• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
No matching authentication protocol Oracle 12c
Guest
Feb 01, 2014 Feb 01, 2014
Hi, we are working with ColdFusion 10 and Oracle 12c Database, but when we are trying to connect with the database across CF, we have the following message:
java.sql.SQLException: [Macromedia][Oracle JDBC Driver][Oracle]ORA-28040: No matching authentication protocol
Does anybody know how can we work with Oracle 12c? Is necessary an update to fix that?
Thank you.
TOPICS
Database access
Views
11.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner ,
Mar 24, 2014 Mar 24, 2014
Here's the message I got back from Adobe. It can be referenced in the bugbase (https://bugbase.adobe.com/index.cfm?event=bug&id=3721707).
Rupesh Kumar
1:24:29 AM GMT+00:00 Mar 18, 2014
The support for Oracle 12c is there in ColdFusion 11. As of now, we don't have any plans to add this support in ColdFusion 9/10
Stephen Johnson
Adobe Advanced ColdFusion Certified Developer (ADB184437)
Votes
Translate
Translate
Report
Report
Guest
Hi Stephen Johnson
I appreciate too much your help, for this moment we will continue working
in CF 10, and we will wait the new version of CF 11 to work with 12c.
Thank you very much for your support, greetings from Mexico.
Sincerely
Javier Morales Rangel
2014-03-24 10:46 GMT-06:00 Runrocket <forums_noreply@adobe.com>:
Re: No matching authentication protocol Oracle 12c created by
Runrocket <http://forums.adobe.com/people/Runrocket> in Database Access- View
the full discussion <http://forums.adobe.com/message/6237571#6237571
Votes
Translate
Translate
Report
Report
New Here ,
Jul 02, 2014 Jul 02, 2014
I have oracle 12c working with coldfusion 11 enterprise edition on 64bit oracle linux 6.5.
However, 12c uses a container/pluggable architecture.
If I create a user in the container database (CDB), the datasource GUI in CF11 can log into that user account.
If I create a user in the pluggable database (PDB), I CANNOT get CF11 to log into that account.
If I create an oracle service name in listener.ora, I CAN log into the pluggable account from the shell i.e. sqlplus user@pdb.
So, the service naming is not the issue.
Is it even possible to hit the account within the PDB with the default ORACLE driver in CF11 datasource GUI?
Or, ...must one set up the database as a container-only to allow CF11 access?
Votes
Translate
Translate
Report
Report
Guest
Jul 15, 2015 Jul 15, 2015
If you need to get CF9 or 10 to work with Oracle 12c until you can upgrade to CF11, add this to your sqlnet.ora file on your database server:
SQLNET.ALLOWED_LOGON_VERSION_SERVER=8
In Oracle 12c, the default was effectively changed to 11, meaning that older authentication protocols will not work.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 18, 2015 Aug 18, 2015
Your fix worked for us, and I want to add we were having this problem with ColdFusion 8.
Votes
Translate
Translate
Report
Report
Nov 28, 2017 Nov 28, 2017
LATEST
Re. this setting:
Any idea what this might break? Oracle 12c is back-end for a mission-critical database; how likely is this change to cause a problem for other applications (e.g. Banner)?
Votes
Translate
Translate
Report
Report
Guest
Aug 26, 2015 Aug 26, 2015
I found this "amazing" solution here and it worked like a charm for me. It solves the problem on the Oracle side.
12c: USE_SID_AS_SERVICE_listener_name - ORACLE IN ACTION
It is sad that Adobe couldn't come up with an answer/(alternative) solution to this problem for such a long time - all those devoted CF users out there are feeling "abandoned"...
Votes
Translate
Translate
Report
Report
Resources
Documentation
