4 Replies Latest reply on Feb 6, 2014 12:18 PM by rob day
    How do I add a bunch of lorem ipsum text to the InDesign spell check dictionary?
    bettyx1138
      When I spellcheck a huge doc w/ lots of lorem ipsum text spellcheck takes forever.
      If I use only one certain block of loremipsum text that's in the spellecheck dictionary it wouldn't stop at those words every time. Can I do this? Thanks.
      Using CS6.
        • 1. Re: How do I add a bunch of lorem ipsum text to the InDesign spell check dictionary?
          Joel Cherney Adobe Community Professional & MVP
          I don't know, but it seems like the wrong way to go about it to me. I'd just mark my lorem ipsom as "No Language" so that the spellcheck would skip it.
          • 2. Re: How do I add a bunch of lorem ipsum text to the InDesign spell check dictionary?
            bettyx1138 Level 1
            Ah, that's awesome thanks, Joel.
            (I'd still love to see an indd feature in spellcheck "ignore placeholder text" that we've put in w/ the "Fill with placeholder text" feature... I shall submit that.)
            • 3. Re: How do I add a bunch of lorem ipsum text to the InDesign spell check dictionary?
              When you add place holder text there's nothing that distinguishes it from regular text, so it seems like a difficult feature to add.
              You could script the adding of placeholder text and set the language of its text flow to No Language in the script.
              Something like this AppleScript could have a key command (note that it sets no language to the entire textflow of the placeholder text frame):
              tell application "Adobe InDesign CS6"
                  --the Placehoder text menu item
                  set lorem to item 1 of every menu action whose id is 119681
                  --check that there's an insertion point an fill with placeholder
                  try
                      set sel to class of selection
                      set c to {insertion point, character, word, paragraph, text}
                      if sel is in c then
                          invoke lorem
                          --set th
                          set applied language of parent story of selection to "[No Language]"
                      end if
                  end try
              end tell
              • 4. Re: How do I add a bunch of lorem ipsum text to the InDesign spell check dictionary?
                This is a bit better, it will change the added place holder text to No language and leave other text in the frame alone:
                    try
                        if sel is in c then
                            --the starting insertion point of the placeholder
                            set myStart to index of last character of parent story of selection
                            invoke lorem
                            --the ending insertion point of the placeholder
                            set myEnd to index of last character of parent story of selection
                            --the added placeholder
                            set myLorem to object reference of text from character myStart to character myEnd of parent story of selection
                            set applied language of every word of myLorem to "[No Language]"
                        end if
                    end try
                end tell
