1 Reply Latest reply on May 15, 2006 6:56 AM by Iceborer
    reference cfgridupdate array
    Level 7
      I am using CFMX7 and cfgrid. CfGrid mode is "EDIT" name is MYGRID
      The output from the CFFORM page is:
      Form fields: [ID,CUSTOMERNO,SAVEMYUSAGE,__CFGRID__GETSTUFF__MYGRID]
      Form values:
      ID = 74
      CUSTOMERNO = 21691
      SAVEMYUSAGE = Save My Usage
      __CFGRID__GETSTUFF__MYGRID =
      __CFGRID__EDIT__=10permitnoNtrucknoNlastreaddateNlastreadingYcurrentreaddateNcurrentreadin g
      How can I reference the array in form variable =
      to get my permit no, truck no, lastreaddate, etc.?
      What I want to get to are the values in the array because I need to
      check to see if value is null or if the value is 0, or if the value
      is a number greater than zero.
      I think it is related java and I think the names are param 1, param 2,
      param 3, etc.
      Thanks in Advance
      trainmom
        • 1. Re: reference cfgridupdate array
          Iceborer Level 1
          Try dumping the form variable using <cfdump var="#form#"> on your target page to get a better idea of what the cfgrid construct looks like. If I remeber correctly there is an array for both the before and after images of each column plus an array of row actions. Sorry I don't have an example that would easily show this.
