9 Replies Latest reply: Feb 4, 2014 12:27 PM by Jeff_Coatsworth RSS
    RoboHelp 10 can't update linked FrameMaker book
    SOLpubs Community Member
      TCS 4
      Linked FrameMaker book
      HTML Help output
      When I open a previously working project and go to update the FrameMaker files, the Update and Update All options are greyed out.
      A possible culprit is that Windows Update ran automatically while the project was open, and then restarted the machine.
      If I Force Update All, RH launches an instance of FM, which doesn't open anything and remains on its startup screen. If FM is already running with the book + .fm files open, another instance of FM starts w/o loading any files. RH then hangs, going into a "Not responding" state in Task Manager.
      If I start a new blank project and attempt to link to the FM book, RH launches another blank instance of FM and hangs.
      I tried opening the project and exporting the project settings in an .isf file, but RH hangs trying to scan.
      i tried relinking the FM book, but RH launches another blank instance of FM and hangs.
      i tried deleting the book, but RH hung partially through the deletion.
      i tried reinstalling RH. Same behavior.
      Is there some file I can delete and/or restore to reacquiant FM and RH?
      Note that when Windows Update ran the FM book was open too, and when I subsequently generated/updated the book, some files were listed as missing and some cross-refs were broken. This was fixed by replacing the broken cross-refs. The FM book generated/updated with no errors before the first attempt to update in RH.
      Thanks.
