3 Replies Latest reply on Jan 25, 2014 8:54 PM by A.T. Romano
    Is there any way to avoid the Dynamic Sequence Preset in PreE11?
    johnjv24 Level 1
      I read on here ( http://help.adobe.com/en_US/premiereelements/using/WS04855172-E9FD-41b3-9145-FD434A543442. html ), that "When you add a movie clip to the Expert view timeline, Adobe Premiere Elements automatically changes your project settings in the background to match the clip properties...", is there anyway to bypass this or turn it off? Or is going to Quick view the only way?  Because I need to intentionally mismatch video with project settings, I know sounds ridiculous.
        • 1. Re: Is there any way to avoid the Dynamic Sequence Preset in PreE11?
          A.T. Romano Level 7
          johnjv24
          I am offering the following in the name of assuring the you get the project preset you want.
          Hopefully, you will see the merits of the project preset matching the properties of the source media. I see no rationale in a mismatch. I would be pleased for the opportunity to convince you of that.
          Open a new Premiere Elements 11 or 12 project.
          Go immediately to the File Menu/New/Project and set the project preset.
          Before you exit the final dialog in that area, place a check mark before "Force Selected Project Setting on This Project".
          When you are back in the Premiere Elements 11 or 12 Expert workspace, use Add Media/ to import your source media to the Timeline. You can verify your project preset by checking the reading under the workspace's Edit Menu/Projects Settings/General and its Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio (grayed out or not).
          ATR
          • 2. Re: Is there any way to avoid the Dynamic Sequence Preset in PreE11?
            johnjv24 Level 1
            ATR,
            The rationale for this is because I've tried matching the project preset with the video footage (1080p/29.97fps) with subpar results when burning to SD-DVD.  I have tried the project preset, DV Widescreen, and scaling to frame my AVCHD footage and obtained better results.  I've tried that and it seems to keep changing the project preset, but I will try it again to be certain. Thanks.
            johnjv24
            • 3. Re: Is there any way to avoid the Dynamic Sequence Preset in PreE11?
              A.T. Romano Level 7
              johnjv24
              Pending more information, you should try setting the project preset manually for
              NTSC
              DSLR
              1080p30
              DSLR 1080p30 @ 29.97
              Have we discussed this previously?
              Keep in mind that this 16:9 import is appropriate for the NTSC_Widescreen_Dolby DVD choice in burn to DVD disc. (16:9 to 16:9 rather than 16:9 to 4:3)
              More later.
              ATR
