3 Replies Latest reply on Feb 4, 2014 2:23 AM by try67
    Javascript cannot read my csv file
    yvesha Level 1
      Hi there,
      I have a 48 page document which I need to split into 8 documents. I have the excel spreadsheet with column headed "filename" with 8 file names.
      When I select the data file to import after being asked to enter text at start of filename etc I see the message 'No filenames found - using "file-XX.pdf". Press Escape after continuing to cancel.'
      and then the error -
      RaiseError: The file may be read-only, or another user may have it open. Please save the document with a different name or in a different folder.
      Doc.extractPages:83:Console undefined:Exec
      ===> The file may be read-only, or another user may have it open. Please save the document with a different name or in a different folder.
      file-0
      I have checked the number of rows in the csv with the one which i created the merge in Indesign and it is the same. I have also tried usinh google docs spreadsheet but acrobat doesnt recognise the URL.
      Thank you.
      The script which I am using is:
      var CSV = function (data, delimiter) {
          var _data = CSVToArray(data, delimiter);
          var _head = _data.shift();
          return {
              length: function () {return _data.length;},
              adjustedLength: function () {return _data.length - 1;},
              getRow: function (row) {return _data[row];},
              getRowAndColumn: function (row, col) {
                  if (typeof col !== "string") {
                      return _data[row][col];
                  } else {
                      col = col.toLowerCase();
                      for (var i in _head) {
                          if (_head[i].toLowerCase() === col) {
                              return _data[row][i];
      function CSVToArray( strData, strDelimiter ){
          strDelimiter = (strDelimiter || ",");
          var objPattern = new RegExp(
                  // Delimiters.
                  "(\\" + strDelimiter + "|\\r?\\n|\\r|^)" +
                  // Quoted fields.
                  // Standard fields.
                  "([^\"\\" + strDelimiter + "\\r\\n]*))"
              "gi"
          var arrData = [[]];
          var arrMatches = null;
          while (arrMatches = objPattern.exec( strData )){
              var strMatchedDelimiter = arrMatches[ 1 ];
              if (
                  strMatchedDelimiter.length &&
                  (strMatchedDelimiter != strDelimiter)
                  arrData.push( [] );
              if (arrMatches[ 2 ]){
                  var strMatchedValue = arrMatches[ 2 ].replace(
                      new RegExp( "\"\"", "g" ),
              } else {
                  var strMatchedValue = arrMatches[ 3 ];
              arrData[ arrData.length - 1 ].push( strMatchedValue );
          return( arrData );
      function isInt(n) {
          return typeof n === "number" && n % 1 == 0;
      var prepend = app.response("Enter any text to go at the START of each filename:");
      var append = app.response("Enter any text to go at the END of each filename:");
      var pathStr = app.response("If the PDFs should be saved in a sub folder, enter the relative path here:", "", "pdf/");
      this.importDataObject("CSV Data");
      var dataObject = this.getDataObjectContents("CSV Data");
      var csvData = new CSV(util.stringFromStream(dataObject, 'utf-8'), ',');
      var pagesPerRecord = this.numPages / csvData.length();
      if (isInt(pagesPerRecord)) {
          for (var i = 0; i < this.numPages; i ++) {
              var pageStart = i*pagesPerRecord;
              var pageEnd = (i+1)*pagesPerRecord - 1;
              var recordIndex = (i + pagesPerRecord) / pagesPerRecord;
              var filename = csvData.getRowAndColumn(i, "filename");
              if (!filename) {
                  app.alert('No filenames found - using "file-XX.pdf". Press Escape after continuing to cancel.');
                  filename = "file-" + i;
              var settings = {nStart: pageStart, nEnd: pageEnd, cPath: pathStr+prepend+filename+append+'.pdf'};
              this.extractPages(settings);
      } else {
          var message = "The number of pages per row is not an integer (" + pagesPerRecord;
          message += ", " + this.numPages + " pages, " + csvData.length() + " rows).";
