9 Replies Latest reply on Nov 12, 2017 3:42 PM by adriano.lucas
    convert text to footnote
    gert verrept Level 2
      8.      de chercher plus de véritables [1] partenariats avec la société civile afin que les défenseurs des droits de l'homme se sentent pleinement [2] soutenus par l'UE;
      [1] HRW: Central Asia : Five Years of EU engagement
      [2] http://www.senat.fr/rap/r96-2013,1054/r96-374.html.
      This is a little sample of xml-text we get from external sources. There's no link between the false "footnote-ref [1]" in de text and the false "endnote text".
      Is there a possibility to convert those "notes" to real notes in de text, but not to end-notes? Sometimes these kind of notes extend to more than 100.
      thnkx
        • 1. Re: convert text to footnote
          Peter Kahrel Adobe Community Professional & MVP
          If you can identify uniquely the references in the text ([1], [2], etc) and the notes/note numbers, then yes.
          • 2. Re: convert text to footnote
            Yes, the structure is always the same. We get [1] in the text and at the end of the complete story the [1] followed by the footnote text. All footnotes are numbered from [1] till ...
            • 3. Re: convert text to footnote
              That was clear from your first post. My question was: is every number in brackets in the text a footnote reference?; and is every number in brackets at the start of a paragraph a footnote number?
              • 4. Re: convert text to footnote
                Sorry, misunderstood your question, but indeed, every number between [ ] is a footnote reference and every [ ] at the start of a para is a footnote number.
                • 5. Re: convert text to footnote
                  Jump_Over Level 5
                  Just to show the way:
                  var
                      myDoc = app.activeDocument,
                      mStory = myDoc.textFrames.item("story").parentStory,
                      mEndNotes = myDoc.textFrames.add( {name:"EndNotes"} ),
                      k, len, cIP, currPara, currFoot, mMarkers;
                  app.findGrepPreferences = app.changeGrepPreferences = null;
                  // edit doc.footnoteOption here
                  with (myDoc.footnoteOptions)
                      showPrefixSuffix = FootnotePrefixSuffix.PREFIX_SUFFIX_BOTH;
                      prefix = "[";
                      suffix = "]";
                      separatorText = "\t";
                      markerPositioning = FootnoteMarkerPositioning.NORMAL_MARKER;
                  // move endnotes to a separate textFrame
                  for (k=mStory.paragraphs.length - 1; k >=0; k--)
                      if (mStory.paragraphs[k].contents.search(/^\[\d+\]/) == 0)
                          currPara = mStory.paragraphs[k].move(LocationOptions.AT_BEGINNING, mEndNotes.parentStory);
                          currPara.words[0].remove();
                  // create footnote markers
                  app.findGrepPreferences.findWhat = "\\[\\d+\\]";
                  mMarkers = mStory.findGrep();
                  len = mMarkers.length;
                  while (len-->0) {
                      cIP = mMarkers[len].insertionPoints[0].index;
                      mMarkers[len].remove();
                      mStory.footnotes.add( LocationOptions.AFTER, mStory.insertionPoints[cIP] );
                  // fill footnote contents with proper text
                  for (k=0; k < mStory.footnotes.length; k++) {
                      currFoot = mStory.footnotes[k];
                      mEndNotes.paragraphs[0].texts[0].move(LocationOptions.AT_END, currFoot.texts[0]);
                      if (mStory.footnotes[k].characters[-1].contents == "\r") mStory.footnotes[k].characters[-1].remove();
                  mEndNotes.remove();
                  Assumings:
                  • both text and endnotes are in the same story
                  • one of this story's textContainer is named "story"
                  • each endnote is a separate (one) paragraph
                  • initially there is a white space after endnote's number
                  Jarek
                  • 6. Re: convert text to footnote
                    Perfect. Just had to change "story" to our frame names, we use two frames, a Dutch and a French one (2 frames side by side), and run the script twice.
                    Thanks a lot Jarek.
                    • 7. Re: convert text to footnote
                      adriano.lucas
                      Hello Jarek,
                      First of all, thank you for this script. It seems that it will do exactly what I am looking for. Also, kindly bear with me as I am a complete beginner with InDesign scripting.
                      I'm trying to use your script for exactly the same reason as above, but I have an issue with one of the conditions given: "one of this story's textContainer is named 'story'" In the line:
                      Is it possible to apply your script to the entire document (or story/stories)? Or, how do I attribute the name "story" to the current story in my document?
                      Again, thank you for your help, Jarek.
                      Adriano
                      • 8. Re: convert text to footnote
                        Jump_Over Level 5
                        adriano.lucas  napisał(-a)
                        Hi Adriano,
                        You need to assign a name "story" to one of textFrames which are your target story container (anyone).
                        I mean to assign this name using "Layer Panel" or adding a line of code.
                        In case of target it to every stories - it should be rewritten...:)
                        Jarek
                        • 9. Re: convert text to footnote
                          adriano.lucas Level 1
                          Great, thanks Jarek. I understand now. I've given the name "story" to a given layer, and it's working fine now :-).
                          Adriano
