2 Replies Latest reply on Jan 31, 2014 2:32 AM by Franky Says
    InDesign CC Error on Launch :(
    Franky Says
      I have just purchased a new iMac and tried to install all my CC apps. They all work fine except InDesign which gives me this error on launch:
      "Unable to launch Adove InDesign as you do not haev sufficient permissions to access the preferences folders. Ensure that you have the appropriate permissions and then restart Adobe InDesign"
      This is odd because I currently have it working fine on my laptop.... Any ideas of how I can resolve this?
      Just some background info.. I used migration assistant to import all my data from my laptop to my new mac. This was a time machine backup, which was before I installed CC on the laptop – therefore I had to redownload and installl all the apps onto the new Mac....
        • 1. Re: InDesign CC Error on Launch :(
          Franky Says Level 1
          This is the log, I have installed and uninstalled at least 3 times ...
          01/31/14 15:51:34:830 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:51:34:831 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Visit http://www.adobe.com/go/loganalyzer/ for more information
          01/31/14 15:51:34:831 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:51:34:831 | [INFO] |  | OOBE | DE |  |  |  | 310323 | START - Installer Session
          01/31/14 15:51:34:831 | [INFO] |  | OOBE | DE |  |  |  | 310323 | RIBS version: 7.0.0.108
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | OSX version: 10.9.1
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Total Timer]
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | CHECK: Single instance running
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | CHECK : Credentials
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Load Deployment File
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | deploymentFile option not given
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | CHECK : Another Native OS installer already running
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Create Required Folders
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Assuming install mode
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Looking up install source path
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Sync Media DB ...
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Sync Media DB]
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Pre check media db sync
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | End of Pre check media db sync. Exit code: 0
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Sync Media DB] took 144 milliseconds (0.144 seconds) DTR = 9361.11 KBPS (9.14171 MBPS)
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ready to initialize session to start with ...
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [CreatePayloadSession]
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updated source path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {023B7112-5A50-11E3-966F-EAA971BD6D01}
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-es_MX-011213114620/AdobeInDesign9AppLang-es _MX-011213114620.zip
          01/31/14 15:51:34:834 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {04441A5A-5A4F-11E3-A278-757271BD6D01}
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-en_IL-011213113912/AdobeInDesign9AppLang-en _IL-011213113912.zip
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {1B0447FC-5A58-11E3-BFCF-A0E571BD6D01}
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppFSet-Mena-011213124402/AdobeInDesign9AppFSet-Men a-011213124402.zip
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {245C7482-5A53-11E3-84BD-385B72BD6D01}
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-zh_CN-011213120839/AdobeInDesign9AppLang-zh _CN-011213120839.zip
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {263AD722-5A52-11E3-A9C4-212472BD6D01}
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-pt_BR-011213120141/AdobeInDesign9AppLang-pt _BR-011213120141.zip
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {2B131C1A-5A51-11E3-8C26-5FEC71BD6D01}
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-ja_JP-011213115432/AdobeInDesign9AppLang-ja _JP-011213115432.zip
          01/31/14 15:51:34:835 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {31FF7BA0-5A50-11E3-AA27-EEB471BD6D01}
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-fi_FI-011213114740/AdobeInDesign9AppLang-fi _FI-011213114740.zip
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {37BB8166-5A4F-11E3-BF09-7E7D71BD6D01}
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-fr_MA-011213114040/AdobeInDesign9AppLang-fr _MA-011213114040.zip
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {471C2076-5A4E-11E3-9382-614671BD6D01}
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-cs_CZ-011213113401/AdobeInDesign9AppLang-cs _CZ-011213113401.zip
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {531BF55E-5A53-11E3-8563-796672BD6D01}
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-zh_TW-011213120958/AdobeInDesign9AppLang-zh _TW-011213120958.zip
          01/31/14 15:51:34:836 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {59C0832C-5A51-11E3-9A8F-9AF771BD6D01}
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-ko_KR-011213115557/AdobeInDesign9AppLang-ko _KR-011213115557.zip
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {5C4CBFE2-5A52-11E3-B4A5-2B2F72BD6D01}
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-ru_RU-011213120311/AdobeInDesign9AppLang-ru _RU-011213120311.zip
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {651D323E-5A50-11E3-A36C-4BC071BD6D01}
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-fr_CA-011213114903/AdobeInDesign9AppLang-fr _CA-011213114903.zip
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {6DC52F0A-5A4F-11E3-AE41-CA8871BD6D01}
          01/31/14 15:51:34:837 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-en_GB-011213114212/AdobeInDesign9AppLang-en _GB-011213114212.zip
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppBase2-mul-101213120900/AdobeInDesign9AppBase2-mu l-101213120900.zip
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {7E50595E-5A4E-11E3-BCF7-685171BD6D01}
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-da_DK-011213113522/AdobeInDesign9AppLang-da _DK-011213113522.zip
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {822A1060-5A53-11E3-B1DA-B37172BD6D01}
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppBase-mul-011213121814/AdobeInDesign9AppBase-mul- 011213121814.zip
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {8E52BA1A-5A51-11E3-8664-D50272BD6D01}
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-nb_NO-011213115724/AdobeInDesign9AppLang-nb _NO-011213115724.zip
          01/31/14 15:51:34:838 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {91427E62-5A52-11E3-9CDC-303A72BD6D01}
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-sv_SE-011213120432/AdobeInDesign9AppLang-sv _SE-011213120432.zip
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {960DF6BC-5A50-11E3-A389-50CB71BD6D01}
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-fr_FR-011213115027/AdobeInDesign9AppLang-fr _FR-011213115027.zip
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-en_US-011213114335/AdobeInDesign9AppLang-en _US-011213114335.zip
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {AB6B5934-5A4E-11E3-B9BD-6B5C71BD6D01}
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-de_DE-011213113639/AdobeInDesign9AppLang-de _DE-011213113639.zip
          01/31/14 15:51:34:839 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {B84F03C2-5A57-11E3-BE40-1ED871BD6D01}
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppFSet-Japan-011213124141/AdobeInDesign9AppFSet-Ja pan-011213124141.zip
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {BEFB4406-5A52-11E3-81D4-324572BD6D01}
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-tr_TR-011213120555/AdobeInDesign9AppLang-tr _TR-011213120555.zip
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {C12B9C90-5A51-11E3-BB19-180E72BD6D01}
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-nl_NL-011213115845/AdobeInDesign9AppLang-nl _NL-011213115845.zip
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {C6FD5FD8-5A50-11E3-B229-54D671BD6D01}
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-hu_HU-011213115149/AdobeInDesign9AppLang-hu _HU-011213115149.zip
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {D200D686-5A4F-11E3-8AF8-E39E71BD6D01}
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-es_ES-011213114454/AdobeInDesign9AppLang-es _ES-011213114454.zip
          01/31/14 15:51:34:840 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {D93E2792-5A4E-11E3-89BC-6F6771BD6D01}
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Ignoring original data since install source is local
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Type: 0, Volume Order: 1, Media Name: InDesignCC-AdobeUpdate
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-en_AE-011213113754/AdobeInDesign9AppLang-en _AE-011213113754.zip
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {F2C0A056-5A52-11E3-A7FB-355072BD6D01}
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-uk_UA-011213120722/AdobeInDesign9AppLang-uk _UA-011213120722.zip
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {F2F6A8C8-5A51-11E3-9C0D-1F1972BD6D01}
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-pl_PL-011213120013/AdobeInDesign9AppLang-pl _PL-011213120013.zip
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppFSet-Roman-011213124255/AdobeInDesign9AppFSet-Ro man-011213124255.zip
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Updating media info for: {F9C32678-5A50-11E3-B741-5AE171BD6D01}
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Path: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-it_IT-011213115315/AdobeInDesign9AppLang-it _IT-011213115315.zip
          01/31/14 15:51:34:841 | [INFO] |  | OOBE | DE |  |  |  | 310323 | --------------------  END  - Updating Media Sources -  END  --------------------
          01/31/14 15:51:34:849 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Supported RIBS version range: [0.0.0.0,7.0.0.108]
          01/31/14 15:51:34:850 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ----------------- CreatePayloadSession: machine is x86 ---------------
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ______ Verify Dependency Subscribers ______
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-es_MX 9.2.0.69 {023B7112-5A50-11E3-966F-EAA971BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           Family: InDesign
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-es_MX
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           MinVersion: 0.0.0.0
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           This parent relationship is not satisfied, because this payload is not present in this session.
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           This payload will be ignored in this session.
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_IL 9.2.0.69 {04441A5A-5A4F-11E3-A278-757271BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-en_IL
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Mena 9.2.0.69 {1B0447FC-5A58-11E3-BFCF-A0E571BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Feature Set Files
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-zh_CN 9.2.0.69 {245C7482-5A53-11E3-84BD-385B72BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-zh_CN
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-pt_BR 9.2.0.69 {263AD722-5A52-11E3-A9C4-212472BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-pt_BR
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-ja_JP 9.2.0.69 {2B131C1A-5A51-11E3-8C26-5FEC71BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-ja_JP
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-fi_FI 9.2.0.69 {31FF7BA0-5A50-11E3-AA27-EEB471BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-fi_FI
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-fr_MA 9.2.0.69 {37BB8166-5A4F-11E3-BF09-7E7D71BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-fr_MA
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-cs_CZ 9.2.0.69 {471C2076-5A4E-11E3-9382-614671BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-cs_CZ
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-zh_TW 9.2.0.69 {531BF55E-5A53-11E3-8563-796672BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-zh_TW
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-ko_KR 9.2.0.69 {59C0832C-5A51-11E3-9A8F-9AF771BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:516 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-ko_KR
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-ru_RU 9.2.0.69 {5C4CBFE2-5A52-11E3-B4A5-2B2F72BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           Family: InDesign
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-ru_RU
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           MinVersion: 0.0.0.0
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           This parent relationship is not satisfied, because this payload is not present in this session.
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           This payload will be ignored in this session.
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-fr_CA 9.2.0.69 {651D323E-5A50-11E3-A36C-4BC071BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-fr_CA
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_GB 9.2.0.69 {6DC52F0A-5A4F-11E3-AE41-CA8871BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-en_GB
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-da_DK 9.2.0.69 {7E50595E-5A4E-11E3-BCF7-685171BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-da_DK
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-nb_NO 9.2.0.69 {8E52BA1A-5A51-11E3-8664-D50272BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-nb_NO
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-sv_SE 9.2.0.69 {91427E62-5A52-11E3-9CDC-303A72BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-sv_SE
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-fr_FR 9.2.0.69 {960DF6BC-5A50-11E3-A389-50CB71BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-fr_FR
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-de_DE 9.2.0.69 {AB6B5934-5A4E-11E3-B9BD-6B5C71BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-de_DE
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Japan 9.2.0.69 {B84F03C2-5A57-11E3-BE40-1ED871BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Feature Set Files
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-tr_TR 9.2.0.69 {BEFB4406-5A52-11E3-81D4-324572BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-tr_TR
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-nl_NL 9.2.0.69 {C12B9C90-5A51-11E3-BB19-180E72BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-nl_NL
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-hu_HU 9.2.0.69 {C6FD5FD8-5A50-11E3-B229-54D671BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-hu_HU
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-es_ES 9.2.0.69 {D200D686-5A4F-11E3-8AF8-E39E71BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-es_ES
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_AE 9.2.0.69 {D93E2792-5A4E-11E3-89BC-6F6771BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-en_AE
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-uk_UA 9.2.0.69 {F2C0A056-5A52-11E3-A7FB-355072BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-uk_UA
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-pl_PL 9.2.0.69 {F2F6A8C8-5A51-11E3-9C0D-1F1972BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-pl_PL
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 | DW023: The extension payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-it_IT 9.2.0.69 {F9C32678-5A50-11E3-B741-5AE171BD6D01} requires a parent with following specification:
          01/31/14 15:51:36:517 | [INFO] |  | OOBE | DE |  |  |  | 310323 |           ProductName: Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-it_IT
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}: 0 (0,0)
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}: 0 (0,0)
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}: 0 (0,0)
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}: 0 (0,0)
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Patch Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01} can be applied to product Adobe InDesign CC Application Base Files2 9.0.0.0 {B1D20EDC-ACE6-11E2-B3AC-27469275A9A8}
          01/31/14 15:51:36:518 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Patch Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01} can be applied to product Adobe InDesign CC Application Base Files 9.0.0.0 {C3409B0A-ACE8-11E2-9ED3-A79B9175A9A8}
          01/31/14 15:51:36:519 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Patch Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01} can be applied to product Adobe InDesign CC Application Language Files_AdobeInDesign9AppLang-en_US 9.0.0.0 {DFFB5C1A-ACE5-11E2-945D-EA3C9275A9A8}
          01/31/14 15:51:36:519 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Patch Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01} can be applied to product Adobe InDesign CC Application Feature Set Files 9.0.0.0 {ABBC5854-ACE6-11E2-96DE-FE459275A9A8}
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Setting property "installSourcePath" to: /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Setting property "mode" to: silent
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Setting property "updateManifestPath" to: /Users/frankdemaria/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeInDesignCC-9.0/9.2.0.069/9.2.0.069.xml
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Setting property "workflow" to: updater
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Overwrite property "extensionsOnly" to: 1
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Overwrite property "mode" to: silent
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Overwrite property "patchesOnly" to: 1
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Overwrite property "updateManifestPath" to: /Users/frankdemaria/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeInDesignCC-9.0/9.2.0.069/9.2.0.069.xml
          01/31/14 15:51:37:956 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Overwrite property "workflow" to: updater
          01/31/14 15:51:37:957 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Found payload actions:
          01/31/14 15:51:37:957 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Deciding what installer mode to use...
          01/31/14 15:51:38:030 | [INFO] |  | OOBE | DE |  |  |  | 310323 | BEGIN Setting requested payload actions
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Value returned on lookup of payload: Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01} is: false
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Action string for Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}  is install
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Value returned on lookup of payload: Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01} is: false
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Action string for Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}  is install
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Value returned on lookup of payload: Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01} is: false
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Action string for Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}  is install
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Value returned on lookup of payload: Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01} is: false
          01/31/14 15:51:38:031 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Action string for Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}  is install
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END Setting requested payload actions
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Collected advanced path check information for INSTALLDIR
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | INSTALLDIR is a well-formed path
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | INSTALLDIR is not the root path
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | INSTALLDIR is on a local volume
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | INSTALLDIR is on a writable volume
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | INSTALLDIR is not on a case sensitive volume
          01/31/14 15:51:38:034 | [INFO] |  | OOBE | DE |  |  |  | 310323 | INSTALLDIR passed path basic path validation: /Applications
          01/31/14 15:51:38:066 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [System check :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}]
          01/31/14 15:51:38:067 | [INFO] |  | OOBE | DE |  |  |  | 310323 | In InstallPreSystemCheckProc
          01/31/14 15:51:38:067 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:51:38:067 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [System check :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}] took 0 milliseconds (0 seconds)
          01/31/14 15:51:38:073 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [System check :{822A1060-5A53-11E3-B1DA-B37172BD6D01}]
          01/31/14 15:51:38:075 | [INFO] |  | OOBE | DE |  |  |  | 310323 | In InstallPreSystemCheckProc
          01/31/14 15:51:38:075 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:51:38:075 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [System check :{822A1060-5A53-11E3-B1DA-B37172BD6D01}] took 1 milliseconds (0.001 seconds)
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 | BEGIN InstallOperationsQueue Unordered operations
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}:  with operation install
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}:  with operation install
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}:  with operation install
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}:  with operation install
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END InstallOperationsQueue Unordered operations
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 | BEGIN InstallOperationsQueue Ordered operations
          01/31/14 15:51:38:137 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END InstallOperationsQueue Ordered operations
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Payloads passed preflight validation.
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Call PreSession Custom Hook
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Pre session :{822A1060-5A53-11E3-B1DA-B37172BD6D01}]
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | In InstallSessionOpenProc
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Pre session :{822A1060-5A53-11E3-B1DA-B37172BD6D01}] took 0 milliseconds (0 seconds)
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | BEGIN InstallOperationsQueue Unordered operations
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}:  with operation install
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}:  with operation install
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}:  with operation install
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 |   Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}:  with operation install
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END InstallOperationsQueue Unordered operations
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | BEGIN InstallOperationsQueue Ordered operations
          01/31/14 15:51:38:285 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END InstallOperationsQueue Ordered operations
          01/31/14 15:51:38:355 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for pre-install for payload Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}
          01/31/14 15:51:38:355 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Pre payload :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}]
          01/31/14 15:51:38:355 | [INFO] |  | OOBE | DE |  |  |  | 310323 | In PrePayloadInstallProc
          01/31/14 15:51:38:355 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:51:38:355 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Pre payload :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}] took 0 milliseconds (0 seconds)
          01/31/14 15:51:38:355 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Payload Operation :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}]
          01/31/14 15:51:38:371 | [INFO] |  | OOBE | DE |  |  |  | 310403 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:51:38:371 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Installer Operation: PayloadInstaller
          01/31/14 15:51:38:371 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Request to install payload
          01/31/14 15:51:38:383 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Payload Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
          01/31/14 15:51:39:554 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Extracting assets complete. Number assets: 1
          01/31/14 15:51:39:554 | [INFO] |  | OOBE | DE |  |  |  | 310403 | CustomizedPatch property not found in database
          01/31/14 15:51:39:554 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Beginning installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppBase2-mul-101213120900/Install.db
          01/31/14 15:51:44:793 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Evaluating condition# 1(Seq 4129)
          01/31/14 15:51:44:800 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Condition failed(Seq 4129)
          01/31/14 15:51:44:801 | [INFO] |  | OOBE | DE |  |  |  | 310403 | Completing installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppBase2-mul-101213120900/Install.db
          01/31/14 15:51:44:826 | [INFO] |  | OOBE | DE |  |  |  | 310403 | UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}.db
          01/31/14 15:52:06:702 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:52:06:702 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Payload Operation :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}] took 28332 milliseconds (28.332 seconds) DTR = 4533.25 KBPS (4.427 MBPS)
          01/31/14 15:52:07:003 | [INFO] |  | OOBE | DE |  |  |  | 310323 | User specified overrideFile:
          01/31/14 15:52:07:057 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Successfully updated the csu inventory for Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01} return values 0:0
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for post-install for payload Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul 9.2.0.69 {7DA2FD00-6164-11E3-87E7-76BC71BD6D01}
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Post payload :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}]
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | InDesign Patch CustomHook: In PostPayloadInstallProc
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | InDesign Patch CustomHook: INSTALLDIR value:
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Applications
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | InDesign Patch CustomHook: Core Mac application.xml path:
          01/31/14 15:52:07:078 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Resources/AMT/application.xml
          01/31/14 15:52:07:079 | [INFO] |  | OOBE | DE |  |  |  | 310323 | InDesign Patch CustomHook:Trial has been successfully reset
          01/31/14 15:52:07:079 | [INFO] |  | OOBE | DE |  |  |  | 310323 |  InDesign Patch CustomHook: Core application.xml updated.
          01/31/14 15:52:07:097 | [INFO] |  | OOBE | DE |  |  |  | 310323 |  InDesign Patch CustomHook: Clearing the cache...
          01/31/14 15:52:07:097 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:52:07:097 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Post payload :{7DA2FD00-6164-11E3-87E7-76BC71BD6D01}] took 18 milliseconds (0.018 seconds) DTR = 1555.56 KBPS (1.5191 MBPS)
          01/31/14 15:52:07:265 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for pre-install for payload Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}
          01/31/14 15:52:07:265 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Pre payload :{822A1060-5A53-11E3-B1DA-B37172BD6D01}]
          01/31/14 15:52:07:265 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: In PrePayloadInstallProc
          01/31/14 15:52:07:265 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:52:07:265 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Pre payload :{822A1060-5A53-11E3-B1DA-B37172BD6D01}] took 0 milliseconds (0 seconds)
          01/31/14 15:52:07:265 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Payload Operation :{822A1060-5A53-11E3-B1DA-B37172BD6D01}]
          01/31/14 15:52:07:274 | [INFO] |  | OOBE | DE |  |  |  | 312738 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:52:07:274 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Installer Operation: PayloadInstaller
          01/31/14 15:52:07:274 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Request to install payload
          01/31/14 15:52:07:291 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Payload Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
          01/31/14 15:52:10:094 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Extracting assets complete. Number assets: 1
          01/31/14 15:52:10:094 | [INFO] |  | OOBE | DE |  |  |  | 312738 | CustomizedPatch property not found in database
          01/31/14 15:52:10:094 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Beginning installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppBase-mul-011213121814/Install.db
          01/31/14 15:52:12:576 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Evaluating condition# 1(Seq 1759)
          01/31/14 15:52:12:579 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Condition failed(Seq 1759)
          01/31/14 15:54:14:169 | [INFO] |  | OOBE | DE |  |  |  | 312738 | Completing installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppBase-mul-011213121814/Install.db
          01/31/14 15:54:14:189 | [INFO] |  | OOBE | DE |  |  |  | 312738 | UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{822A1060-5A53-11E3-B1DA-B37172BD6D01}.db
          01/31/14 15:54:31:606 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:54:31:606 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Payload Operation :{822A1060-5A53-11E3-B1DA-B37172BD6D01}] took 144268 milliseconds (144.268 seconds) DTR = 2464.16 KBPS (2.40641 MBPS)
          01/31/14 15:54:31:674 | [INFO] |  | OOBE | DE |  |  |  | 310323 | User specified overrideFile:
          01/31/14 15:54:31:703 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Successfully updated the csu inventory for Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01} return values 0:0
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for post-install for payload Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul 9.2.0.69 {822A1060-5A53-11E3-B1DA-B37172BD6D01}
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Post payload :{822A1060-5A53-11E3-B1DA-B37172BD6D01}]
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: In PostPayloadInstallProc
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: BEGIN
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: (1) Populate INSTALLDIR
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: Installing Files
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: Getting INSTALLDIR
          01/31/14 15:54:31:744 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Applications
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | en_US
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | After modification
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: LIST...
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: Source...
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Library/Application Support/Adobe/InDesign/Version 9.0/AdobeInDesign9AppBase/RFS/Adobe InDesign CC.app/Contents/_CodeSignature/CodeResources
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Library/Application Support/Adobe/InDesign/Version 9.0/AdobeInDesign9AppBase/RFS/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: Target...
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/_CodeSignature/CodeResources
          01/31/14 15:54:31:745 | [INFO] |  | OOBE | DE |  |  |  | 310323 | /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
          01/31/14 15:54:31:757 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: coderesource copied succesfully
          01/31/14 15:54:31:758 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: Executable copied sucessfully
          01/31/14 15:54:31:758 | [INFO] |  | OOBE | DE |  |  |  | 310323 | IDPATCH: END
          01/31/14 15:54:31:758 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:54:31:758 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Post payload :{822A1060-5A53-11E3-B1DA-B37172BD6D01}] took 14 milliseconds (0.014 seconds) DTR = 6000 KBPS (5.85938 MBPS)
          01/31/14 15:54:31:818 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for pre-install for payload Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}
          01/31/14 15:54:31:818 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Payload Operation :{A0DAD516-5A4F-11E3-9171-DF9371BD6D01}]
          01/31/14 15:54:31:830 | [INFO] |  | OOBE | DE |  |  |  | 318361 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:54:31:830 | [INFO] |  | OOBE | DE |  |  |  | 318361 | Installer Operation: PayloadInstaller
          01/31/14 15:54:31:830 | [INFO] |  | OOBE | DE |  |  |  | 318361 | Request to install payload
          01/31/14 15:54:31:842 | [INFO] |  | OOBE | DE |  |  |  | 318361 | Payload Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
          01/31/14 15:54:31:914 | [INFO] |  | OOBE | DE |  |  |  | 318361 | Extracting assets complete. Number assets: 1
          01/31/14 15:54:31:914 | [INFO] |  | OOBE | DE |  |  |  | 318361 | CustomizedPatch property not found in database
          01/31/14 15:54:31:914 | [INFO] |  | OOBE | DE |  |  |  | 318361 | Beginning installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-en_US-011213114335/Install.db
          01/31/14 15:54:32:020 | [INFO] |  | OOBE | DE |  |  |  | 318361 | Completing installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppLang-en_US-011213114335/Install.db
          01/31/14 15:54:32:048 | [INFO] |  | OOBE | DE |  |  |  | 318361 | UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A0DAD516-5A4F-11E3-9171-DF9371BD6D01}.db
          01/31/14 15:54:32:635 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:54:32:635 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Payload Operation :{A0DAD516-5A4F-11E3-9171-DF9371BD6D01}] took 816 milliseconds (0.816 seconds) DTR = 1681.37 KBPS (1.64197 MBPS)
          01/31/14 15:54:32:695 | [INFO] |  | OOBE | DE |  |  |  | 310323 | User specified overrideFile:
          01/31/14 15:54:32:725 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Successfully updated the csu inventory for Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01} return values 0:0
          01/31/14 15:54:32:746 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for post-install for payload Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US 9.2.0.69 {A0DAD516-5A4F-11E3-9171-DF9371BD6D01}
          01/31/14 15:54:32:792 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for pre-install for payload Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}
          01/31/14 15:54:32:792 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Payload Operation :{F55AEBC8-5A57-11E3-8162-BDE271BD6D01}]
          01/31/14 15:54:32:805 | [INFO] |  | OOBE | DE |  |  |  | 318368 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:54:32:805 | [INFO] |  | OOBE | DE |  |  |  | 318368 | Installer Operation: PayloadInstaller
          01/31/14 15:54:32:805 | [INFO] |  | OOBE | DE |  |  |  | 318368 | Request to install payload
          01/31/14 15:54:32:817 | [INFO] |  | OOBE | DE |  |  |  | 318368 | Payload Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
          01/31/14 15:54:32:855 | [INFO] |  | OOBE | DE |  |  |  | 318368 | Extracting assets complete. Number assets: 1
          01/31/14 15:54:32:855 | [INFO] |  | OOBE | DE |  |  |  | 318368 | CustomizedPatch property not found in database
          01/31/14 15:54:32:855 | [INFO] |  | OOBE | DE |  |  |  | 318368 | Beginning installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppFSet-Roman-011213124255/Install.db
          01/31/14 15:54:32:886 | [INFO] |  | OOBE | DE |  |  |  | 318368 | Completing installation for payload at /Users/frankdemaria/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCC-9.0/9.2.0.069/InDesig nCC-AdobeUpdate/payloads/AdobeInDesign9AppFSet-Roman-011213124255/Install.db
          01/31/14 15:54:32:890 | [INFO] |  | OOBE | DE |  |  |  | 318368 | UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{F55AEBC8-5A57-11E3-8162-BDE271BD6D01}.db
          01/31/14 15:54:33:206 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:54:33:206 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Payload Operation :{F55AEBC8-5A57-11E3-8162-BDE271BD6D01}] took 414 milliseconds (0.414 seconds) DTR = 3922.71 KBPS (3.83077 MBPS)
          01/31/14 15:54:33:462 | [INFO] |  | OOBE | DE |  |  |  | 310323 | User specified overrideFile:
          01/31/14 15:54:33:495 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Successfully updated the csu inventory for Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01} return values 0:0
          01/31/14 15:54:33:500 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Calling the custom action code for post-install for payload Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman 9.2.0.69 {F55AEBC8-5A57-11E3-8162-BDE271BD6D01}
          01/31/14 15:54:33:545 | [INFO] |  | OOBE | DE |  |  |  | 310323 | No operation.  We're done:
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Successfully installed 4 components:
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 |  - Adobe InDesign CC Application Base Files2_9.2.0.069_AdobeInDesign9AppBase2-mul
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 |  - Adobe InDesign CC Application Base Files_9.2.0.069_AdobeInDesign9AppBase-mul
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 |  - Adobe InDesign CC Application Language Files_9.2.0.069_AdobeInDesign9AppLang-en_US
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 |  - Adobe InDesign CC Application Feature Set Files_9.2.0.069_AdobeInDesign9AppFSet-Roman
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Total components repaired: 0
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Total components removed: 0
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Call PostSession Custom Hook
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | ::START TIMER:: [Post session :{822A1060-5A53-11E3-B1DA-B37172BD6D01}]
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | In InstallSessionCloseProc
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Custom action return code: 0
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Post session :{822A1060-5A53-11E3-B1DA-B37172BD6D01}] took 0 milliseconds (0 seconds)
          01/31/14 15:54:35:551 | [INFO] |  | OOBE | DE |  |  |  | 310323 | :: END TIMER :: [Total Timer] took 182268 milliseconds (182.268 seconds) DTR = 2786.42 KBPS (2.72112 MBPS)
          01/31/14 15:54:36:553 | [INFO] |  | OOBE | DE |  |  |  | 310323 | Exit Code: 0 - No error.
          01/31/14 15:54:36:553 | [INFO] |  | OOBE | DE |  |  |  | 310323 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
          01/31/14 15:54:36:553 | [INFO] |  | OOBE | DE |  |  |  | 310323 | END - Installer Session
          • 2. Re: InDesign CC Error on Launch :(
            Franky Says Level 1
            I solved my own problem by reading this thread:
            http://forums.adobe.com/message/5901356
            Sorry for the repost... but checking that I had read and write permissions in my  Cache and Preferences folders in my user Library folder solved the problem!
