I am using photoshop cc and cannot find the "place" command. All I have under file is "place embedded and place linked. Will you be able to help me?
Those are the place commands. You choose whether you want the placed file to be embedded or linked.
I placed my logo in another drawing like your tutorials, and once I sized it, I couldn't edit it anymore. So, in order to be able to move it around and edit it, which place should I use? Sorry to be so stupid on this, but this is my first introduction to Photoshop. Merci!
Bonjour.
The place commands does place the file as a smart object, it's not therefore a regular layer.
More info: http://help.adobe.com/en_US/photoshop/cs/using/WSACAD27BE-C403-47f2-BE6A-BDFBE87CDA57.html
If you want to have regular pixels that you can directly edit, you should open the other file, and drag it's contents to the first document.
thank you
There are two place options now, Instead of just adding Place Link and leaving the old place option Adobe renamed Place to Place embedded and may have change its operation a bit. Old code that use place still works. And both Place Embedded and Place Linked add smart object layer that have copies of the original file in the layers embedded object. So they are independent from the original. However the Place Linked object is also linked to the original file. If the document is open when the original file is updated and committed the smart object layer will be automatically updated. If its not open and later opened in the future you will be informed that the original file has been updated or that the link was broken because the file was either moved or delete. In Layer menu smart objects several new options have been added one can be used to resolve broken links. I would think if one was to open a linked smart object layer the the original file or the resolved file would be open. If the link was not resolved the object would the be changed to a Place Embedded layer and the file copy would be used. I have not tested this so what is written is just a guess on my part for I do not have a need for Place Linked....
Thanks for your information. this is hard.
tacowatha wrote:
this is hard.
No its Software
Thanks so much man!
