4 Replies Latest reply on Jan 29, 2014 12:25 PM by wcndave
    Project Settings Based on File
    wcndave
      I have tried pretty much every setting in turn, and it's getting really boring...
      I have a clip from my Mobile that I would like to edit.
      I just want to base the project settings on that one file, however I can't find any way to do so.
      Am I just being thick? I'd think this is one of the most important elements of creating a new project...
        • 1. Re: Project Settings Based on File
          The first thing you need to do is determine the properties of your video
          Codec & Format information, read both links in reply #1 http://forums.adobe.com/thread/1270588
          Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
          http://forums.adobe.com/thread/592070?tstart=30 for screen shot instructions
          For PC/Mac http://mediaarea.net/en/MediaInfo/Download
          • 2. Re: Project Settings Based on File
            wcndave Level 1
            But that's my point.  Rather than having to delve in to each file, when I get a bunch of clips, they are nearly always from a singel source, and I just want to open the clip and have PE11 create the settings from the first file.
            Otherwise I have to look through all the settings each and every time.  I know the settings of this file but cannot find anything that matches, so I have to live with black bars all around.
            I opened AVS, dragged the file in, it said "do you want to base all project settings on this file", I clicked yes, and I was up an running creating a montage of some clips.
            I spent half an hour on PE11 and got nowhere :-(
            FWIW the settings for this particular file are:
            Complete name                            : C:\Users\dave\Pictures\20131227_155808.mp4
            Format                                   : MPEG-4
            Format profile                           : Base Media
            Codec ID                                 : isom
            File size                                : 20.0 MiB
            Duration                                 : 47s 125ms
            Overall bit rate                         : 3 561 Kbps
            Encoded date                             : UTC 2013-12-27 14:58:57
            Tagged date                              : UTC 2013-12-27 14:58:57
            Video
            Format                                   : AVC
            Format/Info                              : Advanced Video Codec
            Format profile                           : Baseline@L3.0
            Format settings, CABAC                   : No
            Format settings, ReFrames                : 1 frame
            Format settings, GOP                     : M=1, N=30
            Codec ID                                 : avc1
            Codec ID/Info                            : Advanced Video Coding
            Duration                                 : 46s 937ms
            Bit rate                                 : 3 446 Kbps
            Width                                    : 720 pixels
            Height                                   : 480 pixels
            Display aspect ratio                     : 3:2
            Rotation                                 : 90°
            Frame rate mode                          : Variable
            Frame rate                               : 29.970 fps
            Minimum frame rate                       : 14.878 fps
            Maximum frame rate                       : 43.000 fps
            Standard                                 : NTSC
            Color space                              : YUV
            Chroma subsampling                       : 4:2:0
            Bit depth                                : 8 bits
            Scan type                                : Progressive
            Bits/(Pixel*Frame)                       : 0.333
            Stream size                              : 19.3 MiB (96%)
            Title                                    : VideoHandle
            Language                                 : English
            Audio
            Format                                   : AAC
            Format/Info                              : Advanced Audio Codec
            Format profile                           : LC
            Codec ID                                 : 40
            Source duration                          : 47s 154ms
            Source_Duration_FirstFrame               : 28ms
            Bit rate mode                            : Constant
            Bit rate                                 : 128 Kbps
            Channel(s)                               : 2 channels
            Channel positions                        : Front: L R
            Sampling rate                            : 48.0 KHz
            Compression mode                         : Lossy
            Stream size                              : 714 KiB (3%)
            Source stream size                       : 714 KiB (3%)
            Title                                    : SoundHandle
            Language                                 : English
            mdhd_Duration                            : 47125
            • 3. Re: Project Settings Based on File
              You will not be able to "successfully" edit this video in Premiere Elements (or Premiere Pro) because no version of Premiere is designed to work with variable frame rate video
              See the discussion of iPhone video at the next link
              Some people find that Iphone won't edit easily because it uses a variable frame rate
              - A possible fix in message #22 http://forums.adobe.com/thread/934466
              • 4. Re: Project Settings Based on File
                wcndave Level 1
                This was taken on android, but I guess the point is the same.
                It's a bit frustrating that a "premiere" product struggles where knock off type products that have lots of other flaws manage without problem.
                I'm using this to put together montages from phone cameras, compact cameras, dslr's, jvc camcorder and a couple of other rarer sources.
                I keep having to go back to avs, but it had some things that were so annoying UI wise that I got PE11, which I really can't use. Shame :-(
