8 Replies Latest reply on Jan 29, 2014 2:47 PM by DreaMaTrix
    Extension manager not selectable
    DreaMaTrix
      Hello
      My extensions menu is greyed out in photoshop. I have unistalled extension manager, updated it too. I have uninstalled exchange and reinstalled that too.
      I have unistalled photoshop, and all components, then reinstalled
      I have checked the folder C:\Program Files (x86)\Common Files\Adobe\CEPServiceManager4\extensions and there are folders in there.
      I am running windows 7 and this happened after the last photoshop update
      Any ideas?
      Many thanks
      Paul
        • 1. Re: Extension manager not selectable
          Zhihong Chen Level 1
          Hi Paul,
          This is Zhihong from Adobe CEP team. Thanks for reporting this, could you please help to offer following information:
          1. Is there a nested extension folder under “C:\Program Files (x86)\Common Files\Adobe\CEPServiceManager4\extensions”? The correct structure should be “..\CEPServiceManager4\extensions\extensionA” rather than “..\CEPServiceManager4\extensions\nestedFolderName\extensionA”.
          2. Can you get the CEP log and listed in this thread? The steps are as following:
          First, set the “LogLevel” value of registry key “HKEY_CURRENT_USER\Software\Adobe\CSXS.4” from “1” to “6”. Second, restart Photoshop and do the operations you mentioned. The CEP log will be in folder “C:\Users\’username’\AppData\Local\Temp” with name csxs4-PHXS.log.
          3. In addition, could you please check following components version on your machine?
          Version of CEPHtmlEngine.exe (it locates at path “C:\Program Files (x86)\Common Files\Adobe\CEPServiceManager4\html”).
          Version of PlugPlugOwl.dll (in the Photoshop installation folder like “C:\Program Files (x86)\Adobe\Adobe Photoshop CC”).
          Thanks!
          • 2. Re: Extension manager not selectable
            DreaMaTrix Level 1
            Hi Zhihong
            1/
            2/
            2014-01-05 17:12:44 : INFO  PlugPlug version : 4.0.1.34
            2014-01-05 17:12:44 : INFO  LogLevel : 1
            2014-01-05 17:12:44 : ERROR EvalScript: Failed to evaluate script for engine <MINIBR_Engine_Id>
            3/
            CEPHtmlengine.exe 4.0.2.6
            PlugPlugOwl Standard Dll (32bit) 4.2.0.36
            Thank you
            Paul
            • 3. Re: Extension manager not selectable
              Hi Paul,
              The extensions folder structure is correct. Both of the
              CEPHtmlEngine and PlugPlugOwl version is correct, too. But about step2, the log
              you attached is still with LogLevel 1. Could you please check the value of “LogLevel”
              in registry key “HKEY_CURRENT_USER\Software\Adobe\CSXS.4” again? If it was set
              to 6, the log will looks as following:
              “2014-01-27 20:41:36 : INFO
              PlugPlug version : 4.2.0.36
              LogLevel : 6
              Copy RGB Background Color Information for AppBar
              2014-01-27 20:41:37 : INFO
              Copy RGB Background Color Information for Panel
              Copy sRGB Background Color Information for AppBar
              Copy sRGB Background Color Information for Panel
              Windows 64-bit PlugPlug logs
              • 4. Re: Extension manager not selectable
                DreaMaTrix Level 1
                Hi Zhihong
                That was it, it was set to 6. I even deleted it to see if a new one would be generated.
                • 5. Re: Extension manager not selectable
                  Thanks for your confirmation. Is it possible that the “LogLevel” value you modified is in “HKEY_CURRENT_USER\Software\Adobe\CSXS.3” instead of “..\CSXS.4”? If the “LogLevel” in “..\CSXS.4” was modified, the log file name would be “csxs4-PHXS.log”; and the “PlugPlug version: 4.0.1.34” in log file should as same as the PlugPlugOwl.dll version in your PS (which is 4.2.0.36). On the other hand, the “LogLevel : 1” in log file should be “LogLevel : 6”. Could you please check this? Thanks!
                  • 6. Re: Extension manager not selectable
                    DreaMaTrix Level 1
                    No, thats it. Exactly the instructions you provided, tried it several times. Moved the log to see if it would generate a new one.
                    can you give me instructions on how to uninstall all my cc products and clean all folders/registries etc. I am wasting too much time with all this.
                    Many thanks for your help
                    Paul
                    • 7. Re: Extension manager not selectable
                      Please try the Adobe CC Cleaner Tool: http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html . And let me know whether it can fix your problem or not, thanks!
                      • 8. Re: Extension manager not selectable
                        DreaMaTrix Level 1
                        Ok it's working again now.
                        I uninstalled eveything including preferences.
                        I deleted all the registry entries for adobe
                        I reinstalled everything, back to normal.
                        The Adobe CC cleaner tool is about as much use as a chocolate kettle
