1 Reply Latest reply on Jan 30, 2014 2:14 PM by Josh_Corey
    Checkbox and date/text feild
      I need to create a form with a checkbox and a date/text feild in the same row. Is this possible?
      An example is below:
      [ check box ] name of document [date/text feild]
      [  ] document name [1/30/2014]
        • 1. Re: Checkbox and date/text feild
          Josh_Corey Adobe Employee
          Sure - you can add fields adjacent an existing field using the "+" sign on the right side of the field to bring up the add field toolbar to add a field to the side.  You can also do this through the right click menu item "Add field beside", and you can Drag and Drop fields where you want them by clicking on the left side of the field and holding the mouse button down while you drag it where you want it, a blue vertical bar shows where it will be placed, drag it to the right of a row to add it to the right of existing fields.
