1 Reply Latest reply on Feb 26, 2014 6:58 AM by emale9999
    FindChangeByList for CS6 Server?
    Xtof_D
      Dear all,
      can anybody please help me?
      I am quite new to CS6 server and tried to use the well-known "FindChangeByList.jsx" on a generated document, but it doesn't work...
      I did some changes to the script as described in the Scripting User Guide for the server version, but I am not sure if this was right as two or three chnages didn't make sense to me...
      1. Replace the main() function with the following:
      function main(){
      if(app.documents.length > 0){
      //Provide a story object or a document object.
      myFindChangeByList(app.documents.item(0), false);
      2.     Delete the myDisplayDialog function.
      3.     Change the line:
      var myFindChangeFile = "/c/FindChangeSupport/FindChangeList.txt";
      to (you will have to fill in a valid file path for your system):
      set myFindChangeFile to "yukino:FindChangeSupport:FindChangeList.txt"
      --> Is this right?? This looked like AppleScript to me.
      To me it made more sense to change it to
          var myFindChangeFile = "FindChangeSupport/FindChangeList.txt";
      Doesn't a relative path work if the .txt file is in the specified subfolder?
      Which would be the right syntax for Windows path like "\\myserver\somefolder\myscriptfolder\FindChangeSupport\FindChangeList.txt"?
      4.     Delete the myFindChangeFile function.
      --> I didn't find this function, I deleted the myFindFile function
      5.     Delete the myGetScriptPath function.
      On CS6 desktop version I use the unchanged script version which works well and replaces the things defined in the txt file.
      After my changes my complete script looks like this, but nothing is replaced...
      //FindChangeByList.jsx
      //An InDesign CS4 JavaScript
      @@@BUILDINFO@@@ "FindChangeByList.jsx" 2.0.0.0 10-January-2008
      //Loads a series of tab-delimited strings from a text file, then performs a series
      //of find/change operations based on the strings read from the file.
      //The data file is tab-delimited, with carriage returns separating records.
      //The format of each record in the file is:
      //findType<tab>findProperties<tab>changeProperties<tab>findChangeOptions<tab>description
      //Where:
      //<tab> is a tab character
      //findType is "text", "grep", or "glyph" (this sets the type of find/change operation to use).
      //findProperties is a properties record (as text) of the find preferences.
      //changeProperties is a properties record (as text) of the change preferences.
      //findChangeOptions is a properties record (as text) of the find/change options.
      //description is a description of the find/change operation
      //Very simple example:
      //text    {findWhat:"--"}    {changeTo:"^_"}    {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}    Find all double dashes and replace with an em dash.
      //More complex example:
      //text    {findWhat:"^9^9.^9^9"}    {appliedCharacterStyle:"price"}    {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false}    Find $10.00 to $99.99 and apply the character style "price".
      //All InDesign search metacharacters are allowed in the "findWhat" and "changeTo" properties for findTextPreferences and changeTextPreferences.
      //If you enter backslashes in the findWhat property of the findGrepPreferences object, they must be "escaped"
      //as shown in the example below:
      //{findWhat:"\\s+"}
      //For more on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
      //or visit the InDesign Scripting User to User forum at http://www.adobeforums.com
      main();
      function main(){
      function myFindChangeByList(myObject){
          var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
          var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit, myStory;
          var myStartCharacter, myEndCharacter;
          if(myFindChangeFile != null){
              myFindChangeFile = File(myFindChangeFile);
              var myResult = myFindChangeFile.open("r", undefined, undefined);
              if(myResult == true){
                  //Loop through the find/change operations.
                  do{
                      myLine = myFindChangeFile.readln();
                      //Ignore comment lines and blank lines.
                      if((myLine.substring(0,4)=="text")||(myLine.substring(0,4)=="grep")||(myLine.substring(0,5)=="glyph")){
                          myFindChangeArray = myLine.split("\t");
                          //The first field in the line is the findType string.
                          myFindType = myFindChangeArray[0];
                          //The second field in the line is the FindPreferences string.
                          myFindPreferences = myFindChangeArray[1];
                          //The second field in the line is the ChangePreferences string.
                          myChangePreferences = myFindChangeArray[2];
                          //The fourth field is the range--used only by text find/change.
                          myFindChangeOptions = myFindChangeArray[3];
                          switch(myFindType){
                              case "text":
                                  myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
                                  break;
                              case "grep":
                                  myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
                                  break;
                              case "glyph":
                                  myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
                                  break;
                  } while(myFindChangeFile.eof == false);
                  myFindChangeFile.close();
      function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
          //Reset the find/change preferences before each search.
          app.changeTextPreferences = NothingEnum.nothing;
          app.findTextPreferences = NothingEnum.nothing;
          var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
          myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
          myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
          app.doScript(myString, ScriptLanguage.javascript);
          myFoundItems = myObject.changeText();
          //Reset the find/change preferences after each search.
      function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
          //Reset the find/change grep preferences before each search.
          app.changeGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences = NothingEnum.nothing;
          var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
          myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
          myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
          var myFoundItems = myObject.changeGrep();
          //Reset the find/change grep preferences after each search.
      function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
          //Reset the find/change glyph preferences before each search.
          app.changeGlyphPreferences = NothingEnum.nothing;
          app.findGlyphPreferences = NothingEnum.nothing;
          var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
          myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
          myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
          var myFoundItems = myObject.changeGlyph();
          //Reset the find/change glyph preferences after each search.
        • 1. Re: FindChangeByList for CS6 Server?
          emale9999 Level 1
          First of all there's a bracket missing for your main() function:
          At the beginning of your question there were two closing brackets at the end, what was correct, and in your complete code there's only one closing bracket.
          Your point three: Yes, this is AppleScript code. Using var myFindChangeFile = "FindChangeSupport/FindChangeList.txt"; is correct but you are going to use that script with InDesign Server so I'm not sure where your FindChangeList.txt file will be located. At the Server? I hope so.
          How does your FindChangeList.txt file look like? If it looks like this (and I recommend to use an absolute path), your script will work - locally at least.
          text<tab>{findWhat:"Replace me"}<tab>{changeTo:"I'm the replacement"}<tab>{}
          text<tab>{findWhat:"I'm bad"}<tab>{changeTo:"I'm good"}<tab>{}
