0 Replies Latest reply on Jan 28, 2014 12:08 PM by creativejoan0425
    Print(false)
    creativejoan0425 Level 1
      my script showm below, if I use myDoc.print(false) will have R6025 Run time Error, but If I use myDoc.print(true) or myDoc.print() that will be ok, can anyone fix it?
      #targetengine "myHandler";
      if(app.documents.length > 0){
      var myPrintPrefs = myDoc.printPreferences;
      if (app.printerPresets.item("PDF_fit on paper") == null) {
         alert("Printer preset \"PDF_fit on paper\" is not installed.");
         exit();
      else {
         myPrintPrefs.activePrinterPreset = app.printerPresets.item("PDF_fit on paper");
      for(var i = 0; i < app.documents.length; i++)
                                    if(app.documents[i].undoHistory.length > 0)
                                              if(app.documents[i].textVariables.item("User_id") != null)
                                                        app.documents[i].textVariables.item("User_id").variableOptions.c ontents = myLog_status;
      var myDocProof = myDoc.textVariables.item('proof').variableOptions.contents;
      var currentYear = new Date().getFullYear();
      var currentMonth = new Date ().getMonth()+1;
      var currentDate = new Date().getDate();
      var currentHours = new Date().getHours();
      var currentMinutes = new Date().getMinutes();
      var PreMon = ((currentMonth < 10) ? "0" : "")+currentMonth;
      var PreDate = ((currentDate < 10) ? "0" : "")+currentDate;
      var PreHours = ((currentHours < 10) ? "0" : "")+currentHours;
      var PreMinutes = ((currentMinutes < 10) ? "0" : "")+currentMinutes;
      var myFileName = myDoc.name.replace(/\.indd$/i, "") + "_" + myDocProof.replace(/st Proof|nd Proof|rd Proof|th Proof| Proof/i, "P") + "_" + currentYear + PreMon + PreDate + "_" + PreHours + PreMinutes +".ps";
      var myPsFolder = new Folder("~desktop/" + "/LowRes/In");
      var myFile = new File(myPsFolder + "/" + myFileName);
      myPrintPrefs.printFile = myFile;
      myDoc.print(false);
      alert(myFileName.replace(/\.ps$/i, ".pdf").replace(/%20/g, " ")+"\rSmallest File Size PDF Done!");
      below is my part of login script:
      funEventListener();
      function funEventListener() {
                var myEventNames = ["beforeQuit", "beforeOpen", "afterNew", "afterOpen", "beforeClose", "afterSave", "afterSaveAs", "afterSaveACopy", "afterPrint", "afterExport", "beforeSave", "beforeSaveAs", "beforeSaveACopy", "beforePrint", "beforeExport"];
                for (var i = 0; i < myEventNames.length; i++) {
                          app.addEventListener(myEventNames[i], funEvent);
                if (myLog_status == "undefined" && myEvent.eventType != "beforeQuit") {
                          myEvent.stopPropagation();
                          myEvent.preventDefault();
                          return;
                var myString = "";
                if (myEvent.target.constructor.name == "Document") {
                          myDocument = myEvent.target;
                          if (myEvent.eventType == "afterNew") myString = "Opened a New Document.";
                          if (myEvent.eventType == "afterOpen") myString = "Opened File " + (myDocument.saved ? myDocument.fullName : myDocument.name + " [Converted]");
                          if (myEvent.eventType == "beforeClose") myString = myDocument.saved ? "Closed File " + myDocument.fullName : "Closed New Document without saving.";
                          if (myEvent.eventType == "afterSave") myString = "Saved File " + myDocument.fullName;
                          if (myEvent.eventType == "afterSaveAs") myString = "Saved File (Save As) " + myDocument.fullName;
                          if (myEvent.eventType == "afterSaveACopy") myString = "Saved File (Save A Copy) " + myDocument.fullName;
                          if (myEvent.eventType == "afterPrint") myString = myDocument.saved ? "Printed " + myDocument.fullName : "Printed New Document.";
               if (myEvent.eventType == "afterExport") myString = myDocument.saved ? "Exported " + myDocument.fullName : "Exported New Document.";
               if (myEvent.eventType == "beforeSave" || myEvent.eventType == "beforeSaveAs" || myEvent.eventType == "beforeSaveACopy" || myEvent.eventType == "beforePrint" || myEvent.eventType == "beforeExport") {
                                    for (var i = 0; i < app.documents.length; i++) {
                                              if (app.documents[i].undoHistory.length > 0) {
                                                        if (app.documents[i].textVariables.item("User_id") != null) {
        app.documents[i].textVariables.item("Us er_id").variableOptions.contents = myLog_status;
                } else if (myEvent.target.constructor.name == "LayoutWindow") {
                          if (myEvent.eventType == "afterOpen") {
                                    app.activeDocument.stories.everyItem().trackChanges = true;
                if (myString) funWriteLogFile(myLog_status, myString);
                function funGetPhaseName(myPhase) {
                          switch (myPhase) {
                          case EventPhases.atTarget:
                                    myPhaseName = "At Target";
                                    break;
                          case EventPhases.bubblingPhase:
                                    myPhaseName = "Bubbling";
                                    break;
                          case EventPhases.done:
                                    myPhaseName = "Done";
                                    break;
                          case EventPhases.notDispatching:
                                    myPhaseName = "Not Dispatching";
                                    break;
                          return myPhaseName;
