8 Replies Latest reply on Feb 6, 2014 6:36 AM by Szalam
    Can't import video into After Effects
    breaker1crazy
      Hey guy's, Im trying to import a MPEG video from my camcorder into after effects, but AE says that the video is "corrupted or unsupported" and won't load it. I've tried taking it and exporting it from Premiere Pro and i've also tried just importing it as raw footage and it won't load it either way. I'll post some pictures below. Do you guys know whats wrong/ how to fix it?
        • 1. Re: Can't import video into After Effects
          breaker1crazy Level 1
          CompleteName :F:\MP_ROOT\101PNV01\M2U00135.MPG
          Format :MPEG-PS
          FileSize/String :25.7 MiB
          Duration/String :34s 528ms
          OverallBitRate_Mode/String :Variable
          OverallBitRate/String :6 248 Kbps
          Video
          ID/String :224 (0xE0)
          Format :MPEG Video
          Format_Version :Version 2
          Format_Profile :Main@Main
          Format_Settings_BVOP/String :Yes
          Format_Settings_Matrix/String :Custom
          Format_Settings_GOP :M=3, N=15
          Duration/String :34s 468ms
          BitRate/String :5 868 Kbps
          BitRate_Maximum/String :9 100 Kbps
          Width/String :720 pixels
          Height/String :480 pixels
          DisplayAspectRatio/String :16:9
          FrameRate/String :29.970 fps
          Standard :NTSC
          ColorSpace :YUV
          ChromaSubsampling :4:2:0
          BitDepth/String :8 bits
          ScanType/String :Interlaced
          ScanOrder/String :Top Field First
          Compression_Mode/String :Lossy
          Bits-(Pixel*Frame) :0.567
          TimeCode_FirstFrame :00:00:00:00
          TimeCode_Source :Group of pictures header
          StreamSize/String :24.1 MiB (94%)
          Audio
          ID/String :189 (0xBD)-128 (0x80)
          Format :AC-3
          Format/Info :Audio Coding 3
          Format_Settings_ModeExtension :CM (complete main)
          Format_Settings_Endianness :Big
          MuxingMode :DVD-Video
          BitRate_Mode/String :Constant
          BitRate/String :256 Kbps
          Channel(s)/String :2 channels
          ChannelPositions :Front: L R
          SamplingRate/String :48.0 KHz
          BitDepth/String :16 bits
          Video_Delay/String :-67ms
          StreamSize/String :1.05 MiB (4%)
          • 3. Re: Can't import video into After Effects
            The top one is codec information and the bottom picture is what my screen looks like when i try to import it.
            • 4. Re: Can't import video into After Effects
              Does it play back in Premiere with no problems? If so, a workaround would be using the Adobe Media Encoder to transcode it to a proper production codec (which actually isn't a bad workflow regardless).
              What version of AE are you running? And I mean the specific version number such as 12.2.0, 11.0.4, etc.
              Also, what camera is this coming from and how did you get the data from the camera into the computer? I'm guessing it's fairly old considering that it's not HD footage.
              • 5. Re: Can't import video into After Effects
                It plays in premiere fine, I'll try the media encoder. Im using version 11.0 the camera is a sony handycam, probably 5 or so years old. I use a usb cord that goes from the camcorder to my laptop.
                • 6. Re: Can't import video into After Effects
                  What media does the camera record onto? Are you copying files over USB or are you capturing via Firewire?
                  And your AE version is 11.0.what? That third number is important. You should be using version 11.0.4. If not, you're missing some serious bug fixes and should probably update it.
                  • 7. Re: Can't import video into After Effects
                    sorry i've been away for a while, haven't had  a chance to look at the adobe media encoder and probably won't get to it till this weekend. I'm using version 11.0.0.378, I just downloaded this trial like 3 weeks ago, why do i have such an old version?
                    • 8. Re: Can't import video into After Effects
                      Update and see if it helps.
