1. Re: Blog Template won't work right
Liam Dilley Jan 31, 2014 2:25 PM (in response to William Noel)Have you set up the Blog to be running a template?
You just have a page there..
/blog_pjspeech.html
I guess you put a module in there to render blog posts.
You know that when you set up a blog..
/my-blog
You can link to that and that will render the overal layout so you can access more of the blog features like tag cloud etc.
Also as a note in that url you have blog_pjspeech.
Search engines read that as blogpjspeech. All one word. They know to split words when using the -
2. Re: Blog Template won't work right
William Noel Feb 1, 2014 11:51 AM (in response to Liam Dilley)Thanks Liam
I changed file names to not have the_
Re the Blog
Since I'm not using BC Dynamic Menus - I'm using html menu.
How can I link the menu item to the BC Blog in Admin or DW - instead of a page?
Appreciate all your support
Will
3. Re: Blog Template won't work right
William Noel Feb 3, 2014 8:05 AM (in response to Liam Dilley)Liam,
I think I figured out something
Is this correct? - to use the url in blog details: http://www.pjspeech-hearing.com/port-jefferson-speech-hearing-blog
for blog link in my "non-dynamic" menu instead of a html page like you suggested.
Is this correct proceedure?
But if you look at my blog using template it only shows the BLOG TITLE and not the whole blog post
Blog not using template shows everything but just plain white background.
Will
4. Re: Blog Template won't work right
Liam Dilley Feb 3, 2014 1:25 PM (in response to William Noel)If your not using a dynamic menu and just have a static html menu then you will not be able to make anything you do in the admin automatically update that menu.
