0 Replies Latest reply on Jan 29, 2014 1:07 PM by creativejoan0425
    EventListener in Book
    creativejoan0425 Level 1
      I have a login script, i just put a part of it, i add an eventListener in a document, that can beforePrint will update the user id, but I found that can't work in booklet, I try to change something in my doc and print a booklet, but the user id will change, it is eventListener can't active in book?
      funEventListener();
      function funEventListener() {
                var myEventNames = ["beforeQuit", "beforeOpen", "afterNew", "afterOpen", "beforeClose", "afterSave", "afterSaveAs", "afterSaveACopy", "afterPrint", "afterExport", "beforeSave", "beforeSaveAs", "beforeSaveACopy", "beforePrint", "beforeExport"];
                for (var i = 0; i < myEventNames.length; i++) {
                          app.addEventListener(myEventNames[i], funEvent);
                if (myLog_status == "undefined" && myEvent.eventType != "beforeQuit") {
                          myEvent.stopPropagation();
                          myEvent.preventDefault();
                          return;
                var myString = "";
                if (myEvent.target.constructor.name == "Document") {
                          myDocument = myEvent.target;
                          if (myEvent.eventType == "afterNew") myString = "Opened a New Document.";
                          if (myEvent.eventType == "afterOpen") myString = "Opened File " + (myDocument.saved ? myDocument.fullName : myDocument.name + " [Converted]");
                          if (myEvent.eventType == "beforeClose") myString = myDocument.saved ? "Closed File " + myDocument.fullName : "Closed New Document without saving.";
                          if (myEvent.eventType == "afterSave") myString = "Saved File " + myDocument.fullName;
                          if (myEvent.eventType == "afterSaveAs") myString = "Saved File (Save As) " + myDocument.fullName;
                          if (myEvent.eventType == "afterSaveACopy") myString = "Saved File (Save A Copy) " + myDocument.fullName;
                          if (myEvent.eventType == "afterPrint") myString = myDocument.saved ? "Printed " + myDocument.fullName : "Printed New Document.";
               if (myEvent.eventType == "afterExport") myString = myDocument.saved ? "Exported " + myDocument.fullName : "Exported New Document.";
               if (myEvent.eventType == "beforeSave" || myEvent.eventType == "beforeSaveAs" || myEvent.eventType == "beforeSaveACopy" || myEvent.eventType == "beforePrint" || myEvent.eventType == "beforeExport") {
                                    for (var i = 0; i < app.documents.length; i++) {
                                              if (app.documents[i].undoHistory.length > 0) {
                                                        if (app.documents[i].textVariables.item("User_id") != null) {
        app.documents[i].textVariables.item("User_id").variableOptions.contents = myLog_status;
                } else if (myEvent.target.constructor.name == "LayoutWindow") {
                          if (myEvent.eventType == "afterOpen") {
                                    app.activeDocument.stories.everyItem().trackChanges = true;
                if (myString) funWriteLogFile(myLog_status, myString);
                function funGetPhaseName(myPhase) {
                          switch (myPhase) {
                          case EventPhases.atTarget:
                                    myPhaseName = "At Target";
                                    break;
                          case EventPhases.bubblingPhase:
                                    myPhaseName = "Bubbling";
                                    break;
                          case EventPhases.done:
                                    myPhaseName = "Done";
                                    break;
                          case EventPhases.notDispatching:
                                    myPhaseName = "Not Dispatching";
                                    break;
                          return myPhaseName;
