0 Replies Latest reply on Jan 26, 2014 12:52 PM by olegkon
    Spark skin incompatible with MX DataGrid?
    olegkon Level 1
      I am working on a screen where I need an MX AdvancedDataGrid and a regular DataGrid,
      and have Spark skin.
      I used to have a Spark skin there, everything worked fine, but it looks slightly different from ADG,
      so I am trying to replace that Spark DataGrid with either MX DataGrid or ADG.
      As soon as I do it, getting the following exception and screen turns white, nothing there:
      TypeError: Error #1034: Type Coercion failed: cannot convert mx.collections::ArrayList@d6724d9 to mx.controls.dataGridClasses.DataGridColumn.
                at mx.controls::DataGrid/set columns()[E:\dev\4.5.1\frameworks\projects\mx\src\mx\controls\DataGrid.as:1357]
                at ieddata.metaweb.view::ExplorerViewSkin/_ExplorerViewSkin_DataGrid1_i()[C:\MSDE\konovalo\d ev\ieddata\pantheon_web\trunk\src\flexpackages\ieddata\metaweb\view\ExplorerViewSkin.mxml: 30]
                at Function/<anonymous>()
                at Function/http://adobe.com/AS3/2006/builtin::call()
                at mx.core::ComponentDescriptor/get properties()[E:\dev\4.5.1\frameworks\projects\framework\src\mx\core\ComponentDescriptor.a s:271]
                at mx.core::Container/createComponentFromDescriptor()[E:\dev\4.5.1\frameworks\projects\mx\sr c\mx\core\Container.as:4272]
                at mx.core::Container/createComponentsFromDescriptors()[E:\dev\4.5.1\frameworks\projects\mx\ src\mx\core\Container.as:4183]
                at mx.core::Container/createChildren()[E:\dev\4.5.1\frameworks\projects\mx\src\mx\core\Conta iner.as:3189]
                at mx.core::UIComponent/initialize()[E:\dev\4.5.1\frameworks\projects\framework\src\mx\core\ UIComponent.as:7624]
                at mx.core::Container/initialize()[E:\dev\4.5.1\frameworks\projects\mx\src\mx\core\Container .as:3131]
                at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.5.1\frameworks\projects\framework\src\mx\core\UIComponent.as:7485]
                at mx.core::UIComponent/addChildAt()[E:\dev\4.5.1\frameworks\projects\framework\src\mx\core\ UIComponent.as:7189]
                at spark.components::Group/addDisplayObjectToDisplayList()[E:\dev\4.5.1\frameworks\projects\ spark\src\spark\components\Group.as:2037]
                at spark.components::Group/http://www.adobe.com/2006/flex/mx/internal::elementAdded()[E:\dev\4.5.1\frameworks\projects\spark\src\spark\components\Group.as:1628]
                at spark.components::Group/setMXMLContent()[E:\dev\4.5.1\frameworks\projects\spark\src\spark \components\Group.as:633]
                at spark.components::Group/set mxmlContent()[E:\dev\4.5.1\frameworks\projects\spark\src\spark\components\Group.as:573]
                at spark.components::SkinnableContainer/set mxmlContent()[E:\dev\4.5.1\frameworks\projects\spark\src\spark\components\SkinnableContai ner.as:657]
                at spark.components::SkinnableContainer/createDeferredContent()[E:\dev\4.5.1\frameworks\proj ects\spark\src\spark\components\SkinnableContainer.as:1050]
                at mx.containers::ViewStack/instantiateSelectedChild()[E:\dev\4.5.1\frameworks\projects\mx\s rc\mx\containers\ViewStack.as:1260]
                at mx.containers::ViewStack/commitProperties()[E:\dev\4.5.1\frameworks\projects\mx\src\mx\co ntainers\ViewStack.as:756]
                at mx.core::UIComponent/validateProperties()[E:\dev\4.5.1\frameworks\projects\framework\src\ mx\core\UIComponent.as:8209]
                at mx.managers::LayoutManager/validateProperties()[E:\dev\4.5.1\frameworks\projects\framewor k\src\mx\managers\LayoutManager.as:597]
                at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.5.1\frameworks\projects\frame work\src\mx\managers\LayoutManager.as:813]
                at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.5.1\frameworks\projec ts\framework\src\mx\managers\LayoutManager.as:1180]
      Skin which is my MXML view:
      <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:fb="http://ns.adobe.com/flashbuilder/2009"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          xmlns:view="ieddata.metaweb.view.*">     that is where that ExplorerViewSkin.mxml:30 is where exception is coming from.
                          <!-- alpha.disabled="0.5" -->
      That DataGrid in question is just plain vanilla, nothing special.
      So why would I get that exception?
      Please help!
      Using Flex 4.5.1
      TIA,
      Oleg.
