1 Reply Latest reply: Feb 2, 2014 9:58 PM by Nanoucab RSS
    Help with a Bad Request on the CRM API
    Jupiter Community Member
      Hi All,
      I'm new the BC API's and have an issue I'm hoping someone can help with.
      The following request generates a Bad Request... but I can't see why. Can anyone see what I've done wrong?
      I've also included a second request in this email with a badly formatted timestamp which is giving me an understandable error - bad format I've only included this second request because it appears to be reading it - at least until it fins an error - which makes me think that the format is almost correct.
      Thanks in advance.
      Kind Regards,
      Jupiter
      POST /catalystwebservice/catalystcrmwebservice.asmx HTTP/1.1
      Host: myDomain.worldsecuresystems.com
      Content-Type: text/xml; charset=utf-8
      Content-Length: 882
      SOAPAction: "http://tempuri.org/CatalystDeveloperService/CatalystCRMWebservice/ContactList_Retrieve"
      <env:Envelope xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:enc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:env="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" env:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
      <env:Body>
          <ContactList_Retrieve xmlns="http://tempuri.org/CatalystDeveloperService/CatalystCRMWebservice">
            <username xsi:type="xsd:string">myEmail</username>
            <password xsi:type="xsd:string">myPassword</password>
            <siteId xsi:type="xsd:integer">mySiteId</siteId>
            <lastUpdateDate xsi:type="xsd:date">2013-01-01T10:15:30-10:00</lastUpdateDate>
            <recordStart xsi:type="xsd:integer">0</recordStart>
            <moreRecords xsi:type="xsd:boolean">false</moreRecords>
          </ContactList_Retrieve>
      </env:Body>
      </env:Envelope>
      The above returns:
      HTTP/1.1 400 Bad Request
      Cache-Control: private
      Content-Type: text/html
      Access-Control-Allow-Origin: *
      Date: Mon, 27 Jan 2014 23:48:06 GMT
      Content-Length: 11
      Bad Request
      The second example with the bad timestamp format is:
      Content-Length: 883
      <env:Body>
            <lastUpdateDate xsi:type="xsd:date">2013-01-01T10:15:30Z-10:00</lastUpdateDate>
      </env:Body>
      </env:Envelope>
      ...which returns:
      HTTP/1.1 500 Internal Server Error
      Content-Length: 504
      Date: Mon, 27 Jan 2014 23:55:04 GMT
           <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
                <soap:Body>
                     <soap:Fault>
                          <faultcode>soap:Client</faultcode>
                          <faultstring>Server was unable to read request. ---&gt; There is an error in XML document (8, 86). ---&gt; The string '2013-01-01T10:15:30Z-10:00' is not a valid AllXsd value.</faultstring>
                          <detail />
                     </soap:Fault>
           </soap:Body>
      </soap:Envelope>
      Any advice would be greatly appreciated.
