1. Re: Long-lived Process cannot be invoked
~Sid~ Feb 10, 2014 10:16 AM (in response to yichen@adobe.com)any hints from the server log file ?
You could check the tb_process_instance table on the LC database side to see if that creates a new entry when you try to trigger the long lived process.
*try to navigate the DB with read only permissions, do not commit any changes on LC db side. Could cause irreverisble damage to the system's stability.
2. Re: Long-lived Process cannot be invoked
WASIL Feb 10, 2014 1:31 PM (in response to yichen@adobe.com)Besides, manually sync the domain with reverted changes and try to invoke the long lived process. Also, check the status of users in edcprincipalentity table.
Wasil
3. Re: Long-lived Process cannot be invoked
yichen@adobe.com Feb 10, 2014 7:09 PM (in response to ~Sid~)There is one error thrown when server start up. I am not sure whether it is the reason. There is no other error thrown while startup and invoking process.
I checked the table tb_process_instance. There is no new process instance record.
Anyway, I've installed another LC server instance and migrated our application to new one.
2014-01-26 17:32:39,323 ERROR [com.adobe.idp.scheduler.SchedulerServiceImpl] Failure occured during job recovery.
- org.quartz.SchedulerConfigException: Failure occured during job recovery. [See nested exception: org.quartz.JobPersistenceException: Couldn't clean volatile data: Table './eagle_development/QRTZ_TRIGGERS' is marked as crashed and should be repaired [See nested exception: java.sql.SQLException: Table './eagle_development/QRTZ_TRIGGERS' is marked as crashed and should be repaired]]
at org.quartz.impl.jdbcjobstore.JobStoreSupport.initialize(JobStoreSupport.java:557)
at org.quartz.impl.jdbcjobstore.JobStoreTX.initialize(JobStoreTX.java:59)
at com.adobe.idp.scheduler.DSCSchedulerFactory.instantiate(DSCSchedulerFactory.java:968)
at com.adobe.idp.scheduler.DSCSchedulerFactory.getScheduler(DSCSchedulerFactory.java:352)
at com.adobe.idp.scheduler.SchedulerServiceImpl.createScheduler(SchedulerServiceImpl.java:47 4)
at com.adobe.idp.scheduler.SchedulerServiceImpl.startSchedulerServiceInternal(SchedulerServi ceImpl.java:767)
at com.adobe.idp.scheduler.SchedulerServiceImpl.startSchedulerServiceDirect(SchedulerService Impl.java:733)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
at org.jboss.ejb.Container.invoke(Container.java:960)
at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
at $Proxy191.doBMT(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:188)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.idp.dsc.impl.DSCManagerImpl.startAsynchronousServices(DSCManagerImpl.java:214)
at com.adobe.idp.dsc.impl.DSCManagerImpl.startCoreComponents(DSCManagerImpl.java:149)
at com.adobe.idp.dsc.startup.DSCStartupServlet$2.doInTransaction(DSCStartupServlet.java:171)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:218)
at sun.reflect.GeneratedMethodAccessor318.invoke(Unknown Source)
at $Proxy191.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:133)
at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
at com.adobe.idp.dsc.startup.DSCStartupServlet.init(DSCStartupServlet.java:162)
at javax.servlet.GenericServlet.init(GenericServlet.java:212)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1161)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:981)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4069)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4373)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:761)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:741)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:553)
at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:297)
at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
at org.apache.catalina.core.StandardContext.init(StandardContext.java:5310)
at sun.reflect.GeneratedMethodAccessor205.invoke(Unknown Source)
at org.jboss.web.tomcat.service.TomcatDeployer.performDeployInternal(TomcatDeployer.java:301 )
at org.jboss.web.tomcat.service.TomcatDeployer.performDeploy(TomcatDeployer.java:104)
at org.jboss.web.AbstractWebDeployer.start(AbstractWebDeployer.java:375)
at org.jboss.web.WebModule.startModule(WebModule.java:83)
at org.jboss.web.WebModule.startService(WebModule.java:61)
at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
at $Proxy0.start(Unknown Source)
at org.jboss.system.ServiceController.start(ServiceController.java:417)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
at $Proxy46.start(Unknown Source)
at org.jboss.web.AbstractWebContainer.start(AbstractWebContainer.java:466)
at sun.reflect.GeneratedMethodAccessor188.invoke(Unknown Source)
at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterce ptor.java:142)
at org.jboss.mx.interceptor.DynamicInterceptor.invoke(DynamicInterceptor.java:97)
at org.jboss.system.InterceptorServiceMBeanSupport.invokeNext(InterceptorServiceMBeanSupport .java:238)
at org.jboss.ws.integration.jboss42.DeployerInterceptor.start(DeployerInterceptor.java:93)
at org.jboss.deployment.SubDeployerInterceptorSupport$XMBeanInterceptor.start(SubDeployerInt erceptorSupport.java:188)
at org.jboss.deployment.SubDeployerInterceptor.invoke(SubDeployerInterceptor.java:95)
at $Proxy47.start(Unknown Source)
at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1015)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
at $Proxy9.deploy(Unknown Source)
at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:421)
at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:634)
at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeplo ymentScanner.java:263)
at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentSca nner.java:336)
at $Proxy4.start(Unknown Source)
at org.jboss.deployment.SARDeployer.start(SARDeployer.java:302)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766)
at $Proxy5.deploy(Unknown Source)
at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482)
at org.jboss.system.server.ServerImpl.start(ServerImpl.java:362)
at org.jboss.Main.boot(Main.java:200)
at org.jboss.Main$1.run(Main.java:508)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.quartz.JobPersistenceException: Couldn't clean volatile data: Table './eagle_development/QRTZ_TRIGGERS' is marked as crashed and should be repaired [See nested exception: java.sql.SQLException: Table './eagle_development/QRTZ_TRIGGERS' is marked as crashed and should be repaired]
at org.quartz.impl.jdbcjobstore.JobStoreSupport.cleanVolatileTriggerAndJobs(JobStoreSupport. java:736)
at org.quartz.impl.jdbcjobstore.JobStoreSupport$1.execute(JobStoreSupport.java:697)
at org.quartz.impl.jdbcjobstore.JobStoreSupport$40.execute(JobStoreSupport.java:3628)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.executeInNonManagedTXLock(JobStoreSupport.ja va:3662)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.executeInNonManagedTXLock(JobStoreSupport.ja va:3624)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.cleanVolatileTriggerAndJobs(JobStoreSupport. java:693)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.initialize(JobStoreSupport.java:555)
... 216 more
Caused by: java.sql.SQLException: Table './eagle_development/QRTZ_TRIGGERS' is marked as crashed and should be repaired
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1055)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3491)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3423)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1936)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2060)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2542)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1734)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1885)
at org.jboss.resource.adapter.jdbc.CachedPreparedStatement.executeQuery(CachedPreparedStatem ent.java:90)
at org.jboss.resource.adapter.jdbc.WrappedPreparedStatement.executeQuery(WrappedPreparedStat ement.java:236)
at org.quartz.impl.jdbcjobstore.StdJDBCDelegate.selectVolatileTriggers(StdJDBCDelegate.java: 3491)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.cleanVolatileTriggerAndJobs(JobStoreSupport. java:714)
... 222 more
2014-01-26 17:32:39,332 ERROR [com.adobe.idp.scheduler.SchedulerServiceImpl] Scheduler Exception thrown Failure occured during job recovery.
2014-01-26 17:32:39,364 ERROR [STDERR] ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
2014-01-26 17:32:39,366 ERROR [STDERR] at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:152)
2014-01-26 17:32:39,366 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
2014-01-26 17:32:39,366 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
2014-01-26 17:32:39,366 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
2014-01-26 17:32:39,366 ERROR [STDERR] at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
2014-01-26 17:32:39,366 ERROR [STDERR] at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
2014-01-26 17:32:39,366 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
2014-01-26 17:32:39,366 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
2014-01-26 17:32:39,366 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,366 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,366 ERROR [STDERR] at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
2014-01-26 17:32:39,366 ERROR [STDERR] at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.Container.invoke(Container.java:960)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
2014-01-26 17:32:39,367 ERROR [STDERR] at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
2014-01-26 17:32:39,367 ERROR [STDERR] at $Proxy191.doBMT(Unknown Source)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:188)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
2014-01-26 17:32:39,368 ERROR [STDERR] at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.impl.DSCManagerImpl.startAsynchronousServices(DSCManagerImpl.java:214)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.impl.DSCManagerImpl.startCoreComponents(DSCManagerImpl.java:149)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.startup.DSCStartupServlet$2.doInTransaction(DSCStartupServlet.java:171)
2014-01-26 17:32:39,369 ERROR [STDERR] at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:218)
2014-01-26 17:32:39,369 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor318.invoke(Unknown Source)
2014-01-26 17:32:39,369 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,369 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,369 ERROR [STDERR] at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
2014-01-26 17:32:39,369 ERROR [STDERR] at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
2014-01-26 17:32:39,369 ERROR [STDERR] at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
2014-01-26 17:32:39,369 ERROR [STDERR] at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.Container.invoke(Container.java:960)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
2014-01-26 17:32:39,370 ERROR [STDERR] at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
2014-01-26 17:32:39,370 ERROR [STDERR] at $Proxy191.doRequiresNew(Unknown Source)
2014-01-26 17:32:39,370 ERROR [STDERR] at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:133)
2014-01-26 17:32:39,370 ERROR [STDERR] at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
2014-01-26 17:32:39,371 ERROR [STDERR] at com.adobe.idp.dsc.startup.DSCStartupServlet.init(DSCStartupServlet.java:162)
2014-01-26 17:32:39,371 ERROR [STDERR] at javax.servlet.GenericServlet.init(GenericServlet.java:212)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1161)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:981)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4069)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.StandardContext.start(StandardContext.java:4373)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:761)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:741)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:553)
2014-01-26 17:32:39,371 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
2014-01-26 17:32:39,371 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,371 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:297)
2014-01-26 17:32:39,371 ERROR [STDERR] at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.apache.catalina.core.StandardContext.init(StandardContext.java:5310)
2014-01-26 17:32:39,372 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor205.invoke(Unknown Source)
2014-01-26 17:32:39,372 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,372 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:297)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.web.tomcat.service.TomcatDeployer.performDeployInternal(TomcatDeployer.java:301 )
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.web.tomcat.service.TomcatDeployer.performDeploy(TomcatDeployer.java:104)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.web.AbstractWebDeployer.start(AbstractWebDeployer.java:375)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.web.WebModule.startModule(WebModule.java:83)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.web.WebModule.startService(WebModule.java:61)
2014-01-26 17:32:39,372 ERROR [STDERR] at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
2014-01-26 17:32:39,373 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
2014-01-26 17:32:39,373 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,373 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
2014-01-26 17:32:39,373 ERROR [STDERR] at $Proxy0.start(Unknown Source)
2014-01-26 17:32:39,373 ERROR [STDERR] at org.jboss.system.ServiceController.start(ServiceController.java:417)
2014-01-26 17:32:39,373 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
2014-01-26 17:32:39,374 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
2014-01-26 17:32:39,374 ERROR [STDERR] at $Proxy46.start(Unknown Source)
2014-01-26 17:32:39,374 ERROR [STDERR] at org.jboss.web.AbstractWebContainer.start(AbstractWebContainer.java:466)
2014-01-26 17:32:39,374 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor188.invoke(Unknown Source)
2014-01-26 17:32:39,374 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterce ptor.java:142)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.interceptor.DynamicInterceptor.invoke(DynamicInterceptor.java:97)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.system.InterceptorServiceMBeanSupport.invokeNext(InterceptorServiceMBeanSupport .java:238)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.ws.integration.jboss42.DeployerInterceptor.start(DeployerInterceptor.java:93)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.deployment.SubDeployerInterceptorSupport$XMBeanInterceptor.start(SubDeployerInt erceptorSupport.java:188)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.deployment.SubDeployerInterceptor.invoke(SubDeployerInterceptor.java:95)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,375 ERROR [STDERR] at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
2014-01-26 17:32:39,375 ERROR [STDERR] at $Proxy47.start(Unknown Source)
2014-01-26 17:32:39,376 ERROR [STDERR] at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
2014-01-26 17:32:39,376 ERROR [STDERR] at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1015)
2014-01-26 17:32:39,376 ERROR [STDERR] at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
2014-01-26 17:32:39,376 ERROR [STDERR] at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
2014-01-26 17:32:39,376 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
2014-01-26 17:32:39,376 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,376 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,376 ERROR [STDERR] at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
2014-01-26 17:32:39,376 ERROR [STDERR] at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterce ptor.java:142)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
2014-01-26 17:32:39,377 ERROR [STDERR] at $Proxy9.deploy(Unknown Source)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:421)
2014-01-26 17:32:39,377 ERROR [STDERR] at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:634)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeplo ymentScanner.java:263)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentSca nner.java:336)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
2014-01-26 17:32:39,378 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
2014-01-26 17:32:39,378 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,378 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
2014-01-26 17:32:39,378 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
2014-01-26 17:32:39,379 ERROR [STDERR] at $Proxy0.start(Unknown Source)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.system.ServiceController.start(ServiceController.java:417)
2014-01-26 17:32:39,379 ERROR [STDERR] at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
2014-01-26 17:32:39,379 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,379 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
2014-01-26 17:32:39,379 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
2014-01-26 17:32:39,380 ERROR [STDERR] at $Proxy4.start(Unknown Source)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.deployment.SARDeployer.start(SARDeployer.java:302)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
2014-01-26 17:32:39,380 ERROR [STDERR] at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766)
2014-01-26 17:32:39,380 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
2014-01-26 17:32:39,381 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
2014-01-26 17:32:39,381 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,381 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterce ptor.java:142)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
2014-01-26 17:32:39,381 ERROR [STDERR] at $Proxy5.deploy(Unknown Source)
2014-01-26 17:32:39,381 ERROR [STDERR] at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482)
2014-01-26 17:32:39,382 ERROR [STDERR] at org.jboss.system.server.ServerImpl.start(ServerImpl.java:362)
2014-01-26 17:32:39,382 ERROR [STDERR] at org.jboss.Main.boot(Main.java:200)
2014-01-26 17:32:39,382 ERROR [STDERR] at org.jboss.Main$1.run(Main.java:508)
2014-01-26 17:32:39,382 ERROR [STDERR] at java.lang.Thread.run(Thread.java:619)
2014-01-26 17:32:39,383 ERROR [STDERR] Caused by: com.adobe.idp.scheduler.SchedulerException: Failure occured during job recovery.
2014-01-26 17:32:39,383 ERROR [STDERR] at com.adobe.idp.scheduler.SchedulerServiceImpl.createScheduler(SchedulerServiceImpl.java:48 3)
2014-01-26 17:32:39,383 ERROR [STDERR] at com.adobe.idp.scheduler.SchedulerServiceImpl.startSchedulerServiceInternal(SchedulerServi ceImpl.java:767)
2014-01-26 17:32:39,383 ERROR [STDERR] at com.adobe.idp.scheduler.SchedulerServiceImpl.startSchedulerServiceDirect(SchedulerService Impl.java:733)
2014-01-26 17:32:39,384 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
2014-01-26 17:32:39,384 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
2014-01-26 17:32:39,384 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
2014-01-26 17:32:39,384 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
2014-01-26 17:32:39,384 ERROR [STDERR] at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
2014-01-26 17:32:39,384 ERROR [STDERR] ... 205 more
2014-01-26 17:32:39,385 ERROR [com.adobe.idp.dsc.impl.DSCManagerImpl] Post initialization was not done for on the service:IDPSchedulerService as it is not yet installed. Reason: Invocation error.
4. Re: Long-lived Process cannot be invoked
WASIL Feb 11, 2014 4:41 AM (in response to yichen@adobe.com)A probable cause behind this : http://stackoverflow.com/questions/3719908/java-sql-sqlexception-table-qrtz-triggers-is-ma rked-as-crashed-and-should-be
