6 Replies Latest reply on Feb 3, 2014 6:15 AM by Americo Pinto
    dropdownlist used onchange of an another dropdownlist
    Americo Pinto
      Hi everyody,
      I try to select my way by using two dropdownlist.
      Each item on the first list change the second dropdownlist
      example
      List A                              List B               List C               List D  etc..
      ItemA1  -> call ListB     ItemB1               ItemC1
      ItemA2  -> call ListC     ItemB2               ItemC2
      itemA3  -> call ListD     ItemB3               ItemC3
      itemA4  -> call ListE     ItemB4               ItemC4
      I scripted like this :
      var myList0= ["ItemA1", "ItemA2", "ItemA3", "ItemA4"];
      var myListA = ["ItemB1", "ItemB2", "ItemB3", "ItemB4"];
      var myListB = etc ....
      var columns = myOption2.add("group");
      var dimC = [0, 0, 100, 50];
      var col1 = columns .add('dropdownlist', dimC , myList0);
      col1.onChange = function()
           if (col1.selection == 0)
                     var col2 = columns .add('dropdownlist', dimC, myListA);
                     return col2;
           else if (col1.selection == 1)
                     var col2 = columns .add('dropdownlist', dimC, myListB);
           etc ....
      finally, it happens that my second dropdownlist overlap the first, and i want it separately.
      Please, if anyone have an idea ?
      best regards
      Américo
        • 1. Re: dropdownlist used onchange of an another dropdownlist
          Marc Autret Level 4
          Hi Américo,
          Two suggestions:
          • Have your data structure as abstract as possible, and keep it independent from the UI.
          • Do not hardcode the bounds of your controls (as this inhibits the auto layout mechanism).
          Here is a generic template to 'link' two dropdownlist. In my code I use an associative array of arrays to represent your data:
          const MIN_DD_SIZE = [100, 50];
          var data = {
              'Item1 (B)' : ['ItemB1', 'ItemB2', 'ItemB3', 'ItemB4' /*...*/],
              'Item2 (C)' : ['ItemC1', 'ItemC2', 'ItemC3' /*...*/],
              'Item3 (D)' : ['ItemD1', 'ItemD2', 'ItemD3', 'ItemD4', 'ItemD5' /*...*/],
              // etc.
          var keys = [], z = 0,
              w, g, col1, col2;
          // Feed keys (= col1 strings)
          for( keys[z++] in data );
          // Create the UI
          w = new Window('dialog',"Test");
          (g = w.add('group')).orientation = 'row';
          (col1 = g.add('dropdownlist', undefined, keys)).minimumSize = MIN_DD_SIZE;
          (col2 = g.add('dropdownlist')).minimumSize = MIN_DD_SIZE;
          col1.proxy = col2;
          // Change item event
              var dd = this.proxy,
                  t, a, i;
              dd.items.length && dd.removeAll();
              if( !(t=this.selection) ) return;
              for( a=data[t.text],t=a.length,i=0 ; i < t ; dd.add('item',a[i++]) );
              t && (dd.selection=a[0]);
          // Init. & Go
          col1.selection = keys[0];
          col1.onChange();
          w.show();
          Hope that helps.
          Marc
          • 2. Re: dropdownlist used onchange of an another dropdownlist
            Americo Pinto Level 1
            Hi Marc,
            Thanks a lot ! It works well and better than I could hope.
            Best Regards.
            Américo
            PS : are you french ?
            • 3. Re: dropdownlist used onchange of an another dropdownlist
              Marc Autret Level 4
              > are you French?
              Well, I have many other defects but, yes, I'm French.
              Marc
              • 4. Re: dropdownlist used onchange of an another dropdownlist
                No offens, nobody's perfect, and I share the same DNA error code .
                Please one more question, i'll get the first and the second onChange results as variables, how could I do this on your code.
                As you can see I'm not powerfull in scripting.
                Best regards.
                Américo
                • 5. Re: dropdownlist used onchange of an another dropdownlist
                  Marc Autret Level 4
                  Not sure I understand your question. Do you mean that you need the newly selected list item to be stored in a variable?
                  Within a List.onChange callback the selected ListItem is referred to by this.selection You can then use either ListItem's index or text property to process the data.
                  Marc
                  • 6. Re: dropdownlist used onchange of an another dropdownlist
                    Hi Marc,
                    i'm very sorry. Finally i find it by myself. You're explaination is well but i don't write the command lines in the right place.
                    Thank you for time.
                    Américo
