1. Re: Keep with Next?
Peter Grainge Jan 30, 2014 1:23 AM (in response to JaredHess)I am not seeing why you would want that in HTML so I assume the requirement is to have that in the printed document you create. Are you mapping to a Word document or using the CSS option at the end of the wizard? If you are mapping to Word, simply set that option in the Word template.
2. Re: Keep with Next?
JaredHess Jan 30, 2014 11:04 AM (in response to Peter Grainge)Yes, it's not needed in HTML. It's just so I don't have to do the post processing step in the printed document. I'm using the project's native CSS, not mapping to a separate word template.
3. Re: Keep with Next?
Peter Grainge Feb 4, 2014 12:29 AM (in response to JaredHess)Try outputting to Word using native CSS, making the style change and then save the document as a template, removing all content. Next time you can map to that template and have the required styles. As long as you don't change the styles, that should work.
4. Re: Keep with Next?
JaredHess Feb 5, 2014 8:07 AM (in response to Peter Grainge)Okay. I'll give that a try. Thanks Peter.
