12 Replies Latest reply on Feb 3, 2014 8:09 AM by Almac44
    Elements 12 Organizer has stopped recognising .mts files
    Almac44
      The Organizer has suddenly stopped being able to display .mts video files. It used to do this quite happily but now says it does not have the codec, and suggests installing Quick Time. I have done this but it does not help. Quick Time does not recognise files. The Premiere elements editor has no trouble with .mts files. I am running Widows 8.1 64 bit. Is this an Adobe or an Apple snarl-up?
        • 1. Re: Elements 12 Organizer has stopped recognising .mts files
          GautamBahl Adobe Employee
          Hi Almac44,
          It seems to be an issue with a conflict of codecs.
          Please check if K-lite codec pack is installed on your system.
          If yes please uninstall it from your system and restart it and try again.
          For more information please have a look at the below thread
          http://forums.adobe.com/thread/1305028
          • 2. Re: Elements 12 Organizer has stopped recognising .mts files
            Almac44 Level 1
            I don’t think The K-Lite codec pack is installed, at least I can’t find it.
            Alisdair Macdonald
            • 3. Re: Elements 12 Organizer has stopped recognising .mts files
              Hi Almac44,
              Can you please try to rename any one file from.mts to .m2ts
              Then try to check that file in elements organizer.
              • 4. Re: Elements 12 Organizer has stopped recognising .mts files
                A.T. Romano Level 7
                Almac44
                Have you read the thread
                http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home/?cc=us&cc=us&lang=en&lang=en&sp 4ts.oid=5212912&ac.admitted=1390664762998.876444892.492883150
                to which GautamBahl pointed you?
                Please check out my contributions to that thread, including the simple fix of right clicking the thumbnail in the Elements Organizer 12, selecting Update Thumbnail. Have you been there and done that?
                Typically the K-Lite codec pack is 3rd party. But, be careful downloading and installing any 3rd party codecs unless absolutely necessary. The after problems can be more problematic than the before problem in many instances.
                More later.
                ATR
                • 5. Re: Elements 12 Organizer has stopped recognising .mts files
                  Almac44 Level 1
                  I have tried this. An old file which had a .m2s extension will not play, and a new file renamed will not import as it is not a recognised file type.
                  • 6. Re: Elements 12 Organizer has stopped recognising .mts files
                    Almac44 Level 1
                    This link seems to be something different. I have looked at the original link but I do not think I have the K-Lite codec pack installed. Right clicking and selecting update thumbnail does not seem to do anything
                    Thanks for the reply
                    • 8. Re: Elements 12 Organizer has stopped recognising .mts files
                      A.T. Romano Level 7
                      Almac44
                      You might want to check out codecs already installed on your computer.
                      One way...do you have installed Windows Media Player 12?
                      If so, open Windows Media Player 12 and go to the Help Menu/Adobe Windows Media Player.
                      At the bottom of the dialog that opens, you should be "Techical Support Information". Click on "Technical Support Information" to get a comprehensive list of codecs installed on your computer.
                      ATR
                      Also, did we determine if you had installed on your computer
                      a. latest version of Windows Media Player
                      b. latest verison of QuickTime
                      c. Media Player Classic
                      http://mpc-hc.org/
                      • 9. Re: Elements 12 Organizer has stopped recognising .mts files
                        Almac44 Level 1
                        Windows Media Player 12 is installed.
                        Version 12.0.9600.16384
                        Operating System
                        Version:
                        6.3.9600
                        System Locale:
                        en-GB
                        Service Pack:
                        0.0
                        User Locale:
                        en-GB
                        Build Lab:
                        9600.winblue_gdr.131030-1505
                        Geo ID:
                        United Kingdom
                        Type:
                        Workstation
                        DRM Version:
                        11.0.9600.16384
                        Architecture:
                        x86
                        Indiv Version:
                        2.9.0.1
                        Processors:
                        8
                        Video codecs are:
                        Type
                        Name
                        Format
                        Binary
                        Version
                        ICM
                        Microsoft YUV
                        UYVY
                        msyuv.dll
                        6.3.9600.16384
                        ICM
                        Intel IYUV codec
                        IYUV
                        iyuv_32.dll
                        6.3.9600.16384
                        ICM
                        Cinepak Codec by Radius
                        cvid
                        iccvid.dll
                        1.10.0.12
                        ICM
                        Microsoft YUV
                        UYVY
                        msyuv.dll
                        6.3.9600.16384
                        ICM
                        Toshiba YUV Codec
                        Y411
                        tsbyuv.dll
                        6.3.9600.16384
                        ICM
                        Microsoft YUV
                        UYVY
                        msyuv.dll
                        6.3.9600.16384
                        ICM
                        Intel IYUV codec
                        IYUV
                        iyuv_32.dll
                        6.3.9600.16384
                        ICM
                        Microsoft RLE
                        MRLE
                        msrle32.dll
                        6.3.9600.16384
                        ICM
                        Microsoft Video 1
                        MSVC
                        msvidc32.dll
                        6.3.9600.16384
                        ICM
                        proDAD Codec
                        pDAD
                        DMO
                        Mpeg4s Decoder DMO
                        mp4s, MP4S, m4s2, M4S2, MP4V, mp4v, XVID, xvid, DIVX, DX50
                        mp4sdecd.dll
                        6.3.9600.16384
                        DMO
                        WMV Screen decoder DMO
                        MSS1, MSS2
                        wmvsdecd.dll
                        6.3.9600.16384
                        DMO
                        WMVideo Decoder DMO
                        WMV1, WMV2, WMV3, WMVA, WVC1, WMVP, WVP2, VC1S
                        wmvdecod.dll
                        6.3.9600.16384
                        DMO
                        Mpeg43 Decoder DMO
                        mp43, MP43
                        mp43decd.dll
                        6.3.9600.16384
                        DMO
                        Mpeg4 Decoder DMO
                        MPG4, mpg4, mp42, MP42
                        mpg4decd.dll
                        6.3.9600.16384
                        Windows Media Player plays .mps files without problems
                        Quick Time Player v7.7.4 installed (at suggestion from adobe premiere organiser). Will not play .mps files
                        Adobe Premiere 12 organiser will not play .mps files, editor will play and edit them.
                        Media Player Classic not installed
                        • 10. Re: Elements 12 Organizer has stopped recognising .mts files
                          A.T. Romano Level 7
                          Almac44
                          Do you mean .mts files when you wrote .mps?
                          Are you going to try the Media Player Classic install?
                          If not, could you give the properties of the video file(s) involved, including brand/model/settings of the camera recording the video.
                          If you think that it would be to your advantage, I would appreciate the opportunity to work with a small sample of the video(s) involved. Would it be possible to post a Dropbox link to a download of that sample?
                          Typically in these types of problems, the symptoms are
                          a. Elements Organizer thumbnail which does not display the first frame (or any frame) of the video that it represents
                          and
                          b. In spite of the "no video frame display" within the Elements Organizer thumbnail, the video does play back (video and audio) within the Elements Organizer after it is double clicked there.
                          We will be watching for further developments.
                          Thank you.
                          ATR
                          • 11. Re: Elements 12 Organizer has stopped recognising .mts files
                            Almac44 Level 1
                            Yes I did mean .mts
                            I have installed Media Player Classic. It works fine.
                            The recent files are from a Panasonic HC-X920 but the problem applies to all the video files in the organizer archive, which came from other Panasonic cameras. The archives were put together using earlier versions of Premier Elements and Pinnacle Studio. What seems to have happened is that the organizer has decided that it can only play video using Apple Quick Time as a viewer, where before it used its own viewer. This is shown by the fact it can play .mpeg files from the organizer, which appear in a (rather crappy) Quick time window which cannot be resized. Possibly one can obtain codecs for the Quick Time viewer – but what happened to the other one?
                            • 12. Re: Elements 12 Organizer has stopped recognising .mts files
                              Almac44 Level 1
                              I think I have solved this problem. Uninstlling earlier verions can, it seems, sometimes result in a situation where Organizer does not recognize Premiere as being installed. To correct this uninstall both Premiere Elements and Photshop Elements (if you have it), thus uninstalling Oganizer, clean up the registry (I used Ccleaner) and then reinstall. Worked for me
