• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Click-activated animations do not work when I publish Presenter
Guest
Jan 27, 2014 Jan 27, 2014
When I publish my Presenter presentation using Connect, my click-activated animations do not work. Is there a setting I am missing in Connect? I am using Presenter 7.0.7 and Connect Pro 7.5.
TOPICS
Presenter
Views
579
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Did you use the Sync feature to cue the clicks at the correct point in the audio?
Votes
Translate
Translate
Report
Report
Guest
There is no audio. I just want the learner to click on an object, and the next object should then appear. I have it set up to start on click.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
That isn't how the animation cues translate in Presenter.
The timing of the animations is based on the audio, or silence, on each slide. There is 5 seconds of silence on each slide, but you can add or remove silence in the Audio Edit tool.
On-click animations can be placed wherever they are needed to cue in the presentation. By default they are all placed at the end of the slides audio/silence. This can be done by moving the click markers in the Audio Edit tool or by using the Sync tool to cue the animations when desired.
If you want the user to have to click to move on after each animation, you can turn on the 'Pause after each animation' feature under Presentation Settings > Playback > Pause after each animation. The viewer will have to click the Play button to move on, not on the slide though.
Votes
Translate
Translate
Report
Report
Resources
Help resources
