1. Re: ATM Deluxe compatibility with Windows 7 64 bit?
Dov Isaacs Jan 27, 2014 3:52 PM (in response to William_Horne)Sorry, but ATM is totally incompatible with any 64-bit version of Windows (including Windows XP). It is also incompatible with all versions of Windows beyond Windows XP 32 bit (such as Windows Vista, Windows 7, and Windows 8.x).
Don't even try installing it. Even if you think you've succeeded, you may find that you have “bricked” your OS and would need to totally reinstall it.
- Dov
2. Re: ATM Deluxe compatibility with Windows 7 64 bit?
Thomas Phinney Jan 27, 2014 4:34 PM (in response to Dov Isaacs)On the 64-bit side, what Dov said.
On the 32-bit side, it is quite possible to hack an ATM install it on Vista, and not even very hard. I actually documented it on behalf of Adobe back in the day. I don’t know it if would work or blow up on Windows 7 or 8, and given that we don’t know, there is a real risk of damaging your OS.
(On Vista 32-bit, all you had to do was copy over the installed ATM files, and the app would run just fine. You just couldn’t run the ATM Deluxe installer on Vista.)
Of course none of this is supported or actively recommended by Adobe or me. Even the 32-bit Vista hack was “this appears to work, try it at your own risk.” Though I ran it myself for several years with no trouble.
Frankly, the ONLY reason I would even try such a thing today is if I or somebody desperately needed the ability to create and use Multiple Master font instances. That is the only thing you totally can’t do with anything else, and itself might or might not work with current apps, even if the functionality worked in ATM Deluxe. I am pretty sure Adobe apps removed MM support years ago, not so sure about third parties, including Windows itself.
So there you go. If you are in the market for a font manager today that is actively developed and maintained, there is always our product here at Extensis: Suitcase Fusion. (Or for client/server needs, Universal Type Server.)
3. Re: ATM Deluxe compatibility with Windows 7 64 bit?
William_Horne Jan 27, 2014 5:27 PM (in response to Thomas Phinney)Thanks, Dov and Thomas for your replies - much appreciated.
4. Re: ATM Deluxe compatibility with Windows 7 64 bit?
Thomas Phinney Jan 27, 2014 6:28 PM (in response to William_Horne)I for one would be very curious about the results of copying an installed ATM Deluxe app from XP onto (32-bit) Windows 7 and/or 8, as I did with Vista. But I sure would not try it on an install I cared about at all! If one had a spare VM image to duplicate and test on, that would be the way to go.
Mind you, even if it appeared to work I wouldn't swear it would never cause problems later—just too untested!
5. Re: ATM Deluxe compatibility with Windows 7 64 bit?
William_Horne Feb 6, 2014 4:00 PM (in response to Thomas Phinney)My version of Windows 7 is 64 bit Pro, so I won't risk attempting an installation of ATM on that machine. However, I'm going to install Ubuntu on an older desktop and will give it a try on that one. Will try to remember to report here whether or not I'm successful ;-)
6. Re: ATM Deluxe compatibility with Windows 7 64 bit?
Dov Isaacs Feb 6, 2014 4:15 PM (in response to William_Horne)ATM is not Linux-compatible!
- Dov
7. Re: ATM Deluxe compatibility with Windows 7 64 bit?
William_Horne Feb 6, 2014 6:27 PM (in response to Dov Isaacs)Sorry, I meant to say I'd try installing ATM within a virtual install of XP within Ubuntu.
8. Re: ATM Deluxe compatibility with Windows 7 64 bit?
William_Horne May 16, 2014 10:48 AM (in response to Thomas Phinney)Ok, I am now running Windows 7 Pro 64-bit and installed Extensis Suitcase Fusion; gradually rebuilding my font sets. That's going mostly ok.
However, I did discover some important files that used Multiple Master fonts (e.g. titles for art fridge magnets). I can't afford to purchase replacement fonts for all of them, but I could go back into my old XP desktop machine and convert the titles to outlines, resave and then bring them back into my newer Windows 7 machine. But then I have to reinstall a second, older version of Illustrator on the older machine.
Not a big deal, but I wonder if I risk "bricking" my Windows 7 OS if I were to try installing ATM through the Windows Virtual PC & Windows XP Mode? It would be more convenient to cut and paste from within the same machine.
(btw I haven't yet had time to install XP in VirtualBox within Ubuntu to test an ATM installation in that environment.)
9. Re: ATM Deluxe compatibility with Windows 7 64 bit?
Dov Isaacs May 16, 2014 11:59 AM (in response to William_Horne)Do NOT even think about it!
ATM will not run on XP 64-bit at all and it could be very risky trying to install it on the XP-mode of Windows 7.
Your time is worth a hell of a lot more than the cost of replacing some ancient Multiple Master fonts with OpenType fonts.
– Dov
10. Re: ATM Deluxe compatibility with Windows 7 64 bit?
William_Horne May 16, 2014 12:03 PM (in response to Dov Isaacs)Ok, thanks for the advice. I'll stick with Plan A then and avoid any contact with the 64-bit machine.
