0 Replies Latest reply on Aug 8, 2006 10:26 AM by J.Salice
    Need help with Flash Slide Show
    J.Salice Level 1
      Hello, Flash friends.
      I recently put together a Flash photo album for a client of mine. She wants to be able to upload new images, so I created it with XML using the following action-script:
      function loadXML(loaded) {
      if (loaded) {
      xmlNode = this.firstChild;
      image = [];
      description = [];
      total = xmlNode.childNodes.length;
      for (i=0; i<total; i++) {
      image = xmlNode.childNodes.childNodes[0].firstChild.nodeValue;
      description = xmlNode.childNodes.childNodes[1].firstChild.nodeValue;
      firstImage();
      } else {
      content = "file not loaded!";
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.onLoad = loadXML;
      xmlData.load("images.xml");
      listen = new Object();
      listen.onKeyDown = function() {
      if (Key.getCode() == Key.LEFT) {
      prevImage();
      } else if (Key.getCode() == Key.RIGHT) {
      nextImage();
      Key.addListener(listen);
      previous_btn.onRelease = function() {
      prevImage();
      next_btn.onRelease = function() {
      nextImage();
      p = 0;
      this.onEnterFrame = function() {
      filesize = picture.getBytesTotal();
      loaded = picture.getBytesLoaded();
      preloader._visible = true;
      if (loaded != filesize) {
      preloader.preload_bar._xscale = 100*loaded/filesize;
      } else {
      preloader._visible = false;
      if (picture._alpha<100) {
      picture._alpha += 10;
      function nextImage() {
      if (p<(total-1)) {
      p++;
      if (loaded == filesize) {
      picture._alpha = 0;
      picture.loadMovie(image[p], 1);
      desc_txt.text = description[p];
      picture_num();
      function prevImage() {
      if (p>0) {
      p--;
      picture._alpha = 0;
      picture_num();
      function firstImage() {
      picture._alpha = 0;
      picture.loadMovie(image[0], 1);
      desc_txt.text = description[0];
      picture_num();
      function picture_num() {
      current_pos = p+1;
      pos_txt.text = current_pos+" / "+total;
      As you can see, the images can only be viewed by clicking a "next" or "previous" button.
      Well, my client has since decided that she would like to drop the buttons and have the images automatically change from one to another while the user sits back and watches. This seems like such an easy code to add, but I am a novice at this, and I cannot find any forums or tutorials that give a proper code which I may copy and paste into this pre-existing code.
      Can anyone offer a suggestion?
      Thank you!!!!!
