2 Replies Latest reply on Jan 31, 2014 10:27 AM by jccs3
    RH10 and Multiple TOCs
    jccs3 Level 1
      Using RH10HTML I created a project with two TOCs.  Both have different topics and was wondering if there is a way to have the WebHelp search only search a selected TOC as opposed to searching both?
        • 1. Re: RH10 and Multiple TOCs
          Hi there
          As long as your project meets the following criteria there is.
          1. You must be using Dynamic User Centric Content (DUCC) where you have content categories.
          2. You then configure each category with its own TOC.
          3. Within each category, you must enable the option to Exclude Unreferenced Topics from Output.
          4. You must ensure no other topic links to a topic you do not wish to be found in the search. (if a link exists, it's considered to be a referenced topic)
          Hope this helps... Rick
          • 2. Re: RH10 and Multiple TOCs
            jccs3 Level 1
            Thank you very much Sir.
            That is the exact results I was looking for.:)
